Question about GPS
I cannot hear the directions from the system - GPS
    President:
  • 485 Answers
Have you tried setting the volume higher yet ? (it is usually an option on your menu / settings screen).
If you already have done that, and you still cannot hear the directions while the screen shows the maps, direction arrows, etc., and you have selected a valid "preferred" voice/sound, then the speaker may have to be checked / fixed.
Posted on Jan 02, 2011
Condenser fan replaced one year ago, fan not turning but can hear motor
the answer to your problem is most likely the motor start capacitor. A AC motor can run in both directions. The start capacitor is used to cause the current to lag behined the voltage which determines the direction the motor will turn. Its posible the start and run capacitors are in one can. so changing one will change the other. However look for a wiring diagram. Do not asume that both capacitors are wired in properly. They may be fighting one another causeing premature failure.
Sep 18, 2012 | Carrier 38CKC036 Air Conditioner
My ps3 is the one that plays both ps3 and ps2 games and it says cant start cannot find correct hard drive
1. turn off system completely (this means the switch on the back)
2. hold touch sensitive reset button down till you hear 3 beeps, than let go.
3. hold down touch sensitive reset button until you hear 2 beeps and a double beep.
4. follow on screen directions, choose what option you want (i pick 3, it
seems to work the best)
5. follow on screen directions
http://www.youtube.com/watch?v=c0e-oO6l9kk
Mar 09, 2011 | Sony Playstation 3 (PS3) Console
I hooked it up the way the manual said and it doesnt work
Try whatever applies best below, in order...
Cable Box optical Digital Audio to Digital Audio In. (This brings TV-related multi-channel and normal audio into the receiver so you can hear it over the speakers. Turn TV volume OFF.
The cable box probably has a pair of stereo Audio Out RCA jacks. Run those directly to the TV so you can watch and hear cable programming over the TV's speakers without having to turn the system on. Turn TV volume UP.
Depending on your TV's Video In capabilities, use the Cable Box HDMI, Component (Red, Blue and Green), or Composite Video (single Yellow associated with the Audio Out) directly attached to the TV.
May 01, 2010 | RCA RT2380 Home Theatre System System
What outlets do I hook up to on the reciever and the tv for it to play on regular tv stations
Cable Box optical Digital Audio to Coby Digital Audio In. (This brings TV-related multi-channel and normal audio into the Coby so you can hear it over the speakers. Turn TV volume OFF.
The cable box probably has a pair of stereo Audio Out RCA jacks. Run those directly to the TV so you can watch and hear cable programming over the TV's speakers without having to turn the Coby on. Turn TV volume UP.
Depending on your TV's Video In capabilities, use the Cable Box Component (Red, Blue and Green), or Composite Video (single Yellow associated with the Audio Out) directly attached to the TV.
Mar 01, 2010 | Coby DVD938 Theater System
Magicjack
Question: is the magicJack plugged directly into the USB port on the computer or through a USB hub? If it's plugged into a hub, try plugging it directly to the port on the machine.
Feb 22, 2009 | Acer Aspire 3680 Laptop
No Surround Sound in Aux 2 mode
genarally tv output contain two signals.(steereo).it dosent have surrund output.thats y its not hearing surround sound from your system.
Jan 07, 2009 | Samsung HT-WX70 Theater System
Sound from DVDs
check the centre speaker is wired right
Jun 27, 2008 | Audio Players & Recorders
Remote problem
dear friend:after apply fresh and new battery and install it in right direction bring an normal radio set -put it in am postion tune dial in position between channel and press power button in remote many times you will hear clicks eash time you press the button if you hear the clicks clearly the problem will be in the player .
Nov 28, 2007 | Panasonic SC-AK200 CD Shelf System
GPS Logo
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
