My TCL TAC-12CPA air con display panel show "PF" and it would not be able to start.
  • 2,133 Answers
PF-Power failure in pcb board. Check power to indoor unit and then to PCB. If no power, repair your PCB>
Posted on Jan 03, 2011
How do i fix my tcl 32 inch led tv? When i turn it on the screen display is ok minutes later the screen turning to white. Pls help me how to fix it. Thanks in advance
The T CON board or the LCD panel is faulty. In almost all the 32 inch tvs the TCON board is integrated to the LCD panel and is only replaceable along with the LCD panel.
http://electro-medical.blogspot.com/
Jan 02, 2016 | Televison & Video
How do I refill water in a portable air conditioner. TCL TAC-09CP/C
If it's an air conditioner it probably needs freon and not water
Dec 19, 2015 | Miscellaneous
Kitchenaid model YKGSC308LSO is showing code PF
Press and hold the Start pad for 5 seconds until "Control Lock" appears on the display. Repeat to unlock, and "Control Lock" will disappear from the display.
Apr 19, 2014 | Kitchen Ranges
Air conditioner TCL TAC-12CHS/G not cooling
you could have ither an electronic or lectrical problem, your electronic board in the inside unit or a bad capacitor for example not letting the compressor to run. call a service man or some thng
Jan 26, 2014 | Heating & Cooling
I have ac tcl model tac-42cf is not working and have error code in the display,how i can fix this trouble for this error?
I have the same problem..but i fixed that. if u have the same type with mine; TCL split type ac, TAC-42CF/A,380V 3N~. Then u can try this.
1. open indoor panel.
2. find 2 cable in socket pcb that is p11 And P12, u plug p12 on p11,and p11 on p12.
3. if not solved, try the same just like point 2 on power suply 3phase cable R.S.T try S to R, or else.
4. hopefully ur problem solved.
Aug 14, 2012 | Cars & Trucks
My TCL portable air con display panel show'PF' and it can not start.
PF power failure. Please check input has right voltage. If so, check fuse in PCB.
Oct 16, 2011 | Heating & Cooling
TCL-12 CHE/s Mid-wall split unit. The unit is fully operational. The display on the front panal "jumps" - the room temperature display temperature "jumps" Thanks Harold
Clips with PCB loose contacts. Find and rectify. If not clean with blower with minimum speed. Dust forming on display sensor will create these type of jumping.
Jan 19, 2011 | Heating & Cooling
TCL TAC-12CS/J displays 1 and beeps 4 times then turns off.
Check your indoor fan motor mechanism is locked. Replace bearing, if u can or replace motor. Helpful?
Dec 20, 2010 | Heating & Cooling
TCL air conditioner wiring
John what is the problem ? My 18CHS gave me problems but are now fixed. Maybe I can help
Dec 18, 2009 | Heating & Cooling
Mitsubishi gto car air com panel
no lights on air con display panel
Jul 15, 2008 | 1992 Mitsubishi 3000GT
Heating & Cooling Logo
238 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
