Is there any way one can check the suds level without automatically adding more water to the load? As soon as I open the door to check the suds and then either add more detergent or see that the level is OK, and then shut the door, it adds more water. Any way to bypass this action? I bought my washer 3 weeks ago and did not realize this is a feature. Guess I didn't do my homework. Thanks.
  • Barrett Palumbo
    Barrett Palumbo Jan 02, 2011
    Sorry to read about your issues.
    But you really need to give us the make and model, of your unit. It kinda helps us to help you.
  • s_young4 Jan 03, 2011
    My machine is a Whirlpool, model WTW57ESVW1.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Depending on your machine, the type of load, and the size of your load will determine how much soap to use. What is the make and model number of your machine?
Posted on Jan 02, 2011
  • Richard Roth
    Richard Roth Jan 03, 2011
    On your model the washer should not be adding more water to the wash if you open the lid. Check to make sure that your waste pipe is at least 42" from the floor. Having the drain hose lower than the water level in the machine will allow the water to siphon off of the load. Then, when you open the lid and stop the machine, it will see that the water level is lower than the original setting and proceed to fill again.
5d error on front loader samsung washing machine.
The 5d (Sd) error indicates that the washer is not draining properly. It could be that the washer detected too much soap suds. This can happen with non-HE detergent or using too much detergent. It can also happen if there is a clog in the pump filter or something blocking the impeller in the pump. The drain hose could also be clogged.
Do you see a lot of suds in the tub of the washer? Use less detergent in the future. After you get this load washed, try running the washer through a cycle without any laundry and without adding any detergent.
To check the pump and pump filter, you will need to open an access panel. This location will depend on your particular Samsung washer model. Have a bucket ready to catch the water after you disconnect the hose. Remove any foreign objects from the filter and pump area. Check your discharge hose and pipe for any clogs.
If you do not see any suds and the error occurs in the rinse cycle when no detergent was used, then the foam sensor may be faulty. If the 5d error happens as soon as the washer starts to fill, the water level sensor (a pressure switch) could be faulty. In some cases, the main control board could be faulty when the 5d error occurs when the machine is run without any garments or detergent.
Please add a comment with the model number of the Samsung washer and the amount of suds seen in the tub for further assistance. I hope this helps.
Mar 09, 2018 | Samsung Washing Machines
How do I fix a washing machine that doesn't fill with water, but spins and drains? Water enters the detergent holder, but doesn't seem to make it to the tub. Draining can be heard as well, even though
Hum for one a front load H.E washer should not be having very much suds as u claim it had. Are u aware the front loads are made to use very little soap and if u use to much soap hence alot of suds, ur SUDS SENSOR will act up and can shut down any wash cycle. a trick is to run just water and some vinagar trough a couple loads if u can get to wash at all. Another issue u may have is a plugged line somewhere. or loose unconnected water hose line hence the water on the ground effect. u may want to check ur flow line from the entry into the tub where the water at the moment I cant recall the name of the gadget but it can get clogged or damaged and hinder the water from entering the tub
Jan 15, 2015 | Kenmore Washing Machines
SUDsamsung washer error codes
• dc--Unbalanced load preventing washer from spinning
• dL--Door is in locked when washer is running
• dS(d5)--Door is open when washer is open
• FL--Washer failed to lock the door
• Hr--Water temperature control problem(Heat control problem)
• LE--Washer tried to fill but has not reached proper water level(Slow fill)
• LO--Door will not unlock
• E3--Motor not running properly
• nd--Washer is not draining/Washer senses a brief restriction while draining
• nF--Washer tried to fill but was unsuccessful
• Sr(5r)--Problem with control
• PF--Power failure, electric service was lost while washer running
• OE--Fault detected in water level sensor
• E2--Jammed key
• bE--Motor speed sensor problem
• tE--Temperature sensor problem
• 3E--High current detected
• 2E--High/low voltage detected
• 8E--Vibration sensor problem
• 7E--Silver Care control problem
• SUdS--Too much suds detected during wash cycle, unit on hold until suds reduced
Nov 12, 2013 | Washing Machines
Dirty whites
probably your soap, or there is a soap contamination issue......run the machine without adding any clothing to it and see if it suds up or not....I'm suspecting you'll get suds...a little to a lot......if I'm right, then turn it to hot, and add a half gallon of white vinegar to it and let it cycle thru....repeat that for one more cycle...then test the machine one more time for suds without adding any cloths or products to the wash......if the suds are gone or just reduced, then keep repeating til the water runs clear
and to clean the dirty whites, try washing in cold water first, then hot..and obviously the whites with just whites, no colors allowed.
once you clear up the extra suds, try CHARLIES SOAP....it workd great and helps keep the machine clean
Apr 22, 2012 | Zanussi F1245W Front Load Washer
What does SUD mean?
SUD means a detection of suds in the machine. These machines are very sensitive to over sudsing. Try adding just plain water or bleach to break down the suds level. They say to use 1/4 of the detergent you would use in an older machine.
If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle finish
If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Jul 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our Whirpool duet washer will not spin, gives us the SUDS and F02 message and now the door is locked.....suggestionss?
k now the washer beleives that it is full of water.
pour about 3/4 cup of veg oil in the dispenser. and start the unit.. this will get rid of the suds error.
F02 means long fill.. and the water level has not satisfied the computer for 40 secs. check water connections. making sure they are fully open.
to open the door if it does not unlock, in the dispenser there should be an ODD colored line, five that a tug and the door will pop open
Oct 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water level too low. clother wet. No water visible or suds. What is wrong.
Your expectations are based on top load washers.
Front load washers use only a very little water, and suds are an enemy. (HE soaps are designed to clean without suds. Suds are really for show and cause drag on the wash tub during spin.) If you start a load with no clothes, you will see that the water level never gets above a couple inches in the tub. That is the correct water level for front loading machines. PS. Because of the low water use, make sure you use very little soap. (one to two tablespoons per load only!)
Aug 12, 2009 | Frigidaire Affinity ATF7000E Front Load...
Duet Washer will not spin water out
Hello, The most common cause of the 'sud' alarm is too much detergent, or the detergent that is being used is creating too much suds. It works and alarms off of the motor current draw. The causes and cures listed below are pretty much in order of their commonality; try the first item before the second one, etc. If you can pin the fault on the detergent, try using the least amount of detergent that you can while still getting your clothes clean. With a HE washer, more isn't always better. Read on:
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If “Sud” is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
• Check the drain hose and make sure it is not plugged or kinked
• Check / Clean Drain Pump Filter of foreign objects
• Check Drain Pump
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
• Check the Pressure Switch
• Check CCU
Replace failed component.
Hope that this helps. Try the empty loads first to clear the detergent. This is the easiest fix.
Best regards, --W/D--
Jul 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Used wrong detergent, now machine is overflowing water out the detergent door? What do I need to do?
If you have too much suds in your washer, get some phyzeme capsules from a drug store (for stomach gas) and cut at least four of them open and squeeze the contents into your washer. (you can put it in the soap dispenser and rinse a little water in, or open the door and ad it directly) Now mix them in by continuing to run the wash cycle, or moving the wash drum by hand. This will knock down the suds.
May 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Will not do anything
You need to drain the machine manually. Drop the drain hose to a level that is lower than the drain pump and the water will syphon out. Once all the water is out you can open the door. Remove the washing and then close the door and start a rinse cycle. While the machine is taking water, open the dispenser and pour half a cup of milk in with the water. This will neutralise the suds. Once all the suds are gone the washer will be ok.
Oct 29, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
