Question about Maytag MDE4806 Electric Dryer
When I press to start, the dryer (Maytag MDE4806AYW) just clicks but does not start. I do have power. We are trying to find the thermal fuse, and are having difficulties locating it.
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Maytag MDE4806AYW - Clicks but does not start
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 12, 2010
Why would my older Maytag Neptune Electric dryer suddenly quit? Interior light comes on when door opened, but when I press start, it shudders but doesn't tumble or start?
if thermal fuse ok you may have a problem with your interface board. Check thermal cut out, door switch and thermal fuse before suspecting board. Obviously need model to give you more accurate info.
Oct 30, 2014 | Maytag Dryers
Matag dryer not heating
Here is a link to maytag dryer repairs http://apcoappliancerepair.wordpress.com/?s=maytag+dryer . The most common problem is the thermal fuse. My question is. Does the heating element start to light. If not...... and you have changed the ignitor and thermal fuse. Then check the flame sensor to see if there is continuity threw it. Power to the gas coils and ignitor runs threw the flame sensor. CLICK HERE to see a flame sensor on a GE dryer. They are the same on most units but Maytag will be on the opposite side of burner chamber.
Apr 30, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Power to outlet dryer dosent run?
hello click this link http://www.youtube.com/user/RepairClinic?v=1obHbwPfw9s&feature=pyv&ad=5644620461&kw=dryer%20thermal%20fuse this is a video on how to replace the thermal fuse in a maytag dryer which is one of the main reasons why a dryer when there is power to the outlet wont run. You can test the fuse by performing a continuity test with a multimeter or if you do not have a mulitmeter you can briefly connect the two wires that go to the fuse and then press the start button. You will also have to jump the door switch as well in order to get the unit to start. You would do this by taking a piece of wire and stripping both ends and connecting from one connection to the other. If you have any further questions or find that the thermal fuse is functioning properly message me back for further diagnosis. And if you do require further diagnosis please message me back the model number of your unit as well. Thanks again
Rick
Sep 24, 2011 | Maytag Dryers
I have a Kenmore Dryer, Model 96292110. It runs, but it does not heat the air. I have checked the circuit breakers. They are fine.
If your Maytag dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers,thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F.
Thankfully, troubleshooting the thermal fuse in a Maytag dryer is easier than it sounds.
Instructions And Things You'll Needed.
  • Screwdriver,Towel,Electrical tape,Replacement thermal fuse, if necessary.
1 Clean out thelint screen in your Maytag clothes dryer. Lint buildup can cause your dryerto overheat, triggering the thermal fuse to disrupt power to your dryer'sheating mechanisms. Take the lint screen out of your Whirlpool dryer and washit in warm water. Dry the screen thoroughly before replacing it.
2 Look behindthe dryer to check its flexible exhaust hose for kinks or obstructions.Disconnect the exhaust hose from the back of your dryer and clean out any lintthat has built up.
3 Go outside andcheck your Maytag dryer's exhaust vent for obstructions. Lint buildup, birdnests or other obstructions in the outside exhaust vent can trigger yourdryer's thermal fuse.
4 Disconnectyour dryer from its power source before attempting to access its thermal fuse.
5 Access the thermal fuse in your Maytag dryer byremoving the back panel. Remove the screws that hold the back panel in placeand it should easily come free.
6 Look betweenthe dryer's blower housing and exhaust to locate its thermal fuse. The thermalfuse in a Whirlpool dryer looks like a white plastic strip that has two wiresconnected to it.
7 Bypass the thermal fuse in your Maytag dryer whileyou perform a quick diagnostic test. Use electrical tape to tape together thetwo wires connected to the thermal fuse. Reassemble your dryer and plug it backin. Set the dryer to a timed heated drying cycle and press "Start."If the dryer produces heat with its thermal fuse bypassed, it means the thermalfuse needs to be replaced.
8 Replace a blown thermal fuse in your Maytag dryer.Disconnect the power and remove the back panel. Remove the electrical tape thatyou used to perform the diagnostic test and disconnect the wires from thethermal fuse. Remove the screws that secure the thermal fuse to the dryer anddiscard the blown fuse. Attach the replacement thermal fuse by replacing andtightening the screws. Attach the wires to the new thermal fuse.
Thanks for using fixya.
Jul 31, 2011 | Kenmore Dryers
Gas dryer will not heat up. Flame ignites on occasion. Changed the ingnitor but still has the same problem
Hello.
If your Maytag dryer has mysteriously stopped producingheat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers,thermal fuses are safety switches that are designed to disrupt the flow ofelectricity to your dryer's heating mechanisms once the dryer reaches apredetermined maximum temperature, usually somewhere around 180 degrees F.Thankfully, troubleshooting the thermal fuse in a Maytag dryer is easierthan it sounds. Instructions And Things You'll Need
  • Screwdriver
  • Towel
  • Electrical tape
  • Replacement thermal fuse, if necessary
Jul 31, 2011 | Maytag Dryers
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
heatman101
May 12, 2010 | Maytag MDE4806 Electric Dryer
My Maytag dryer (model # MDE4806AYW) makes a grinding sound all of the sudden. Sounds like the cylinder drum is scraping on something. The dryer is only a couple of years old. What do you think needs to be...
Could be your front glides on your drum housing. They are just Teflon pads that the front of the drum rides on. If they wear down you will get a metal on metal rubbing. The part number is 40116501. The other possibility could be your rear rollers going bad but they usually will make almost a squeak usually. They are what support the rear end of the drum.
Hope this helps _MJ_
Jan 29, 2010 | Maytag Dryers
No heat no start from my maytag neptune dryer
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Aug 01, 2009 | Maytag MED6300TQ Electric Dryer
My Maytag dryer won't start when I hit the start button
My dryer light comes on for my Maytag SDE4606AYW dryer when you open the door and I can hear the timer clicking but when I hit start the motor doesn't even attempt to start but there is obviously power. My dad just installed a new power cord to the dryer but this is a seperate issue as we were obviously unable to check the motor before we got a cord for it. He has years of electrical experience so I'm assuming he connected the new cord right. Any ideas on fuses in the dryer or why it may not be getting power?
Jan 15, 2008 | Maytag PYE2300AY Electric Dryer
Maytag MDE4806 Electric Dryer Logo
175 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
