Question about Blanco Plumbing
Single handle faucet has become stiff & squeaks
arealplumber
  • 33 Answers
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Posted on Dec 05, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: price pfister faucet handle drops and turns off.
There is a price pfister little emblem under neath the handle. Use a but knife and pop that off. Once that is off there is a allen bolt in there. Tighten it up, put the emblem back and away you go
Posted on Feb 14, 2009
frcs68
  • 1605 Answers
SOURCE: single handel kitchen faucet: Over time the
shut-off the water, pull the handle and the spout. change the 2 "O"ring and make sure the spout body has no dirt in them. apply some the plumbing grease bewteen the spout body. put everything back.
Posted on Apr 22, 2009
  • 235 Answers
SOURCE: The faucet handle has become stiff to turn off and
The handle has build up in it but should come off eventually. Sounds like a dry o-ring seal. You can purchase a kit for your model without having to replace the whole unit.
Posted on Jul 05, 2009
SOURCE: kitchen faucet single handle pull-out. The base of
I have the same problem with an American Standard Reliant Kitchen Faucet that wont swivel anymore. I called American Standard and they are sending me the replacement parts to fix it free of charge, I have had mine 6-7 years and they said it was under warranty. Call 800-442-1902. Good Luck
Posted on Apr 05, 2010
How do I STOP a squeaky kitchen faucet?
you need to pull the cartridge and put stem grease on the o-ring EVEN THOUGH WATER RUNS THROUGH IT TH RUBBER WILL STILL DRY OUT THE RUBBER IS WHATS MAKING THE SQUEAKING NOISE
Oct 13, 2014 | Moen 7310 Legend Single-Handle Kitchen...
I just installed abrand new single handle delta shower faucet and the water does not get hot enough.
Many single-handle shower mixers have a hot limit, usually limiting the throw of the handle. You could go to the mfg's website (www.deltafaucet.com) & find instructions for adjusting it. Or, if you're handy, you could take off the handle & have a look; it shouldn't be too hard to see what's stopping the handle from turning more towards the hot side. Make changes in small increments & remember where you started.
Mar 01, 2011 | Delta & Single Handle Shower Faucet
Single handle shower/bath faucet is dripping. Want
I can fix this.
What is the last thing you did before this problem started?
Jan 13, 2011 | Delta Faucet Delta 172-SSWF Waterfall...
The swing mixer handle has become very stiff. how do i get it off to clean it/
The first solution is of course correct. However I found it almost impossible to remove the spout assembly. It was very stiff and it was difficult to get any leverage to force it off without damaging the finish to the tap as a whole or damaging the sink.
What I found was that if you poured boiling water over the tap/faucet it eased the stiffness and having done this several times - ie about 5 kettle loads of hot water, I managed to remove the spout. It helps if you reconnect the hose directly to the outlet under the sink (ie not via the faucet). THis allows you to run cold water through the tap whilst pourung boiling water over the outside of the tap. The cold water shrinks the copper/brass components whilst the hot water expands the spout assembly.
Once off, it is possible to clean the inside of the assembly to remove corrosion or calcium deposits to say nothing of old "O" rings.
I also used a kettle descaler between dousing with boiling water in the hope that some of it would seep down within the assembly.
It took me three attempts to do this. I was almost going to spend UK pounds 430 or US dollars 670 and buy a new unit. So do not give up and I hope this helps.
It swings backward and forward now perfectly.
Aug 27, 2010 | Blanco Classic Single Handle Faucet with...
I replaced the cartridge on my Moen single handle kitchen faucet (the old cartridge had become quite stiff). Everything went back together fine. Now however there is alot of slack in the handle when the...
You need to get the handle back on properly there is a groove on the handle that connects to the top lock nut older models had a chrome nut newer ones had a black plastic one
Nov 17, 2009 | Plumbing
Handle is stiff and leaking at base. It appears I need a cartridge replacement. How do I access the cartridge? Thanks.....Keith
Moen products almost all have a lifetime warranty.  I know they have a website because I queried & found a phone number called them & got replacement guts for my unit for about $8.00, Quality counts in my book!
Jul 22, 2009 | Moen 7840 Camerist Single-Handle Kitchen...
The faucet handle has become stiff to turn off and on, and to switch between cold and hot. I have loosened the screw with an Allen key, but cannot remove handle.
Jul 03, 2009 | Blanco Classic Single Handle Faucet with...
Single handel kitchen faucet: Over time the
Apr 22, 2009 | Delta Faucet Delta 470-BL-DST Signature...
On and off handle becoming very stiff
change the insert or washer thank you for useing fixya please rate me
Feb 19, 2009 | Blanco 157-090-CR Rados Kitchen Faucet...
Plumbing Logo
587 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
