Question about Microwave Ovens
I have model jvm1860 w001 serial# RD981284s it turns on, motor runs light works, but does not heat. What is wrong? what might be wrong
  • 472 Answers
MOST LIKELY YOU HAVE A BAD MAGNETRON WHICH IS A DEVICE THAT ACTUALLY HEATS THE UNIT...if the units tiimer and turntable and all are functioning but at the end of the timed cycle the food or liquid is not hot most likely it is the magnetron... the magnetron is one of the main components for the microwave to work and to be honest unless you have access to a supplier or are in the field alot of times the cost to repair almost is as much as a new microwave. good luck servicer now for 18 years and this is a common problem
Posted on Jan 02, 2011
Food Heats fine, but turntable wont rotate. Makes a loud noise until we press the
see this tips for to repair:
Inspect the plastic drive coupling that the tray sits on, as well as the ring-and-roller assembly, to make sure that they're working properly.
First, make sure the turntable coupler under the glass dish is not broken. Second, on the control board, find the turntable relay and test for voltage. Some turntable motors are 24 volts DC, so make sure your testing the correct voltage. If no voltage from the control board, then replace the control board. Otherwise head towards the turntable motor.On OTR models, you can get to the motor by un-screwing the bottom panel on the microwave. On countertop models, there will either be a knockout or screw on access panel. Check for voltage at the motor. If no voltage, check the wiring back towards the control. If voltage, then replace the turntable motor. The component list below also shows how to test a turntable motor.
Sep 09, 2012 | GE JVM1860 Microwave Oven
Light comes on motor runs,does not heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jan 03, 2011 | GE JVM1860 Microwave Oven
Doesn't heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
Oct 27, 2010 | GE JVM1860 Microwave Oven
All functions appear to be working, but food is not heating at all - worked yesterday, but nothing today.
Basic Microwave Oven TroubleshootingTips
heatman101,/.l;l,.
Apr 24, 2010 | GE JVM1860 Microwave Oven
Buzzing sound on all functions, including when light is turned on;fan vent not opening when fan turned on; not heating. is this a short/malfunction of control board?
sounds like a control/display board issue but if you microwave has a noise filter board (fuse is mounted on it) it could be that
Feb 04, 2010 | GE JVM1860 Microwave Oven
Microwave not heating food and is making loud noise.
You have burned out the magnatron (heating element) which is common on GE microwaves. most service companies will charge about 200-250 to replace it
Jan 31, 2009 | GE JVM1860 Microwave Oven
Microwave jvm1860
I had a repair man out to fix my microwave and all it took was to reset the unit. We shut off the power source ( at the breaker box ) and turned it back on. This had the effect of a reset. Now it works fine. Hope this helps.
Jan 09, 2007 | GE JES1851 Microwave Oven
Microwave Ovens Logo
12 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
