Question about Sony Playstation 3 (PS3) Console
The red and yellow lights - Sony Playstation 3 (PS3) Console
  • 943 Answers
This is referred to as the yellow light of death(YLOD). It is caused when your console lacks enough space to be well ventilated and as a result, is now overheating.
It is best advised you send it to a repair center or back to sony because there are no sure ways of fixing this at home by yourself.
Hope this solution was helpful? Please comment for more information and thank you for using the fixya website.
Posted on Jan 02, 2011
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Tail light wire colors
Hi Anonymous,
Black=Ground
Red=Brake light
Yellow=Tail light
Have nice day.
Jun 24, 2013 | Harley Davidson Motorcycles
How can i get the words to which fuse operates what part of the car in an 06 charger???
Hi, All the Info You Need Is Detailed Below:
Front Power Distribution Center Fuses
# Amp Description
1 20 Yellow Left High Beam Headlight
2 20 Yellow Right High Beam Headlight
3 15 Dk. Blue Adjustable Pedal
4 20 Yellow Horn
5 25 Clear Headlamp Washer If Equipped
6 15 Dk. Blue Front Control Module (FCM)
7 20 Yellow Fog Lamp
8 15 Dk. Blue Park Lamp
9 15 Dk. Blue Non ABS Brakes
10 5 Orange Starter
11 20 Yellow Auto Shutdown/Powertrain Control Module (PCM)
12
13
14 25 Clear Powertrain Control Module
15 20 Yellow Injectors, Ignition Coils
16 15 Dk. Blue Powertrain Control Module
17 30 Pink Antilock Brake System (ABS) Valves
18 30 Pink Windshield Wiper/Washer
19 50 Red Radiator Fan
20 20 Lt. Blue Starter
21 50 Red ABS Pump Motor
22 40 Green Radiator Fan High/Low
23 50 Red High Intensity Lighting
24
25 30 Pink Lighting Left High Beam/Right Low Beam
26 20 Lt. BlueTransmission
27 30 Pink Lighting Left Low Beam/Right High Beam
Rear Power Distribution Center Fuses
1 60 Clear Ignition Off Draw
2 40 Green Battery
4 40 Green Battery
5 30 Pink Heated Seat/Steering Column
6 20 Yellow Fuel Pump
7
8 15 Dk. Blue Ignition Start/Run - Start
9 20 Yellow Console Power Outlet
10 10 Red Rear Fog Lamp If Equipped
11 25 C/BRKR Memory Module/Door Locks
12 25 C/BRKR Passenger Power Seat
13 30 C/BRKR Door Module Run/Acc/Delay
14 10 Red Sentry Key/Remote Keyless Entry/Cluster
15 20 Yellow Brake Light (5.7L)
16 20 Yellow Power Outlet Trunk - if equipped
17
18 20 Yellow Selectable Power Outlet
19 10 Red Stop Lamp
20 20 Yellow Rear Wiper If Equipped
21
22
23
24
25
26
27 10 Red Airbag/Occupant Classification Module
28 10 Red Curtain Airbag - if equipped
29 5 Orange Sentry Key/Remote Keyless Entry/Powertrain Control Module Ignition Feed
30 10 Red Steering Column Module/Power Mirrors - if equipped
31
32
33
34
35 5 Orange Power Antenna/Garage Door Opener/Ignition Delay
36 20 Yellow Radio/Navigation
37 15 Dk. Blue Transmission
38 5 Orange Analog Clock/Garage Door Opener
39 10 Red Heated Mirror
40 5 Orange Power Mirror
41 10 Red Climate Control Module/Headlamp Leveling if equipped/Rear Park Assist if equipped/Tire Pressure Monitoring if equipped
42 30 Pink Automatic Temperature Control (ATC) Blower Motor
43 30 Pink Rear Defroster
44 20 Lt. Blue Audio Amplifier
Sep 13, 2012 | Cars & Trucks
Schematic to driver side fuse box
Cavity Fuse Description
1) 15 Amp Blue Horn Relay, Power Sunroof
Relay, Power Window Relay
2) 10 Amp Red Rear Fog Lights (Export Only)
3) 20 Amp Yellow Cigar Lighter
4) 10 Amp Red Headlight Low Beam Right
5) 10 Amp Red Headlight Low Beam Left
6) 20 Amp Yellow Body Control Module/Power Door Locks
7 )10 Amp Red Left Park Light/Left Tail Lamp/License Plate Lamp
8) Spare
9) 10 Amp Red Right Park Light/RightTail Lamp/License Plate Lamp/Cluster
10) Spare Cavity Fuse Description
11) 15 Amp Blue Flasher
12) 15 Amp Blue Stop Lights
13) 10 Amp Red Body Control Module/CMTC/Cluster/Pass. Airbag On,Off Indicator, Auto Daylight
Mirror/Light Bar Switch (Renegade Only)
14) 10 Amp Red PDC Fuel Pump/AC Clutch,
Starter Relay/Engine
Controller/Transmission
Controller (Diesel Only)
15) Spare
16) 20 Amp Yellow Power Outlet (Rear)
17) 15 Amp Blue Rear Wiper
18) 20 Amp Yellow Radio Choke & Relay
19 20 Amp Yellow
Frt Fog Lights/Trailer Tow
Stop and Turn Lights
20 Spare
21 10 Amp Red Radio
22 20 Amp Yellow
Power Sunroof Relay/
Antenna Module (Export
Only)
23 Spare
24 10 Amp Red PDC Blower Motor
25 10 Amp Red Heated Seat Switches/HVAC
Control Head/Trailer Tow
Battery Charge
26 10 Amp Red Headlight High Beam Right
27 10 Amp Red Headlight High Beam Left
28 Spare
29 10 Amp Red Heated Mirrors/Rear Window
Defroster Indicator
30 15 Amp Blue Heated Seat Module
31 Spare
32 10 Amp Red Wiper Switch/Front and
Rear Wipers
33 10 Amp Red SKIM Module/Data Link
Connector
34 15 Amp Blue Body Control Module/
Cluster/Interior Lights,
Hands Free Module/Radio/
CMTC/ITM Module & Siren
(Export Only)
35 Spare
36 10 Amp Red Airbag Control Module/
Occupation Classification
Module (Right Front Seat)
37 10 Amp Red Airbag Control Module
38 10 Amp Red ABS Controller/Shifter Assembly
39 10 Amp Red Hazard Flasher (Turn
Signals)/Backup Lamp
Switch (Manual Transmission
Only)/Transmission Range
Switch (Automatic Transmis
May 23, 2011 | 2005 Jeep Liberty
MY LOW BEAM HEAD LIGHTS AND INTERIOR CURTESY LIGHTS DO NOT WORK
on head light switch check for 12 volts on black/yellow wire. if missing check fuse and wire to fuse box. IF there check red/yellow for same. IF missing on red/yellow suspect defective light switch.
Feb 16, 2011 | 1965 Ford Mustang
Wiring schematics for a kenwood kdc-mp145 to a 1998 ford ranger
Battery light green to yellow
Accessory yellow/black red
ground black black
Illumination light blue.red orange/white
Power antenna amp=blue blue
LF + orange/light green white
LF - light blue/white white/black
RF + dark green/orange gray
RF - white/light green gray/black
LR + gray/light blue green
LR - tan/yellow green.black
RR + orange/red violet
RR - brown/pink violet/black
Sep 21, 2010 | Car Audio & Video
How can I wire fluorescent tube light.There's 2 cables incoming through the wall.One has red,black and green/yellow.Other has red and black only.I've tried connecting both reds from the incoming cables to...
if you have 1 switch ! take the cabel wiv the yellow red black an green conect green to E earth , conect the to reds together that will feed the switch connect the black to the nutral on the light fiting and tape up the yellow not needed !,then take the cabel wiv only red and black , the red is connected to the other red as explaind above ,then the black is the return from the switch therfor connect it to the live tuminal on the light fiting MAKE SURE U TURN IT OFF AT THE FUSE BORD FIRST PLEASE!!!!!!!!!!!
Sep 29, 2009 | Hydrofarm Hydrorfarm Flco200d Fluorescent...
3 red lights and yellow power supply light
at the very least the main board is acting flaky with the 3 red lights flashing. Here is tutorial courtesy of LLAMA to show how to resolve that problem:
http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm
As far as the yellow light on the power supply is concerned. Unhook it from the Xbox 360 and only plug it into a power outlet. If the light is yellow then the power supply is bad. If the light stays green then plug it into the xbox 360, if it tells yellow then, at that point you know that the main board is causing the yellow light on the power supply and that means the main board is bad.
Aug 03, 2009 | Microsoft Xbox 360 Console
Installing remote start
1996 Mercedes E-Class Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Red Ignition Switch Harness Starter Purple Ignition Switch Harness Ignition Pink/Black Ignition Switch Harness Ignition 2 Pink/Yellow Ignition Switch Harness, Accessory 2 Accessory Pink/Blue Ignition Switch Harness Tach Black Coil Brake Switch Black/Red Brake Switch Trunk Pin Brown/Yellow/ (-) Trunk Light Parking Lights Gray/White L And Gray R at Light Switch or Alarm Module Head Lamp White/Yellow (+) Light Switch Factory Disarm Blue (-) Driver's Kick Panel Door Trigger Gray/Black (+) Gray/Red Head Light Switch Door Lock Blue/Yellow (-) Driver's Kick Panel Door Unlock Blue/Black (-) Horn Wire Black/Yellow OEM Alarm in Trunk
Jul 18, 2009 | 1996 Mercedes-Benz E-Class
Need fuse block diagram for a 1991 Plymouth Voyager
Cavity
1 20 amp yellow hazard flashers
2 10 amp red heated mirrors
3 20 amp yellow body lights
4 not used
5 20 amp yellow windshield wipers
6 20 amp yellow turn signal lights
7 10 amp red radio
8 not used
9 7.5 amp violet illumination lights
10 2 amp pink left tail lights
11 2 amp right tail lights
12 not used
13 20 amp yellow rear window wiper/washer
14 2 amp pink speed control
15 10 amp red gauges, warning lights
16 not used
17 10 amp red left low beam headlight
18 10 amp red right low beam headlight
19 20 amp yellow stop lights
20 20 amp yellow rear a/c heat
21 20 amp yellow fog lights
22 20 amp yellow park lights
23 20 amp yellow battery
24 20 amp yellow back up lights
25 circuit breaker power windows,power vent windows
26 30 amp lt. green a/c heater blower motor
27 circuit breaker power door locks
28 not used
May 21, 2009 | 1991 Plymouth Voyager
Sony Playstation 3 (PS3) Console Logo
54 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
