Need to know where to hook speakers to hard drive
  • 23 Answers
On the back of your PC there is a plug-in with a green circle around it. plug it in there
Posted on Jul 09, 2008
Marware mini speakers only work when connected to hard drive
Use an AC Usb charger.
Find out how to reset the speakers.
And it's computer, not hard drive.
Apr 22, 2014 | MarWare UpSurge Mini Speakers
I don't know if it is the speakers or the marantz 2270. But when I turn the volume up I get poping sounds threw the speakers. At low volume it's fine. Do I have something hook up wrong?
First you need to make sure the speakers are hooked up in phase. +from the amp to + on the speaker. Left and right the same. If the speakers are more than 5 years old you need to check the foam suround if it is cracked or disintegrataed. Having them refoamed could solve the problem. You also need to look around the dust cap if you see a stress ring in the cone then the speakers have been lpushed too hard and need to be reconed or replaced.
Feb 11, 2011 | Audio Players & Recorders
TRANSCENT STOREJET 320GB HARD DISK NOT WORKING, BUT PC DETECTS AS some usb drive ,FOLDER path /directories are not opening
Hello there i am very good with hard drives and fixing hard drives but i need to know when you hook this hard drive up to the USP port and the computer detects the USP driver have you tried opening up my computer and opening the drive it self?
let me know
Jan 23, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Stereo Wiring Colours
2006 Ford Focus Car Stereo Wire Color Codes
Car Radio Battery Constant 12v+ Wire: Yellow/Green
Car Radio Accessory Switched 12v+ Wire: Orange/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Gray/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Green
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): White
Right Rear Speaker Negative Wire (-): Gray
Jul 11, 2010 | 2006 Ford Focus
Can't get speakers to speak
change the defualt playback device to internal speakers. the option is available in the sound properties under playback
Jan 08, 2010 | Dell A215 Computer Speakers
Wiring
To hook up speaker's, is not that hard to do.
there are two wire's for speakers, one is the earth and the other is positive.
You will be able to tell by, one of the wire's will have two colors that will be the earth.
hook the wire's up to your speakers, it will not matter if you get them wrong.
you will not blow them, the speaker might be a bit low just swap the wire around.
do this to the other speaker and you will be fine!
Good luck!!!!
Jul 28, 2009 | 1991 Mazda 323
Need diagram of how to hook up my western digitial sata harddrive to mother board a asus a7n8x-e deluxe
this motherboard does not support your new Hard Drive. SATA is a connection type required for your hard drive. Your motherboard supports IDE connector. You probably can get a pci card that allows you to attach the hard drive.
May 24, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Green cable connects to hard drive but not to monitor
connect the separate speakers to cpu slot provided and adjust the sound with utility
Mar 21, 2009 | Audio Players & Recorders
Speakers don't work. Used Dell Dimension 4550 with no setup guide. Don't know if speakers need power source or just plug into hard drive. Volume control is on. Louis
depending on the speakers--if battery powered or powerpack--they need a driver to work--
you can do a hardware check to see if the speakers are found.
The speakers are NOT plugged into the hard drive..the are plugged into a LPT port that is plugged into the motherboard. The hard drive is the main unit that stores all the windows operational system functions, and software you install on it. This can not happen IF there is no motherboard that has the critical information to tell the hard drive to accept the information and where to send that information through the CPU (central prosessing unit). The drivers are the programs that make your speakers, printers, and any other hardware you add work. Now before the speakers can work the motherboard need a sound card and the driver to make that operational. So the sound card needs to be checked too. go to the dell web site for the drivers for the sound card if needed. www.dell.com
you also have a setting comtrol for your volume too. make sure the volume is turned on.
Oct 13, 2008 | Computers & Internet
I would like to know how to hook up rca cord into a factory radio, so I can hook up my sub and amp without changing the deck. Is there a relay I need?..... thanks for your time........ Corey
Not a relay, but a line level converter. You can get one at any place that installs car radios. You tap off your speaker wires and it brings the level down to the proper level for input to an amplifier. It has no appreciable drain on your speaker output so you would not even notice any drop in volume from the radio to the speakers it drives.
Let me know if you need any more help, and a FixYa! rating would be appreciated.
Thanks,
Dave
Jul 13, 2008 | RCA Car Audio & Video
Computers & Internet Logo
David Payne
David Payne
