Pc virus when we do show hidden files from folder option it will not after formating p.c. it is ain same position
    Sergeant:
  • 233 Answers
Download this it will do it
http://en.sergiwa.com/modules/mydownloads/visit.php?cid=2&lid=1
Posted on Jul 09, 2008
My pendrive is working,but some folders are not showing the files.I checked in another pc , it is opening in that. what should i do?
I think it could be due to virus activity. Some virus make the contents of the drive hidden, thats why user can't see the files.
It is suggested that go to FOLDER OPTIONS - and select SHOW HIDDEN FILES. It may show the hidden files. Otherwise, from the system you can see your data, copy all the required files/data. Select the required files and righ-click and change the properties of the file by un-checking the hidden attribute. After copying data and ensuring that the data is on hard drive just format pen drive. Also, make sure that you have a good antivirus installed and its updated.
Let me know if any further clarification is required. Hope this helps! Dont forget to rate the solution!!
CreativeTECH
Feb 14, 2011 | Computers & Internet
Tip
How to check whether a virus has effected a PC
Most common type of virus disable the windows capability to show hidden files. To check whether the computer does not have virus , goto My Computer > Tools (Tab) > Folder Options > View >
Select "Show Hidden Files and Folders"
Click apply and ok
Again repeat the same procedure and check whether the selected "Show hidden files and folders" is still active or its been return to the "Don't show hidden files and folders".
If its still active then it means virus has not effected the system of at least you could delete the hidden virus files.
If it automatically return to the "Don't show...", virus has effected you system. Then go for a good anti-virus software.
on Dec 07, 2009 | Computers & Internet
File can't be copy over 5gb in 8gb king stone pen drive .plz help me
First make a backup of you data in pen drive.
It could be due to virus activity, which hides files and folders on pen drive. Goto TOOLS, FOLDER OPTION and choose SHOW HIDDEN FILES.
It would show any hidden files.
After having the data backup you can format the pendrive and hopefully you would be able to utilize your drive to its max capacity.
Hope this helps!
CreativeTECH
Nov 14, 2010 | Computers & Internet
When i put a usb in my computer it hides the folders and files. But when i look at the usb properties it has the memory of the hidden files. When i tried it in other computers it already has virus.
Could you please explain what you are trying to do?
Are you trying to reveal the hidden files on a USB device or are you trying to remove a virus?
-Revealing hidden files and folders-
1. Open the drive you are wanting to view the hidden files and folders in.
2. Click Tools on your menu bar and select "Folder Options" (If you cannot see your menu bar, you may need to press "alt" on your keyboard.
3. A box will popup, select the "View" tab on top and look down the list of tickboxes, you should come across one that says "Show hidden files and folders", select it. Click apply and ok.
(To view system hidden files and folders, untick the option: "Hide protected operating system files", it is not recommended to have this unticked.)
If it's a virus, I suggest you run a scan on a up to date Virus scanner, once threats have been removed. I would also recommend formatting the drive (once you have backed up any neccessary data).
~ David
Nov 04, 2010 | Office Equipment & Supplies
All folder has been corrupted, folder data not showing
It may be due to Virus.....So Scan your phone and connect it to you PC and enable hidden file and folders show....You will be able to see your folers and file in PC ...... Now go to the properties of any hidden file and uncheck hidden option... Remove all the viruses if any..correctly... Your phone will be normal..
Oct 18, 2010 | Samsung B3410 Cell Phone
Folder Option
show Hidden Files option is missing from folder option...
In windows explorer, when i go to "Tools" , "Folder Option" and click on the Tab "View" and under the "Hidden Files and Folders" it only shows "Do not show hidden files and folder" . The option for Show hidden files is missing
Before the fix
This is caused by viruses ...
To fix this issue follow below steps..
1) open notepad.
2) copy below text and paste in notepad.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\Hidden]
"Text"="@shell32.dll,-30499"
"Type"="group"
"Bitmap"=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,\
00,25,00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,53,00,\
48,00,45,00,4c,00,4c,00,33,00,32,00,2e,00,64,00,6c,00,6c,00,2c,00,34,00,00,\
00
"HelpID"="shell.hlp#51131"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\Hidden\NOHIDDEN]
"RegPath"="Software\\Microsoft\\Windows\\CurrentVersion\\Explorer\\Advanced"
"Text"="@shell32.dll,-30501"
"Type"="radio"
"CheckedValue"=dword:00000002
"ValueName"="Hidden"
"DefaultValue"=dword:00000002
"HKeyRoot"=dword:80000001
"HelpID"="shell.hlp#51104"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\Hidden\SHOWALL]
"Text"="@shell32.dll,-30500"
"Type"="radio"
"CheckedValue"=dword:00000001
"HelpID"="shell.hlp#51105"
3) Save as fix.reg ( make sure to give the extention as fix.reg
4) Double click on this file and click yes when prompted.
5) Issue is fixed now. see the prof below.
-- Let me know if still issues, will glad to help you.
Thanks.
Subhash Chandra.
Jul 08, 2009 | Acer Aspire One PC Notebook
Hidden files and folder not show.
Most likely, you either have a virus or a domain policy restricting the viewing of hidden files.
Here's an easy fix:
1) Go to Start>Run
2) Type "regedit" and click "OK"
3) Expand to HK_CURRENT_USER>Software>Microsoft>Windows>CurrentVersion>Explorer>Advanced
4) Select the value on the right named "Hidden". Right-click and "Modify".
5) On most virus/policy restricted computers, it will have a value of 2, which it shouldn't because it should only be 0 or 1. Change the value to "1" and click "OK".
6) Refresh whatever window you were working in, and it should show you all the hidden files. It will show for all your windows after that until you go to options to change it.
Dec 13, 2008 | Computers & Internet
Show hidden folder problem radio button not selecting
Go to http://www.spybot.net "just copy paste link in your browser"
download it get the up dates and run it in safe mode F8 on start up .that will put ya in 16bit mode.after you run it it will show you thoes folders .DUMP NORTON>if you wish.i dont like it myself.this is a great program trusted by many.give it a run see what ya think. thanxs for useing FIXYA.COM
Feb 23, 2008 | Microsoft Windows XP Professional for PC
Not displaying all files while connected as a USb
Your MP3 player is virused. clean virus then and in your pc done : tools-Folder option -view-(mark)show hidden files.. and (unmark) hide extension ... , hide protected... so change hidden folders in your MP3 player
Dec 17, 2007 | Samsung YP-U2X Digital Media Player
Computers & Internet Logo
David Payne
David Payne
