Question about AEG Refrigerators
AEG SANTO mod 4088 type KS20047 Fridge/freezer Fridge part has ice on the middle of the back wall. Temp.part on fridge does not respond to settings. Freezerpart ok. What do I do to get the ice on back off and set the temp . Orange and green light works, apparently?? Jan 3rd 2011. Greetings from helga@kjole.com
KikkaMikko
SOURCE: AEG Santo Fridge light flashing
Here is fix photos:
http://www.elisanet.fi/mtj/santo/AEG-Santo-fix.html
Posted on Aug 11, 2008
  • 1462 Answers
SOURCE: I have an electrolux Aeg
remove back plate inside freezer. there is a drain tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely. check drain tray heater is ok as well
Posted on Oct 08, 2008
  • 1122 Answers
SOURCE: can I buy spare shelves
MAYBE,GO TO SEARS .COM CLICK ON PARTS PUT IN YOUR MODEL NUMBER AND SEE IF THEY HAVE YOUR PART,ALSO TRY REPAIR CLINIC.COM-MIKE
Posted on Dec 06, 2008
electrodynam
  • 35 Answers
SOURCE: AEG Santo fridge not cooling but freezer is working.
The compressor is obviously still good or the freezer wouldn't work.I'm sure you checked the settings,but turn the freezer all the way up (hot)after it is cool so the unit doesn't come on for the freezer,then turn the refrigerator controls all the way down to the coolest setting.listen for the compressor to start,and/or the fans to run.If the compressor starts,and no fan there may be a problem with the fan.(this is a general test I'm not familiar with your specific unit which may not have a fan,but most newer units do).If the compressor doesn't start after a short time the thermostat/control for the refrigerator section is broken,and needs replaced.
Posted on Mar 16, 2009
SOURCE: AEG Santo 1683-TK7 Led's and
as rwsummers correctly points out replace this part as from uk i bought it from maplins £3.31 part no N74CN 1UF 275V de-solder the two points on rear of pcb and re-solder new part in place and reassemble turn on power and "voila" works like new. Thanks.
Posted on Apr 10, 2010
Aeg santo fridge keeps freezing
Fixya will not let me post links today, or their "capcha" thing does not seem to be working properly, so I will have to try this another way.
I've done some research on your issue and it seems that should only happen if the temperature sensor goes bad, or the evaporator sensor. Each of the two parts cost less than 30 pounds each, so may be less expensive than tossing out the whole thing.
Try browsing to shop (dot) aeg (dot) co (dot) uk
Then in the search at the top right, type in "santo" and look for the two sensors and decide if it would be worth a try.
Oct 14, 2013 | Refrigerators
My AEG Santo freezer is leakin water on the floor every few days. There is also a build up of ice inside the bottom of the freezer, even though we very recently defrosted the freezer. This fridge/freezer...
try pulling out the fridge very slowly, any signs of hard resistance than stop. there should be a main water shut off back there. if still uncomfortable with this you can always shut the main water off to the house before trying. hope this helps.
Feb 22, 2013 | AEG Santo 7085 KG Side by Side...
Fridge freezer not keeping temp
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 11, 2010 | AEG Santo 3888 KG8 Bottom Freezer...
I have an electrolux Aeg santo fridge freezer. Frost free. There seems to be water leaking from the bottom.
Oct 08, 2008 | Electrolux Refrigerators
Aeg fault codes
aeg santo fridge/ freezer
The fridge part of my appliance is not getting cold please help
Apr 13, 2008 | AEG 10.35 cu. ft. / 293 liter Upright...
AEG Santo Fridge 3774-6KA
Check the damper between the fridge and freezer. It may be broken or frozen open. If this happens and you have a water reservoir in the fridge then it could freeze and crack - leak and then flood your house... Shut off the water supply until you get the problem fixed.
Jan 20, 2008 | AEG Santo 7085 KG Side by Side...
AEG SANTO 3790-6 KG
hi i have got a fridgefreezer and it keeps beeping and also inside my fridge is warm but my freezer is ok what could this be
Dec 11, 2007 | AEG Refrigerators
Refrigerators Logo
349 people viewed this question
Top AEG Refrigerators Experts
Oscar Netto
Oscar Netto
ashburton
Jim Goldsmith
Jim Goldsmith
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
