I has told that the fire wall inside burner needed replacement, where to find it and which one should I get?
    Novelist:
    Scholar:
  • 111 Answers
There are several reputable HVAC supply places in any major town, as well as on the internet, but you'll want to make sure you have the Make, model number and serial number to find what you need. I would also recommend either getting professional help, or getting really friendly with an HVAC guy and having them explain the process in minute detail as you don't want to install it improperly and end up with a fire hazard rather than protection!
Good luck!!
8^)
Posted on Jan 02, 2011
Water leaking near the fire wall
Sounds a corroded heater core, leaking inside firewall. It is possible if the leak is not to bad try some stop leak. from the below link. Thank you Atheek, please leave feedback. Advance Auto Parts Car Engine Batteries Brakes Replacement Performance...
Jul 12, 2016 | 2008 Ford Territory 4.0
Frigidaire gas dryer model flxg52rbs3 is making strange noise and leaving burn marks on clothes. I want to take front cover off to clean out lint but I need to know how to take cover off.
The burner safety system is not working. The thermostat may need to be replaced. If it were too much lint, the dryer would not dry the clothes completely. Take the vent hose off the dryer and vacuum it out and if it connects to a wall that vents to the roof, then vacuum inside the wall too. Lint fires are more prevalent than those that vent thru the wall to the outside.
May 25, 2015 | Frigidaire Dryers
How do u replace the clutch pedal to the transmission on a 1989 toyota pickup!? The clutch bracket is broken that's on the inside of the fire wall
the holding bracket for the pedal is welded to the fire wall so will need rewelding into place , it must be millimeter perfect for the clutch to operate accurately
May 13, 2015 | Toyota Pickup Cars & Trucks
My jandy xl 250 pool heater runs great for 5-6 minutes with a blue flame then it turns orange and runs hot ive replaced all 5 burners wire brushed and power-washed the heat exchanger. I tore it all apart...
bad mixture is correct. heater is under firing, lack of oxygen, hence the immense amount of soot or carbon build up underneath heat exchanger. Is heater inside a shed? if so u need 2 vent openings to provide combustion and ventilation air. vent blockage can also cause sooting and over heat conditions. your repair guy lacks alot of knowledge. burners and heat exchangers can be cleaned. i can give you a list of reasons of possible problems that im sure were never mentioned or checked
Aug 11, 2013 | Pool & Spa
Installing burner tubes
On a lot of weber grills, the back of the tube burners have tabs that slide into slots in the back wall of the fire box. You have to take off the front control panel so the valves will move forward. This will allow the burners to move forward out of the slots. Install the new burners and be very, very careful to get the new burners mounted on the valves correctly when you put the front plate back on, or you will have a flash back fire problem.
Aug 18, 2011 | Weber Genesis Silver A Grill
I have a HE20 Insta Flame propane fireplace. I can light the pilot light but I can't get the burners to turn on. It has a wall switch that is suppose to turn the burners on. Any suggestuions?
Try installing a new light switch. The fireplace is using a millivolt system and even a tiny amount of voltage drop across the switch can be enough to no longer bring on the burners. You can test that it is the switch by removing the wires from it and touching them together... if the burners fire, replace the switch, if they don't, call your serviceman.
Dec 19, 2010 | Heating & Cooling
My pitco 35 c the flame is burning yellow and not going inside the very wall i thought it might be the regulator pressure on the fryer on the back side
Low gas pressure will produce low flame quality (yellow flame).
Check and remove any dirt or soot on burner holes, and orifice
Burner flame not going inside the fire tube could be due to soot or carbon build up inside the fire tube blocking the flame path, check the inside of the fire tube, if considerable amount of soot is seen, better have them removed.
Yellow flame will cause a lot of problem on fryers if not corrected as soon as possible.
If you have doubt on your gas regulator, better have a qualified service technician to check it.
Sep 02, 2010 | Pitco Frialator 35CS Deep Fryer
The steering wheel is very loose. I've been told to replace the whole steering column. Does this include from the wheel all the way into the engine to the tire assembly? What's the general process?
The column unbolts from near the fire wall.. You should only need to replace the column from near the fire wall and all that is inside the car..
Have a great day !
Mar 06, 2010 | Dodge Caravan Cars & Trucks
How hot is the Vent temp of my new Duet?
It's not the temperature of the air that is the problem. The air is seldom over 160 Deg F. If you have a vent fire the piping needs to last long enough without melting to starve the fire of oxygen in the hopes of extinguishing. Rigid aluminum piping is best suited for this, Rigid flexible is next. The tin foil and white plastic offer little resistance to melting if a fire should begin. The melting would allow the fire to replenish oxygen and support the burning process. The main caution here is to keep your dryer and vent clean...at least annually.
If the duct inside your wall is rigid metal all the way from the dryer to the house exit you need to do nothing to it . Replace the vent between the dryer and the wall with rigid metal 4" piping or hard flexible aluminum piping. If the duct inside your wall is either of the least effective types you need a new run of vent for the dryer to avoid a fire.
You can't use white plastic or flimsy flexible aluminum that feels like aluminum foil when you touch it.
Sep 10, 2009 | Whirlpool Dryers
Williams wall furnace no longer adequately heats home
A couple thoughts. On some of the wall furnace gas valves there's a knob that you can set for low fire or high fire. If your valve has this make sure it is in the high fire setting. Is the wall furnace controlled by a wall thermostat or a knob on the heater? With the thermostat turned all the way up like to 90, does the burner and fan continue to run or is the burner short cycling. Is the fan clean and running up to speed. Some of the Williams wall furnace had a two speed fan motor so when the fan came on at first it would run on low speed. As the heat exchanger got hotter the internal fan switch would switch it to high speed. Outside of that you would need a monometer to check the manifold gas pressure.
Aug 31, 2017 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
