Question about Stanton T.60 Turntable
Can the swing arm get replaced on t.60 the weight part broke off
Where do i buy parts for clock
find a clock maker or watch repairer in your area
admitted they will be far between but they do exist
maybe on the net
however if you just want a pendulum to make it work and weight on an arm will do
the arm will need to be fully threaded so that the length from the pivot point to the weight can be adjusted as this dimension is what adjusts the timing of the swing to maintain time accuracy
something like a 1/2 ounce lead sinker on a threaded bar say 1/8 dia will do for a start point.
The longer the swing the slower the time and conversely the shorter the swing the faster the time.
May 18, 2015 | Watches
Show me proper spacer placement on rear axle of 2002 hd duece
The axle enters from the disc brake side through a collar (washer with a cut out on it, axle adjuster bolts sits in cut out), through the swing arm, through the plain spacer, then through the wheel, then through the spacer that has a type of grouve in the middle of it, through the swing arm and finally through another collar, then a washer and finally the axle nut. Nut torque is 60 - 65 ft/lbs. Do not exceed 65 ft/lbs or wheel bearing damage will occur.
Oct 04, 2014 | Harley Davidson Motorcycles
Pulley and belt
This is one hell of a job so if you aint got patience get someone who has to do it. Here goes;
Get her up on the main stand or jack her up. Ensure the weight is carried on the front wheel otherwise get a jack to raise/support the rear.
Loosen rear wheel adjusters and push wheel assembly as far forward as it will go.
Lift old belt from the top of rear pulley and as you ease the belt towards you rotate the wheel/pully towards the rear this will allow the belt to be eased off the pulley. MIND YOUR FINGERS
Now remove the rear wheel assembly completely, not forgetting to disconnect the torque arm and brake cable / rod if your bike has drum brakes.
Remove the drive pulley cover and ease the belt off.
Now the worst bit, the swing arm has to come off to allow the belt to go around it.
Disconnect shocks from swing arm (lower mounts only will be ok)
Remove swing arm.
Install new belt on drive pulley, replace swing arm ensuring the belt goes around it and reassemble all other parts.
Making sure all nuts / bolts are torqued to makers specs.
When the rear wheel is back in the belt can be refitted to rear pulley using the same method as removal it will probably be harder being new but it will go.
Finally adjust the belt tension to makers spec and ensure wheel runs true. That's it now you can have a cup of tea you've earned it
. GOOD LUCK
Jun 04, 2014 | 1993 Harley Davidson FXR Super Glide
2006 c90 swing arm bearing replacement
how do you remove the swing arm from susuki c90
Aug 06, 2012 | 2006 Suzuki Boulevard C90
Record player head goes a few songs in on start up
not sure what you mean Ryan ... do you mean the arm swings to the middle of the record when you set it down in the groove? if so the arm is out of balance and you need to balance the weight forward. if there is no weight adujustment then your works off a spring and there a million ways to adjust that. Try balancing a penny on top of the head where the cartridge is to hold it done, if this temporarily solves the problem then teh arm is out of balance.
Feb 14, 2012 | Audio Players & Recorders
Hi my chain was to loose and tensioners were maxed out . so i took out a link worked fine brought it up to the 3rd mark on the rear arm sweet. but now my tire is rubbing on swing arm ?? tires the rite...
LOL! U took too many link.... u just have to deduct at least 1 link at a time or the tire is misaligned, i meant the way u put back the tyre in the swing arm!
Jun 12, 2011 | 1990 kawasaki ZXR 250
How do I wind up my tag carrera automatic using the crown??
Wow, how wrong yall are.
There are three positions for the Carrera's push-down crown. The inner position is used for normal wear and winding. To wind the crown manually, simply rotate it clockwise.
Changing the date on the Carrera is done from the middle crown position. Turn the crown clockwise to advance the date, one day at a time. Push the crown back to the inner position when finished.
The outer crown position is used for setting the time. You can turn the crown in this position either clockwise or counter-clockwise. Adjust the time forward or backwards. Setting the time backwards will not damage the watch. When the time is correct, press the crown all the way into the inner position.
Feb 24, 2011 | Tag Heuer Automatic Chronograph Series...
How do I shut it off, going on a trip. Ice maker swing arm is broke, it just flops. Thanks
Without that swing arm, the only way you can turn the ice maker off is to remove it from the freezer, or of course replace a new swing arm.
I would also highly advise turning the water off to the refrigerator. this is good advice for anyone leaving their home for a while, whether or not you have a problem with your icemaker or water dispenser system.
Visit my website for service or to ask general refrigerator questions: www.FixMyFridge.net
Mar 17, 2010 | Amana ABB1927DE Bottom Freezer...
Replaced the rear struts and shocks but there is still a rattle from the left rear wheel when i drive over the smallest of bumps in the road . someone mentioned the swing arm bushings: your thoughts?
You probably need to tighten down the center bolt. With the vehicle on the ground with weight on the struts (laden weight), tighten the center bolt in the strut tower. That should take care of your problem.
Sep 02, 2009 | 1995 Toyota Camry
Tone arm skip back.
You most likely have broken balls,,, lol yes balls bearings are most likely broke you might have to replace your arm.. about 80.00 for the part
Oct 17, 2007 | Technics SL-1200 Turntable
Stanton T.60 Turntable Logo
26 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Electro Med Services...
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
