It sounds like the capacitor on the flash board isn't charging. They're small electrolytics that go bad in time, but usually are good for a few years. There could also be other problems such as a cracked solder joint on the board. It could also be a fault with the main board, but not likely in this situation.
The unit will have to be serviced, or at least troublshot, and you might contact Moultrie to see what they can do, or what they offer for support. I couldn't find a site for them online, so refer to your manual that came with the unit.
As an alternative, you can run it by a local repair shop, and see what they would fix it for.
Always get an estimate first, since it can run a bit.
Good luck, and hope this helps.
SOURCE: Flash
The flash PCB (circuit board) is a common failure point on your D70. It will need parts replaced. Nikon will be expensive, you might wish to use the service locater here on Fixya to find someone in your area.
SOURCE: Can't take picture with flash on
Hi
Your flash is defective and needs to be replaced, nothing else will fix the problem.
One solution is to look online for a defective camera and use the parts to fix yours. Another is to buy a flash from someone like us who sells new and used parts and performs repairs if you can't do it yourself.
Please feel free to check us out, Google: Darntoothysam and you will find us, I cant post a link.
Thanks and good luck from Darntoothysam com
Thomas
