Question about HP Pavilion dv4155cl (EC321UA) PC Notebook
Touchpad As I type, sometimes I touch the finger pad and the cursor jumps all over the place. How do i disable the finger pad?
  • Anonymous Mar 30, 2009
    How do I do this on a dell?
    Novelist:
    Scholar:
  • 96 Answers
You can go to the Control Panel (Select the start button and then either "Control Panel" or "Settings" and then "Control panel") and double click the Mouse properties icon.
Then you can select the "Device Select" tab and check the box marked "Disable Touch Pad when USB Pointing Device is present."
That is also where you can permantly disable the touch pad by simply selecting "Disable Device" and "Disable Button"
Hope that helps.
Posted on Jul 09, 2008
Jumping cursor
Open touchpad properties, touchpad settings section, enable Touchcheck, set the slider to minimum setting Click OK
TouchCheck disabled the touchpad while typing
Jul 10, 2010 | Dell Latitude E4300 Notebook
CURSOR JUMPS OUT OF PLACE ,
Go to the touchpad properties, touchpad settings, Enable TouchCheck, set the slider to the far left (1/2 Second Delay) this will disable the touch pad while typing and enable it 1/2 second after you stop typing
Jun 01, 2010 | Dell Vostro 2510 Laptop
When I tap on the touch pad on a HP Pavilion dv7 cursor jumps
The touchpad is installed on HP notebook PCs.
You can "tap" and "double tap" your touchpad with your finger, and interact with the operating system in exactly the same way as clicking and double clicking on your mouse.
When using touchpad on your notebook PC, the cursor may jump, flicker, or double-click by itself.
Follow the recommendations in that HP document, or "disable" the TouchPad, if you don't like what it does.
May 12, 2010 | Computers & Internet
I have a inspiron 1721 and the cursor jumps all over the place
If the cursor is jumping while typing, then go to the touch pad settings and enable palmcheck or it's equivalent to disable the touchpad while typing
Apr 26, 2010 | Dell Computers & Internet
My cursor jumps back to the beginning when i'm trying to type. i'm constantly having to backspace and correct and reset my cursor. any suggestions?
Disable your touchpad if you consistently have this problem.
When you are typing something, and you suddenly touch the touchpad (tapping this touchpad moves the cursor) then your cursor will suddenly change position which then mess up your typing.
If you don'r have an external mouse connected, better be careful not to touch the touchpad. If you have an external mouse, better disable this touchpad.
Mar 03, 2010 | Compaq Presario 700 470024-192 Notebook
Cursor jumps around
Does the cursor jump around when your hands are nowhere near the touchpad? The touchpads are heat and pressure sensitive. I personally have very warm (and sometimes sweaty) hands. I have this problem often when working on laptops. If I hover my hands over the pad, it causes the mouse to move. I've had to take a business card, put tape on one side of it, and use it as a flip-cover for the touchpad on most of my laptops. If the cursor moves around when you're nowhere near the laptop, then you may want to try disabling the pointing stick (if it has one). I've had several clients with laptops where the pointing stick mouse control go crazy and move and click on things.
May 13, 2009 | Dell Inspiron 1420 Laptop
Acerr Aspire 5315-2940
I don't know if you mean that your cursor suddenly moves as you are typing? If so, it is likely your touch pad is too sensitive. I have a mouse w/mouse pad but never disabled the touch pad. So i disabled the touch pad and it solved it for me. If you want to be sure it is the touch pad being over sensitive, then type a paragraph but keep your fingers and palms far away from the touch pad. If the problem improves, like it did for me, then the touchpad is too sensitive. You can go into the settings for the touchpad to change the sensitivity setting to make it less senstive and see if that works and it does not then press Fn +F7 keys to disable the touchpad.
Aug 26, 2008 | Acer NSK8458AN Keyboard
Cursor jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
  1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
  2. Adjust the sensitivity of the touch pad:.
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
  3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
Aug 14, 2008 | Computers & Internet
Cursor skips lines while typing
My experience: cursor suddenly moving backward when i was typing, or moving somewhere else on the page. I would be typing and text suddenly would get highlighted. I followed someone's advice to disable the touch pad. Since I do have a mouse & key pad that was all i had to do.
HOW TO DISABLE THE TOUCHPAD FOR ACER 3680 AND OTHERS??? PRESS Fn +F7
Yep, it was that simple. At first I made sure i typed without my fingers or palms touching or near the touchpad. I noticed it seemed to stop or happen less. Soon as I disabled the touch pad all is back to normal. Yet I spent hrs trying to find out how and there were all these posts by people suggesting downloads and other more complicated things etc..
May 12, 2007 | Acer NSK8458AN Keyboard
HP Pavilion dv4155cl (EC321UA) PC Notebook Logo
206 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
