My samsung ht-thx22 player turns off after few minutes it read Protection. Also how can i reset the system itself?
5 Suggested Answers
SOURCE: We have bought a Samsung
the problem of the tv sound though speaker and the dvd player,have no audio output maybe the input from the receiver is wrong, always patch the line in to the receiver. patch the av cable one by one.pls see at the back of the receiver. note always patch the cable to audio in.
Posted on Apr 29, 2008
drlalitv
  • 488 Answers
SOURCE: I have a samsung DVD
If it is, the protection message usually meant either a speaker had blown, or more commonly a wire to a speaker had come disconnected or broken/shorted.
Try unplugging the speakers one at a time, and if you have a set of speakers of the same rating to try, try plugging them in as you remove the originals (obviously doesn't need to be done in the setup positions in the room, just have them beside the player to check it works.)
This might then identify which speaker or cable is the problem one for you to replace or repair.
If this is the speaker overload/short mesaage as I think it is and the above doesn't cure it, it would appear the amplifier board has a short somewhere and that's an electronics engineer job time
Hope it helps!
Posted on Nov 18, 2008
  • 4 Answers
SOURCE: My Samsung HT-40 home theater
The fan is going bad and if you have replaced it try to open the case and remove the cover over all the capaciters and what not and replace that fan in the back then cut a hole in the top of the metal case directly about the cap's that warm up and install a aditional fan to act as a chimney a little noisy but i did this and the player had been runing in aux and radio mode for a few days stright now no problems at all it's alot of work and skill but for 2 5-15 dolar fans sure beats the 160 for repair or buying a new recever! make sure u turn on the recever for 10 min if the fan is not turning by then its still not good
Posted on May 24, 2009
SOURCE: samsung dvd player switches itself onto protect!
hi,i can't connect my audio tv to cinema theater dvd
Posted on Apr 04, 2010
Sound fades out on my Samsung ht-thx22 system
Please check the drivers and see if this section is heating up, If so there is possibilty that there is a thermal runaway or there is dry soldering on the board. You can check for heating or simulate the heat to confirm the case, if not the use of a freeze-it spray can cool the suspected component to be confirmed.
Oct 22, 2011 | Samsung HT-X20 Home Cinema 600W Theater...
Cutting out samsung ht-thx22
Start with checking your speaker wires, alot of times if you have positive & negitive crossing it will cause this issue
Jul 25, 2009 | Samsung HT-DM550 System
My dvd home theatre system ht tx75 keeps shutting down
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
May 28, 2009 | Samsung HT-TX72 Theater System
Hello I have a Samsung HT-HTX22 home cinema. It wont play any discs at all, it says Loading then reads no disc or disc error, can any one help. Regards Joe
ik heb een vestel tv ,en krijg geen geluid via mn 5.1 ht-thx22 speakers omdat hy niet voorkomt op de lijst van het manual dus mijn vraag is ondersteunt hij ook vestel tv ,s of moet ik een samsung tv kopen m.v.g. D.Suverein
Apr 11, 2009 | Samsung HT-Z310T Theater System
Dvd multiregion unlock code
use the procedure for unlocking the Samsung HT-DM150 .
Oct 28, 2007 | Audio Players & Recorders
Samsung HT-DB600
samsung told me the fan is not working and needs replacement or a tune up??? They can repair it for $150.00....totally sucks
Apr 29, 2007 | Samsung HT-DB600 System
Dsp protection
Resetting- taken from the user manual:
Jan 27, 2006 | Samsung HT-DB600 System
System switches itself off
The HT-DB120 has an automatic shut down that should turn off after 20 min of idle mode, it seems yours is malfunctioning. try disconecting the DVD from power for a few minutes.
Jan 07, 2006 | Samsung HT-DB120 System
Televison & Video Logo
332 people viewed this question
Top Televison & Video Experts
