Question about Panasonic NV-GS21EG-S Mini DV Digital Camcorder
PANASONIC NV-GS21 Camcorder. There is no tape in the camcorder, but there is an SD card. When trying to record, it says that there is no tape - so I'm assuming I HAVE to have a tape to record. If I switch on the camcorder without trying to record, it says 'card error'\r\nHELP please. It is not full, and it has software on the SD card. I bought this second hand. No wires, no manual.
SOURCE: Transfer of video from Panasonic NV-GS50 tape to computer
You will need a firewire card in your PC and firewire cable to connect your camera to the PC. you will also need a software like Windows movie maker which can help you to transfer videos from your camera to the PC.
Posted on May 19, 2007
  • 33 Answers
SOURCE: panasonic nv-ds60
The fix is really easy and costs nothing, just 10 minutes of your time!
*I fixed mine (twice) this way*
Turn the cam over.
remove all the screws holding the dark plastic bottom on the camcorder, remove it carefully.
Now you will see the ribbon cables, VERY GENTLY, wiggle them from left to right (about 1mm each way), then push them in.
Test by putting your battery back on and see if it holds a tape, or plays without blinking and switching off - you will be happy.
The fault is simply that one cable (I can't tell you which one) becomes loose over time, so it just needs to be pushed back in and the condensation error and/or the door closing problem go away!
A lot of folks are buying cams off eBay like this as it's such a simple repair!
Good luck - please help others - post back if it works!
Posted on Feb 21, 2008
SOURCE: USB drivers for panasonic nv-gs11 gc
I have a software for that model.... NV-GS11GC it work only on Window XP,Me,98SE
Posted on Feb 25, 2008
SOURCE: trouble with finding Panasonic NV-GS11 Mini DV Digital Camcorder driver / software
NV-GS11
Posted on Dec 22, 2008
SOURCE: Lost driver software for Panasonic NV-MX500 Camcorder.
OMG, took me forever to find the driver, contacted the support centre who told me I had to pay $25 just to get it on CD
Finally found it by doing a 'round-a-bout' search
http://www.panasonic.co.uk
navigate to support and downloads then type in "NVMX" and select 'software driver' scroll down the page till you come to NVMX50. Should be two downloads there, one the driver the other the audio update.
After installing this on my new dell pc, it was able to identify the camera and webcam... HOWEVER although I can get webcam to work via messenger, my mic is no longer working??? even after the audio update so go figure??? I use to be able to use the mic on skype before downloading this... what a pain
Posted on Mar 03, 2009
No memory card for the Panasonic NV-GS10 camcorder...
The NV-GS10 uses MiniDV tapes. You should be able to buy these at just about any camera, department, or electronics store.
Feb 19, 2012 | Panasonic NV-GS10 Mini DV Digital...
When I use different SD cards it says Card Error or Incorrect Operation? Tried to format or delet the files of the card but couldn't. It's a cam recorder nv-gs50
Check with the instruction manual for the camcorder which type and capacity SD cards it will "support" and use only the specified cards. The camera will reject any card with a greater Gb capacity than it's system can support.
The more recent your camera the greater card memory capacity will be supported.
Sep 20, 2011 | Panasonic NV-GS50 Mini DV Digital...
Do all video camera called "mini DV" use cassette tape to record? If so what is the memory cards on some models for?
no the cassette tape style mini s are now superceded, all the newer models use CF or SD card storage and many can accept cards up to 16Gb
Please rate my help++++Thanks for using FIXYA
May 08, 2010 | Panasonic NV-GS25 Mini DV Digital...
Can you record video to the SD card on the Panasonic NV-GS25?
Yes very easy with a razor sharp knife you will need to cut it in middle.
When you did that you will have this [ ] [ ] if you put in the right part you will record video to sd card and the left side will put pictures on sd card , when ur done just put them together with some tape again and same thing next time
May 08, 2009 | Panasonic NV-GS25 Mini DV Digital...
Removing fade out .
Go to the Tape mode. Press and hold the joystick untill a small menu-thingy comes up. Go left with the joystick, and voilà, problem solved.
Mar 03, 2009 | Panasonic NV-GS17 Mini DV Digital...
Not recording on tape
Take out SD card from camera and try torecord.
Jul 23, 2008 | Panasonic NV-GS55 Mini DV Digital...
Problem with Panasonic NV-GS3 camcorder
use cleaning cassette , before a brand new blank tape ( may have a worn or damaged tape in your library ) ;
Jul 29, 2007 | Panasonic NV-GS17 Mini DV Digital...
Panasonic Nv-GS3
I have the same problem, i was just using my camcorder and when i changed the tape, it says incompatble tape and now it wont play or record at all. It has happened to me today.My friend told me to leave for a while and try again. Hi C8dee, is your camcorder working, any updates, did you find a solution. jinn666@hotmail.com
Mar 30, 2007 | Panasonic NV-GS3B Mini DV Digital...
Panasonic NV-GS21EG-S Mini DV Digital Camcorder Logo
81 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
