Got a samsung 520gb sata hard drive. My ECS PM800 M2 Board does not see that sata drive at all. No problem with the IDE 200gb hard drive. It boots up fine. I have already updated my BIOS, but seems to me that VIA Raid need to be uodated as well. Please could u help me or point me in the right direction. Tks
    Genius:
  • 1,267 Answers
Can't get ECS PM800-M2 to boot to SATA drive.
You need to make sure that your SATA drive has an Operating system on it. It can't boot if it only has a data drive.
Feb 19, 2013 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
I can't install a 500gb western digital sata drive to my vpm800-m2 motherboard it won't read the drive
When you install the drive, go to "Computer" or "my computer" and right-click on the icon.
From the dropdown menu, choose "manage".
Click on Disk Management. You will see your C: drive there and it will tell you what it is.
You will probably also see the new drive, but it will appear as unknown. You can right-click on it to initialize it and format it if it is not formatted.
There you go.
May 09, 2011 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
My mp800-m2 motherboard doesn't want to enter the boot with using sata dvd reader i wanna change the system help me please
First, check the boot drives to make sure that the computer is not trying to boot from a different drive to the one that contains Windows.
Check that there are no CDs or DVDs 3 1/2 inch floppy discs
in the CD/DVD,3.1/2 floppydrives.
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 21, 2011 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
I can detect no SATA' HDD
The ECS PM800-M2 only supports SATA 1.0 hard drives. If you are using a newer SATA 3.0 hard drive, there is a jumper on the hard drive which has to be set to SATA 1.0 in order for the VIA 8237R chipset southbridge (which Is on your ECS PM800-M2) to recognize the newer SATA 3.0 hard drives. This Is applicable to all motherboards with the Viatech PM800 / 8237R chipsets. Note: the location for the SATA 1.0 / 3.0 jumper varies on each brand of hard drives. Also check If SATA Is enabled In the BIOS and select IDE mode.
Apr 23, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
945GCT-M/1333 recognize Primary IDE Master as IDE 3 Master
Hello. Some motherboards set SATA1 as IDE primary master, for compatibility. Try connect the DVD RW to SATA2 or SATA3 Port.
Feb 26, 2009 | Computers & Internet
PM800-M2 Restarting
reformat means that you have to install an fresh copy of your operating system to the hard drive. if you do have a cd of your windows installer like windows xp, just put it in your cd drive and restart your computer and boot from that cd. be sure to erase the partition that has your corrupt operating system installed ok to replace it with the new xp that your going to install...
that wasn't to hard was it?
Apr 30, 2008 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
New board will not install com ports 1 & 2 and lpt1 printer port & floppy dr A
what you should have done was uninstalled the old motherboard drivers first as these drivers will be running the board although incorrectly, if you still have the installation disc run it as if to install, but it should show up with the option to uninstall the drivers.
Sep 26, 2007 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
