Question about Canon EOS Rebel XSi Digital Camera
I have a canon eos Rebel DXS - I dropped it and now it won't focus.
  • 747 Answers
Normally I'd say your camera is due for a trip to the service department but, depending on the surface the camera was dropped on and did it hit lens first or body. So without knowing let me ask you to do this. Remove the lens and quickly install the body cap on the camera. Hold the lens firmly in a hand and shake it vertically gently but with a little vigor listen for a rattle, stop, do it again horizontally listen for a rattle. If it rattles the lens has internal damage if not and the camera appears to be functioning then I'm going to instruct you on how to clean the gold contacts on the lens and body.
Using a new pencil with a red rubber eraser gently rub/clean the gold contacts while holding the lens almost vertical with the contacts facing down, use a puffer/blower to clear away the rubber dust. On the camera body, remove the body cap and hold the camera with the lens mount facing down as best possible and clean the tinny gold contacts with the red rubber eraser. DO NOT use a puffer/blower or blow on this part to remove eraser dust. Keep the camera lens mount facing down as much as possible and use a lens tissue to clean away any rubber dust. When you have completed this install the lens on the camera and make sure it clicks and locks solidly. Try your camera again, if it works great if not it means there is an electrical break within the camera or lens and it needs to got to a service depot. Hope everything work for you
Posted on Jan 02, 2011
Canon Rebel EOS Rebel Ti1 will not auto focus
The lens needs servicing, because the lens is stiff the auto focus motor cannot turn the lens to focus.
Mar 24, 2012 | Canon Digital Rebel EOS 450D EOS Rebel XSi...
Digital Rebel XT / EOS 350D Digital Camera with EF-S 18-55mm Lens: my rebel xti won't shoot a macro shot. There's pl...
There is a minimal focusing distance for all lenses. If you move closer to the subject than that distance then the camera won't focus on it. Check you lens manual for minimal focusing distance. It is 11 inches for Canon EF-S 18-55mm f/3.5-5.6 USM, for example.
May 16, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon rebel xt 1. image looks blury in eye
1. The viewfinder's diopter is probably out of focus (doesn't affect Auto Focus of photos). There's a dial and a +/- symbol next to the viewfinder. Turn the dial till you can see clearly through it. Alternative reason: The glass in the viewfinder is dirty/foggy. Use camera cleaning solution (a drop) on a cotton bud to clean it.
2. Malfunction needs Canon Service Centre to take a look at.
Dec 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Camera has no display, appears to be locked up, shows busy through veiw finder, otherwise focus ok but no picture taken. Battery and SD card ok.
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Nov 29, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
"BUSY" Problem
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
I hope that helps.
Apr 17, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon EOS Rebel problem
This is usually caused by a defective shutter release switch - it'll have to go into a repair shop - independent shops will charge about $110 USD - Canon charges about $180
Nov 26, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Rebel Xti Wont autofocus
I dropped my camera and thought the autofocus broke. It turn out that it swithed from autofocus to manual focus. There's a switch on the lens. Check if that's your problem too.
Sep 25, 2008 | Canon Rebel XT / EOS 350D Digital Camera
My auto focus on my rebel digital eos will not focus
have you tried to focus on diffrent things? changing the lighiting? if you try to manual focus, does it work?
Jul 06, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Rebel XSi Digital Camera Logo
179 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
