My current on-board sound card on my Dell Dimension 3100 is going bad and I purchased a new PCI mounted sound card. How do I disable the on-board card now?
    Guru:
  • 2,178 Answers
Right click "My Computer" and select properties. Select "Device Manager" and select the sound - disable the sound on-board sound card.
Posted on Jan 02, 2011
I have verified that the ethernet 10/100 on my Dell Dimension 3000 is bad, Can I just replace the connection via a PCI card or do i need a new motherboard? Also wehat is the price point of this fix?
A new motherboard is not needed and you can just buy a PCI card. Here is one that will work great and is cheap: http://www.newegg.com/Product/Product.aspx?Item=N82E16833166004. If you wanted to get this fixed you would have to go through dell to get a new motherboard which would probably cost an arm and a leg so you are just better off going with the PCI card.
May 15, 2011 | Dell Dimension 3000 PC Desktop
My dell 3100 desktops sound card is not working. it is integrated. i have ran a diagnostic and it states ther is no sound card installed, it used to work.
Hi! If diagnostic stated that there is no sound detected on it then the motherboard should be replace, because it's integrated .If the system is still in warranty call Dell. If not you can buy a PCI sound card and insert it to your motherboard pci slot. That should do the job. Hope that will help you . GOD Bless
Apr 24, 2011 | Dell Dimension 3100 PC Desktop
I need a new sound card for my Dell Dimension 3000 Where do I go , how much will it cost and how do I install one?
u can purchase from any local store go for creative sound card pci slot if u r in blore call 9972888885
Sep 06, 2010 | Dell Dimension 3000 PC Desktop
I need to install a new ethernet card on my Dell Dimension 9100 computer
Simply, purchase a PCI network card; and install a new one. It's pretty simple and most network cards come with instructions.
Jul 24, 2010 | Dell Dimension 3100 PC Desktop
No sound on my pc
Go to Control Panel, Sounds and Audio Devices
Ensure that sound card is the default playback and default recording device.
Also, if this is a Dimension 5100, then there is a possibility that the system has a upgrade sound card installed in a PCI expansion slot (Below the video card)
If the system has an expansion card, (Soundblaster) then the integrated on-board audio should be disabled in the BIOS (If integrated is on and an expansion card is installed, you get a conflict and no sound) Normally, if the system has an expansion card, the ports are covered with a black plastic cover. If the BIOS defaults are ever reset, then onboard audio needs to be disabled again.
Mar 28, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
How to disable on board sound card in dell dimension 8200
At the boot process press key F2 in order to get into the bios settings. Here you will find "Integrated Devices" select this line with the cursor keys (up and down) and press enter (or spacebar).
On the new panel locate the option "sound". It must be marked as ON state. With the cursor keys (left and right) or + / - change the state at OFF. Press escape to exit from this pane, and escape again to exit the bios. At the prompt panel that appears select "save changes and exit" and press enter. Your Dell is going to reboot now with the internal sound card in disabled state.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"????????? ???????"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 25, 2010 | Dell Dimension 8200 PC Desktop
Inserting GeFroce fx 5200 graphics card!
sorry to say this your dell system only has a X1 vga slot it is not compatible with the card you have.
If you want to use a card you have to go for a new system
Nov 30, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
I have a Dell Dimension 4600, will a PCI Express sound card work in place of the original Sound Blaster 5.1 sound card
Well, the short answer to your question is "No, it won't work". The Dell Dimension 4600 does not have any PCI Express slots in it, therefore you can't install it, and therefore it won't work. But, if you installed a PCI sound card, it would work. The BIOS would recognize the add-on sound card, disable the onboard sound, and your sound will start going through the expansion card instead. Hope this helps.
Jul 18, 2009 | Dell (8H390) Sound Card
Have no sound
hi! here is the answer:
Audio Output
  • Type Sound card - Integrated(Any Audio Card that fits the pci slot
  • Sound output mode 5.1 channel surround
  • Audio output compliant standards AC '97
  • Speaker(s) Desktop
Rate me please.
Apr 02, 2009 | Dell Dimension 4600 PC Desktop
Modem bad on Dell Dimension 2400, Can it be replaced?
Ethernet port or dial up modem?
If it's the built in ethernet port, all you need to do is purchase a PCI ethernet card, disable the one that's built in in the device manager and you're good to go.
Thanks and please take a moment to give this solution a rating of fixya.
Mar 11, 2009 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
