Question about Refrigerators
Cool on bottom of frige and freezing on bottom of freezer.side by side frig .
  • 1,772 Answers
Vbnbn
vbn
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Posted on Jan 02, 2011
Freezing up in duct system frig part
Have you checked the heater/defroster element within the freezer? It may be related. When mine failed I was doing the defrosting with a hair blower. Over time (several days) the frost would build up on the freezer coils and the air couldn't flow as it should....so the thermostat wasn't getting cooled enough and it relayed the information to the cooling system, causing the frige to run all the time. Since it was clogged with frost, the frige was constantly trying to cool itself and the frost problem would get so bad that things in the freezer began to melt due to a lack of cold air circulation. After the heater/defroster element was replaced, frost would melt during the defrost cycle (as it should) and airflow/circulation was restored, allowing the thermostat to be cooled properly. Then the freezer coil was able to 'rest' when it should instead of constantly freezing to meet the demand for cold air in the frige. Hope this makes sense...and helps solve your issue.
Apr 11, 2014 | Kenmore Refrigerators
Freezer frozen on bottom and frige cold on bottom only. No airflow coming from vents inside freezer or top left of frige, freezer and frig warm at the top. Model is a ED25QF
check to see if fan is running in freezer if it is you may have a defrost problem if not replace the fan its the evaorator fan that is in the freezer
Mar 08, 2010 | Whirlpool ED5FTGX Side by Side...
Our ge refrig runs constantly,freezer is freezing but the refrig is not cooling. I cleaned the dust and dirt out of the bottom and back of refrig.
See if the fan in side the frig is working It mite be on the freezer side If the fan is not working it will not blow the cold air in to the frig side
Jul 12, 2009 | Refrigerators
Frige freezing solid
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 03, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Freezer works like frig-freezer lite only one working
ch the fan in the frige feel it if is blowing air .or is slow. you need to replace the fan moter.
Feb 06, 2008 | LG LSC26905TT Side by Side Refrigerator
Bottom Freezer working but not side!
Typically the freezer air is circulated into the frige area to provide cooling. If the circ. fan is not working or the air ducts/channels/dampers are blocked with ice, food, etc. then no cool air will get from the freezer to the frige area. Check all the air channels and to see if the dampers are open along with the circulation fan running. The diagrams at the following link should help you see inside better. If your lower circulation fan is running then you likely have an air return/supply channel blocked with ice and will require an old style defrost (unplug unit and leave doors open for 24 hours to melt ice, etc.). If the fan isn't running then that needs to be replaced. Air channels can freeze up if a door is left open slightly overnight or other moisture enters the freezer/frige. http://www.partselect.com/MultiModels.aspx?ModelNum=ER6AHKXPQ&searchTerm=&RefineSearch=0
Nov 20, 2006 | Whirlpool ER6AHKXPQ Top Freezer...
Side by side freezer
Check that the freezer circulating fan is running. The frige section may have dampers or vents (lets the freezer air cool the refer section) that are open too much. Usually the bottom area in the frige has a control lever to meter how much cold air gets to that section (lots for meat, little for fruits, etc.). Check the owners manual for operation of those vent dampers.
Oct 22, 2006 | Maytag 60ADiW Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
