Question about Maytag MSD2756G Side by Side Refrigerator
My refrigerator is a Maytag MSD265hes, the ice maker doesn't make ice because the water doesn't go up to the freezer. It does goes to the door water dispenser .
  • 6,993 Answers
read my tips on how to fix an ice maker not making ice problem;
http://www.fixya.com/support/r7602816-steps_when_ice_maker_not_making_ice
I hope it helps.
Good luck.
Posted on Jan 02, 2011
Ice maker does not make ice
Is the freezer freezing the contents good?
Nov 27, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag psd245ogr refrigerator, no water, no ice. Started with hollow cubes and over time smaller and less cubes. Finally, no ice in freezer and no water or ice at the door dispenser.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 | Maytag MSD2454G Side by Side Refrigerator
Ice maker not making ice
check the water solenoid for the ice maker on the back
Jun 11, 2010 | Maytag MFI2266AES Stainless Steel Bottom...
Ice maker won't work
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Maytag MFD2562KES Stainless Steel Side by...
Ice maker sprays water...
sounds like the inlet part on the ice maker is froze over or not lined up in the opening of it right or a possibilty that the ice maker is leaking out the water if that is the case the ice maker needs replaced
Jun 07, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Ice and water on bottom of freezer
sjlobo, sounds like your defrost drain pan is frozen over or has some gunk in it. When the unit goes into defrost the water is running onto the freezer floor and out the front. Remove the lower bin and check the drain hole. You may have to remove the freezer back panel. If you can, just use some very hot water and some sort of baster to unfreeze the drain. Check this first, Catriver..post back.
May 05, 2007 | Maytag MSD2758G Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
138 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
