Question about Wine Enthusiast 2720229 Wine Cooler Refrigerator
My wine cooler keeps shutting off What could cause this?
Why does my wine cooler run too cold?
If after adjusting your thermostat to desired temp and is still cooling. The thermostat is bad or your relay is bad
If you disconnect the thermostat and the compressor stops it most likely a bad thermostat
If you disconnect the relay from
The thermostat and it stay running it is the relay. It is sticking
If possible store you wine somewhere else and shut the unit down and unplug for 10 to 20 minutes this may cause some melt of condensation some water may be on the floor if is to cold
This may also reset the system.
Jul 26, 2015 | Marvel 61WC Wine Cooler
Why would I need a single zone wine cooler?
The single zone wine coolers is advised when you want to keep only one type of wine, red wine or white wine, since they don't have the same optimal storage temperature (and you only have one chamber.
Aug 14, 2012 | Furniture
Why would I need a dual zone wine cooler?
The dual zone wine cooler style is ideal for keeping both reds and white wine without having to restore them in two different wine coolers.
Other than temperature, is there any other reason not to store wines in a regular fridge? I don't mind my wines being slightly cooler and I can always leave them on the counter for 10 minutes bef
Aside from temperature, humidity is a major concern. The low humidity levels can cause the cork to dry/shrink allowing room for both air and other food odors to enter the bottle and tamper with the quality of the wine inside. Wine coolers offer an optimal humidity level of 50-80% needed to keep your wine in good condition.
Jul 31, 2012 | Furniture
Ice build-up on GE ZDW24A wine cooler cooling coil
Probably the thermostat is bad , you can bypass it by putting together the two wires from the thermostat and if the unit starts working ,replace the thermostat ;only do this if you havesome knowledge of electrical work and be very carefull.
Nov 04, 2009 | GE ZDW24A Wine Cooler
Vinotemp VT-60 Condenser won't shut off, unit running way too cold
It might be a sensor or control board problem. Any appliance repair place should be able to help you out with this. Or you can try contacting the manufacturer directly for help or if you need to purchase replacement parts. Otherwise, my cheapest suggestion would be to hook the cooler up to a timer, so you can turn the unit on and off maybe every 20 minutes or so. That should help keep it from causing more harm and then you can monitor the temperature with a thermometer. Hope that helps!
Aug 29, 2008 | VinoTemp (VT60GNV) Wine Cooler
Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Jan 20, 2008 | Haier BC112G Wine Cooler
Haier BC112G Wine Cooler Beeping and overcooling
That thing that's beeping...it is the circuit board. It is telling you that it wants a new cousin to live in your house. Replace it.
Oct 28, 2007 | Haier BC112G Wine Cooler
Wine Enthusiast 2720229 Wine Cooler Refrigerator Logo
Top Wine Enthusiast Refrigerators Experts
zappal
ray gallant
Are you a Wine Enthusiast Refrigerator Expert? Answer questions, earn points and help others
