posted by jodomellie on Jul 09, 2008
when spining it makes a gravel noise like there is dirt under the agatator and when the cycle has finished all bits of hard dirt have come out into the wash.How do l remove the agatator to clean under it? thankyou
Best Solution
posted on Jul 09, 2008
What type washer do you have? make? model?
Some agitator pull off, some are screwed down, some are bolted down, the bolts would be under the cap or fabric dispenser.
Rating Locked! (?) jodomellie has rated this solution as Helpful
This Problem Also Relates To:
GE WSXH208A Front Load Washer
GE WHRE5260E Top Load Washer
Bosch 3.81 cu ft Nexxt 500 Plus Series Washer - WFMC530 1UC / SUC / CUC / WFMC530CUC - Champagne Du
Bosch Classixx WVF 2402 Front Load All-in-One Washer / Dryer
GE WDSR2080D Top Load Washer
Bosch Axxis WFL 2060 Front Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer
Can you Help with these Washing Machines problems?
Maytag Laundry Neptune Front-Load Washer-...
maytag mah4000aww washer
washer was leaking from the... Answer This...
Maytag Neptune Front Loading Washer w/Built...
washer wont spin
washer wont spin
mid 90's maytag top loader,... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
