Question about D-Link DI-704P Router
Modem to broadband router
I have a d-link adsl modem with ip address 192.168.1.1 and d-link broadband router with ip address 192.168.1.2. my connection type use pppoe. how to connecting my modem to a router, so i can share the internet conncection?
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is your dsl modem plugged into the modem port on the back of the router?
  • 34 Answers
Hi ditia,
U need to connect the modem>>router>>computer..u need to login to the router by using the ip address 192.168.1.1..it will prompt for a password...enter the password to login to the router..After logging in to the router..there will be a connection type..u need to select pppoe..after selecting pppoe u need to enter the user name and password which u got from ur ISP..save it...now ur internet will work...please give me a feedback if this info is useful
Posted on Jul 09, 2008
MR814 does not get IP address from my ADSL modem
try power cycle modem to clear out the computers onfo then it should connect to the router
Aug 10, 2012 | NetGear MR814 Wireless Router
I have a Zhone ADSL2+ 4 Port Wireless Bridge/Router, model number 1518-A1-UK-0MA. it as working perfectly until one day when i turned it ON, only the ADSL LED is lit, no other LEDs are on, nor the power...
Please use the following steps:
1. Remove the router and connect it directly from the pc to the modem.
2. Power cycle: turn the modem off and then the computer for 30 seconds, then turn them both back on, modem first.
3. Check you internet connection to see if it working.
4. If it working, connect the router back up. If it not working contact your ISP for dsl support.
5. Once the router is connected, release/renew the ip address. Go to the dos command type ipconfig/release press enter. Then type ipconfig/renew. Check your ip address, you shouldn't get an ip address starting with 169. If you do, this mean you have a problem with the router getting an ip address.
6. Check you internet connection after the release/renew
Jun 10, 2011 | Zhone 1518-A1-NA Wireless Broadband Router...
Can't connect AirPlus Extreme G+ wireless router and modem
assuming you have adsl/broadband coming down your phone line, you plugn the phone lead into the Thompson. If this is working you simply connect one of the LAN sockets on the Thompson to the Internet socket on the back of the Airplus.
You will need to make sure they dont both have the same IP address otherwise they won't work.
The IP address is the numbers you log into them with, eg 192.168.1.1
If they're both hte same, you'll need to log into one and change the address in the advanced settings area.
Jan 03, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Just bought PB Ixtreme x5620. i am trying to connect my virgin broadband to the pc. i have netgear router which has the yellow cable in the moden and router and the blue cable in the PC and router. i can...
Can you supply more detail of your network setup? You have a broadband modem, a seperate router and the PC.
For this setup cabling should be ....
1. Phone Socket (Pref. Master socket) to ADSL socket on modem
2. Modem LAN socket to Router WAN socket
3. Router LAN socket to PC Ethernet socket
Usually in this configuration you will have to switch off DHCP on either the modem or the router as they may both be trying to supply IP addresses to your PC. I would suggest disabling DHCP on the router and leaving the ADSL modem to supply IP addresses. If you do this you will have to setup the Router with a valid fixed IP.
Have fun!
Cheers,
Ripface.
Oct 25, 2009 | Computers & Internet
How to link two D-Link adsl routers with the same IP at a switch
You can go into one router and specifically assign it a different gateway address. I would rather have one router with one hub behind it and pay for one dsl line and max out the bandwidth from your isp. Hope this helps
May 16, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Wireless set up problem - no gateway ip or limited connectivity
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Feb 07, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Iam having an issue with the dlink router , getting 0.0.0.0 ip address for wan
Hi, first establish that the wires are plugged in to the correct ports, WAN port on the back of the router is in the internet port on the ADSL (assuming that is what your using).reboot the ADSL modem and wait for the light to settle, the link light should be solid. The ethernet light does not need to be solid, and the Act or activity light should be blinking, Now go to the command prompt and type in
> ipconfig /all. you should get a WAN ip. Otherwise, check if your service provider needs the MAC address of the router to establish it on the network...Telus used to need this. If this does not work, take the wire from your computer and plug it in directly to the back of the modem, this should get an WAN IP so you know that the router may need a bit of tweeking and a reboot of the hardware may be in order to sync everthing up again,,goodluck
Jan 06, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Need help
tesco broadband is not your ip address
IP address is 66.75.89.145, 192.168.1.6 something to that effect.
Aug 28, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
RG54SE II
In your wireless router,U want to configure the ip adress of internet,may R u static ip R dynamic ip address,
1. Statis ip customer means, configure the static ip address in your wireless router,
2. Dynamic ip customer means, configure the ip address of the ADSl modem ip.
May 20, 2008 | MSI Wireless-G RG54G3 Router
D-Link DI-704P Router Logo
99 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
