Question about LG LMV2053 Microwave Oven
LG Microvave just stopped all at once as if the power went out. Nothing will respond. I checked the outlet is fine.
  • 472 Answers
You may have blown a fuse if there is no power display...the fuse unfortunately is located in control panel... it usually is either a 15 amp or 20 amp fuse... do not put a larger one in or a smaller. to test the fuse if you cant visible see it is bad you will need to ohm out and should get continuity ...if the fuse is good and you have no display most likely the pcb or board is bad.... good luck
Posted on Jan 02, 2011
  • Anonymous Jan 02, 2011
    you may have blown a fuse if there is no power display...the fuse unfortunately is located in control panel... it usually is either a 15 amp or 20 amp fuse... do not put a larger one in or a smaller. to test the fuse if you cant visible see it is bad you will need to ohm out and should get continuity ...if the fuse is good and you have no display most likely the pcb or board is bad....
    good luck
Lg microwave MC-7648WH i had bought a lg microvave on 2008. it suddenly stops working . i also make complaint in lg service centre. the engineers said that a part had damaged and that part company had...
If you got it from Costco, they will refund you credit (not money)fully without asking.
If not AND if you can fix, you can buy parts from online store (or eBay).
Or, visit local electronic repair shop.
Jun 20, 2013 | Microwave Ovens
No power checked outlet and power is on
HELLO.
This is the way out of the problem.
The outlet is on power,the power problem is from the microwave.
check on the back of the microvave to locate the fuse that control the supply of power to the microvave.
Change the fuse because it is unable to control power supply.
Then plug the microwave to the outlet.
Thanks .
Sep 19, 2011 | GE JVM1790SK Convection/Microwave Oven
No power to microwave JVM1790SK ...checked outlet and it is live
HELLO.
Since the outlet is live,the power problem is from the microwave.
Thanks .
Clock,lights and turntable work but does not heat
Open the microvave discharge the capcitors.If you don't know then stop here and call pro .
Open it First check physically the nothing is burnt.I everything seems okay then, check the resistance of the magnetron and also the fuse.PLEASE DON'T TRY IF YOU DON'T KNOW HOW TO DISCHAGRE THE CAPACITORS.
Thanks
Please rate my work
Sep 17, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave does not react what so ever. Checked the fuse and its fine, what could be the problem? please help
Is there power at the outlet? You say you checked the fuse ... is that the one inside the machine? Is the outlet protected by a GFI (reset for a GFI is on the GFI)? A GFI looks like a ordinary outlet but is very sensitive to electrical irregularities. Your circuit breaker may be on or your power panel fuse may be fine and the fuse inside your oven may be fine. If the GFI is popped, you have no power.
Try some other electrical device in the outlet. Does it work? Try an extension cord from a known hot outlet?
Beyond these tips, you may need professional help with this.
Thanks for your interest in FixYa.com
Jan 22, 2010 | LG LMV1630ST Microwave Oven
My kenmore ELITE 721.64282 microwave/convection just stopped
I just had the exact same problem. :( Did you find anything out?
May 23, 2009 | Kenmore 63792 Microwave Oven
Help with repair for LG 2055ST
Check the internal fuse. Unplug it, unscrew and take off the cover, the fuse should be easily found in the back by the power cord. I tlooks like a regular fuse but is white instead of clear glass because microwave fuses are special. You'll have to measure it with a meter as a result and be sure to replace it with the same kind. (try finding them at radio shack) Hopefully there isn't something more serious also.
Dec 27, 2007 | LG LMV2055ST Microwave Oven
LG LMV2053 Microwave Oven Logo
147 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Will Halftowaite
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
