Question about Vtech 5.8GHz Cordless Phone with Digital Answering System
My phone says "no line"
    Genius:
  • 1,196 Answers
Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, this will fix the problem.
Posted on Jan 02, 2011
Why does dial tone go beep beep beep?
It is called a stutter dial tone and usually means that you have messages on you voice mail.... But its is sounding like a motor boat, and sounds like your in a tunnel while talking. You may need to call your local repair. Could be a bad line card.. as long as its happening on all your phones..
Aug 15, 2015 | Lands Phones
ZTE MF190 Dialing problem
I have a unlocked ZTE Mf190 USB-Modem. When I put the SIM card in it and connect it to the computer, I am able to connect to 3G Internet via beetel connection manager. Is it also possible to send and receive SMS. But when I try to make a voice call on beetel voice call panel, I receive this error message "Dialing failed! Please try again!" . And also when I use another phone to call the SIM card line number that I put in the USB-Modem, I receive busy tone
Mar 31, 2013 | ZTE Mf190 Unlocked 3g Gsm 7.2 Mbps...
How do I stop the red message light from blinking after I have received my messages
~*~*~ SOLVED SOLVED SOLVED! ~*~*~ After talking to both ATT and RCA with no success...I figured it out. ~*~*~ Plug your phone line into the "DATA PORT" on the back of the unit. Slide the "DATA PORT" switch to whichever line is showing it has a message. Press the corresponding Line# button on the front of the phone. (you should hear the dial tone) Dial your voice mail number. Let it answer, (enter your passcode if needed), then hang up! - That's it! example: MSG Waiting:L2 - I plugged the phone line into the Data Port and moved the data port switch to "2". I pressed LINE 2 on the front of the phone, dialed my voice mail number, it answered, I put in my passcode. (It said that I did not have any new voice mails), then hung up! That's it! Message Indicator light off!!! Repeat for each line that shows a (false) message waiting. ~~~Don't forget to move your phone line back into it's correct port on the back of your phone.~~~
Jul 06, 2012 | RCA 25414RE3 Corded Phone
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
How do I retrieve messages from another extension when the "message" light is on?
If you dial 165 to retrieve voice mail messages, you can dial 165 #6 * and the extension that the MW light is lit on. It will be just as if you dialed 165 or pressed the MESSAGE button on that phone.
Carl
Feb 21, 2011 | Panasonic KX-T7433B Corded Phone
We have the Norstar Meridian (M7310)telephone system in our non-profit organization. Recently there was a change in our service providers and since that time we have had nothing but problems with our...
Could be two things, there could be a general delivery mailbox attached to the system which is mail box 100, or the new service provider has a off premisis voicemail attached to the lines. if there is VM on the lines you should get a stuttered dial tone on the line indicating that you have a voice mail.
Oct 13, 2009 | NorStar M7310 Corded Phone
I cannot retrive my voice mail messages from my sciphone i68+
If you have voice mail on a land line as opposed to your cellular phone, you shouldn't have an icon on your cellular phone to retrieve any but the voice mail on your cellular account. If there is a special phone number that you call to retrieve your land line voice mail, then dial it, and enter whatever codes are required to retrieve your land line voice mail.
Apr 25, 2009 | Dual Electronics CECT P168 Cellular Phone
Indicator message light on handheld phones do not go off!!!
on the base set, press and hold the voice mail 1 button. You will get a message clear voice mail indication? hit the sel/save button to the left of the display.
poof! message gone
Apr 17, 2008 | RCA ViSYS 2-Line Speakerphone
Voice Mail
There are two types of voice mail. One is from your local telephone provider and the othere is inside your phone system. Most telephone voice mail is signalled by a stuttered dial tone on the mail line. You would have to call the voicemail ( a local Phone number) and set up a password that will let you retrieve your messages. If this is what you have call your provider and they will tell you the number to call and give you your temporary password.
Jan 17, 2008 | RCA 25414RE3 Corded Phone
Voice mail
Do your Dial tone sound different. Your phone listens to the dial tone. if you have a new voice mail your dial tone changes.and your phone does the flashy thing accordingly. Contact your phone company.
Aug 18, 2007 | Motorola Mobility 5.8 GHz Digital Cordless...
Vtech 5.8GHz Cordless Phone with Digital Answering System Logo
409 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
