Question about Dishwashers
Diswasher is not draining. The bottom is full of water. What is the problem, how do I correct it?
  • 24 Answers
Always when posting make and model are very helpful. most likely there is something blocking the drain ports on the basin. the most common article would be the clear wrap of a tv dinner.. or something like that .. or a paper that was surrounding a can or bottle that you put thru your dishwasher cycle. most often it is reocmmended not to wash your recycling in the dishwasher as this is a common problem that can ruin your machine. is it new ? is this the first time using it? who installed it. would be my next questions and if it is any of the above then chances are someone didnt uncap and port for drainage... if you have used it before and now all of the sudden it is blocked then it is something like a paper or clear plastic blocking your drain ports at the base in the middle of the dishwasher you will see a grate with holes if they are blocked it will not drain.
Posted on Jan 02, 2011
Diswasher water isn't draining?
It is most likely the drain pump. If the drain pump passes a tech's test ok, have the drain passage checked for clogs.
Apr 17, 2012 | Dishwashers
The water is not draining at the end of the dry cycle. White dirty water pools in the bottom of the diswasher.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Feb 02, 2011 | Dishwashers
Fridgeadare FDB510LCS5-My diswasher does not appear to be draining. The bottom of the diswasher is full of water.
there is only a few things this could be caused by
if it is not obvious like a clear plastic wrap covering the drain ports on the base insdie teh dish washer then it will have to be one of the following:
check these:
1. Drain line/air gap
2. Pump
3. Drain valve and/or solenoid
4. Belt
5. Motor
6. Timer it is highly not likely to be the timer..
GL
Jan 02, 2011 | Dishwashers
The bottom of the diswasher is full of water after the cycle
Since the drain pump will pump the water out using the "cancel/drain" button, if it did not work then your problem is likely to be in the drain hose system or the garbage disposal downstream from the drain pump. Check for kinks in clogs in the drain hose. Grease can build up in the portion of the drain hose just before it attaches to the garbage disposal.
Oct 01, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
My diswasher does not drain.
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 08, 2010 | Whirlpool DU960PW Dishwasher
Diswasher has water standing at the bottom after the dishes are clean
Some water can be normal. If it is too much the drain line is clogged or the drain tubing may be too low going into the drain under the sink. Raise the tubing to 30 inches before it drops down and goes into the sink drain. Read the install manual.
Aug 26, 2009 | Dishwashers
Water won't drain after cycle is done. Leaves 1-2 inches of water in bottom. Checked hose and its clear. Put hose going to disposal in bucket and water comes out when diswasher is cycling
it is easy track this path of water from bottom of m/c it will b afilter then small hoses to drain pump thenouter hoses <
thanks
Jul 13, 2009 | Dishwashers
Water not draining from dishwasher
1.attache the drain hose to the bottom of contertop.
2. drain back valve is not work properly.
Dec 20, 2008 | Whirlpool Dishwashers
Diswasher
Check the float switch. If it is stuck the machine will start but no water will be allowed in and the pump will turn on to drain the non existant water. This happens often when a small item gets under the float preventing it from allowing the water valve to open. Find the float in the bottom of your machine and make sure it moves freely.
Jan 15, 2008 | Whirlpool 24 in. ADP6940 Dishwasher
Dishwashers Logo
98 people viewed this question
Top Dishwashers Experts
