Question about Acer Aspire One AOD150-1920 Netbook
How do i need my acer AOD15 turn in a new computer from inside i mean delete everything and start from the first step
  • 97 Answers
If you have a recovery partition when the computer boots hit (alt) and (f10). If you do not then you will need to run the recovery CD's.
Posted on Jan 02, 2011
    Scholar:
  • 149 Answers
You need to use a USB cd-rom drive to reinstall windows. You can also do this from a usb stick, but that is more complicated.
1) Hook up your cdrom drive + insert the windows 7 CD
2) Turn the computer on, and when prompted press any key to boot from the disc.
3) Wait for windows to load the installer, and then follow the prompts. When the prompt asks you what drive to install windows on, select it and then choose to format it. (Quick format is fine)
4) Follow the prompts, and let windows finish the installation.
My acer laptop acting really slow
Perform the following steps to fix this problem:
  • Stop unwanted Programs
  • Stop unwanted Services
  • Delete Temporary files:
Click Start - Run, type in %temp% and then click OK.
Once that temp folder is open and you can view its contents, select and delete EVERYTHING that's inside it.
If issue is not resolved then use a pc optimization software like PCFresher.
Feb 18, 2013 | Acer Aspire 5100 Notebook
My acer is slow. has no memory but i've deleted nearly everything
You need to defragment your hard drive, try this program is free and do the job for you
And also you can use this program to see what prgram starts with windows and you can disable some of them to increase speed.
Oct 06, 2012 | Acer Aspire 5530G Drivers Recovery Restore...
Restore my acer aspire 5742 back to factory settings w/out disk
Step 1 Open the Windows Start menu by clicking on the icon in the lower left corner of your desktop.
Step 2 Click "All Programs," then the "Acer" folder.
Step 3 Select "Acer eRecovery Management" to open the utility. If a Windows prompt asks for permission to run the program, click "Yes."
Step 4 Click the "Restore" button in the pane on the left side of the program window.
Step 5 Click "Completely Restore System to Factory Defaults."
Step 6 Select the "Yes" option in the dialog box that asks you to confirm the action, and click "Start."
Step 7 Click "OK" in the second confirmation dialog box to restart the computer.
Step 8 Click "Next" in the warning window that appears after the computer reboots. This confirms that you realize restoring the computer deletes any data stored on your hard drive.
Step 9 Click "Next" again in the Restore Destination window, and click "OK" in the popup that gives you one last warning about deleting your data. The restoration process will begin.
Step 10 Click "OK" when the utility lets you know that the restoration is complete. The computer will restart, and Windows will finish the recovery process.
May 22, 2017 | Acer Aspire 5500 5570-2609 Laptop
My acer aspire R1600 is to slow,\r\nhow can i clean it ?
Go to 'Start' and then Run
write "msconfig" inside Run tab and press 'enter'
inside the 'System configuration utility' window click on 'startup' tab then uncheck all the applications except your current antivirus and press apply then 'ok' and then 'exit without restart' option.
Now right click My Computer and go to properties tab.
click 'Advanced' tab then under performance menu click on 'settings'
go to 'Advanced' click on 'change' and increase your virtual memory to 2048 in both spaces.
Now restart windows.
Just do the following steps and your issue will be resolved.
1) Delete all unwanted data from Drive C.
2) Delete all data that you have copied from Drive C to External HDD
3) Open My computer and go to Tools---> Folder Options---->Click on View Tab----> Check 'Show hidden files and folders' and select OK.
4) Go to C:\Documents and Settings\Administrator\Local Settings\Temp and Delete everything that you see inside Temp Folder
5) Go to C:\WINDOWS\ here you will find folders like $hf_mig$, here you will have to Delete all the folders starting and ending with $ sign.
6) Empty Recycle bin and restart the PC and your issue will be resolved.
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Jul 21, 2011 | Acer Aspire 3610 Notebook
My acer aspire one 532h windows did not respond properly always been hang and loading.how to fix it?
Jun 02, 2011 | Computers & Internet
When booting up,operating system not found. Using Acer Aspire 5536. Vista. Help!!!
That means the start up files on your computer are already corrupted. You may need to reinstall the operating system. You need an operating system disc for this to work.
Warning: Reinstalling the operating will wipe out everything on the hard drive, so if you need some help in backing up your files, either buy an external enclosure and back up the data on your other computer, or contact a local technician.
Here's the visual step by step guide:
http://www.theeldergeek.com/vista/vista_clean_installation.html
For your laptop's driver go to : support.acer.com
Feb 24, 2011 | Computers & Internet
I have a Acer aspire 6930. Sometimes, my laptop won't shut off, only showing "shutting off" message. I come back after an hour, still not off. What is going on? I have to forcibly turn it off by pressing...
ok sounds like you unit is in very serious need of cleaning and maybe even some virus removal.
to scan and remove viruses ( click here ). install this to your computer and allow it to scan and remove any found threats.
also click start then run or command prompts .
type : cookies.
a page will pop up. you will need to delete everything in this except index. index is a system file and can not be deleted. close this window and empty recycle bin. now you will need to repeat this step but this time you will type in : temp
delete everything in this window. these are the things that will slow your computer down. you will also need to do a disk clean up. and a disk defrag.
after that you computer will be running faster.
also i subjest removing some things from your start up menu. this will slow the computer down from shutting down quickly.
i hope this was helpful.
Nov 13, 2009 | Acer Aspire 6930-6771 Laptop
Acer Aspire 5520
Sounds like a fried battery. Try a brand new one.
Jul 14, 2009 | Acer Aspire 5520-5579 Notebook
Factory settings
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you have any other issue with your Acer laptop/desktop/Notebook, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
Mar 15, 2009 | Acer 4220-2346 Notebook
Acer Aspire One AOD150-1920 Netbook Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
