Question about Jabra Bluetooth Car Kit with Night Driving Mode Tripod
Will not pair with my evo - Jabra Bluetooth Car Kit with Night Driving Mode Tripod
Why will it not pair with my evo phone
Posted on Jan 03, 2011
How to pair an aliph jawbone to my phone
turn the bluetooth option on from your evo and make sure that the bluetooth is discoverable and that press & hold down the power button on the jawbone bluetooth till you see lights blinking red & blue or its blinking red only on some jawbones , that check your phone , it should show u a jawbone bluetooth discovered on device than hit connect or pair , enter 4 zeros (0000) to connect & you should be able to use it like a champ , good luck , thank me if i help out on you Question
Feb 02, 2012 | HTC EVO 4G Sprint - /
How to install the headset to my EVO 4g
To pair the Plantronics BackBeat 903 with an EVO 4G:
On the 903 headset:
With the headset powered off, press and hold the "Power/Pairing" button until the LED indicator flashes blue and red. This will put the 903 headset into pairing mode.
Use the iPod Touch menu to search for the headset and select 9xxBackBeat.
(If prompted, enter 0000 for the PIN code/passkey. Some devices also require you to accept the connection. Headset is paired when LED flashes blue.)
On the EVO 4G:
Turn the Bluetooth on from the Home screen, tap Menu, Settings, Wireless & Networks, Bluetooth.
Pair the EVO 4G by going to the Home screen, press Menu, Settings, Wireless & Networks, Bluetooth Settings, Scan for Devices. Follow the on screen prompts to pair the devices.
Good luck from Headsets Direct - 800-914-7996.
Aug 13, 2011 | Plantronics Backbeat 903 Bluetooth...
Does this work with an evo shift 4g (sprint)
Jabt,
The Parrot supports the following bluetooth profiles: Headset Profile HSP 1.1, Hands-free Profile HFP 1.0, Object Push Profile OPP.
Your Evo should be able to pair using either the Headset profile or the Hands-free profile.
Thank you.
Mar 21, 2011 | Parrot MINIKIT Bluetooth Hands-Free Kit...
I've tried sending pictures to other phone but they never go trough
I imagine this is through Bluetooth.
You have to pair the two devices first. It should be under your bluetooth settings > Pair devices.
Once you pair the devices it will ask you for a pin. Insert the same pin on both devuices and they will be paired. You should then be able to send pictures and other files via bluetooth.
Mar 01, 2011 | HTC EVO 4G Smartphone
How do I pair my jawbone icon with HTC evo phone
From your main/home screen :
1. Press your "Menu" button. ( located near the bottom of your phone to the left of your home button )
2. Press the "Settings" button.
3. Press the "Wireless and Networks" button.
4. Check the Bluetooth box to turn on bluetooth.
5. Press the Bluetooth Settings button.
6. Put your Jawbone Icon into discoverable mode. Follow this link for instructions if you cant find your manual.
http://www.headsets.com/headsets/resources/jawbone-pairing-guide.html
7. Click "Scan for Devices" on your EVO.
8. When your Jawbone Icon appears in the Devices list click on it and pair the devices. At this point it will ask you to accept pairing. Once you do that you should be good to use your headset.
Feb 28, 2011 | HTC EVO 4G Smartphone
Downloading pics from htc evo to my computer
Please install / re install your HTC evo pc suite on your computer and paired them using firewire
Feb 05, 2011 | HTC EVO 4G Smartphone
I cant pair my jabra bluetooth to my evo!
First, put the headset into pairing mode. To do this, remove it from the Stone charger and press and hold the answer/end button until the lights flash four times slowly - this indicates that the unit is off. Then, press and hold the answer/end button again - you'll soon start to see lights flash - hold the button until the green light is on steady and the blue light is flashing. This is pairing mode. Now your Evo should be able to "find" the Stone to pair with it from within the Bluetooth menu on the phone.
Jan 20, 2011 | Jabra Stone Bluetooth Headset
How to connect jawbone bluetooth device to htc evo 4g
HOW TO CONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Oct 02, 2010 | HTC EVO 4G Smartphone
Audiomobile evo needing repair
how old is it and why bother? most speakers now are quite cheap, but poor quality. most people will not notice this unless you are an audiophile. my suggestion: throw them out, keep the magnets, they are good to have around. get a new pair or a surplus pair. and, if you really like them, how did they go? if they went by playing your music too loud and you perforated the surrounds or blew the coils.... sorry buddy, your fault.
May 22, 2008 | Audiomobile EVO 2210 S24 Car Speaker
Jabra Bluetooth Car Kit with Night Driving Mode Tripod Logo
146 people viewed this question
Top Jabra Photography Experts
Tony
Are you a Jabra Photography Expert? Answer questions, earn points and help others
