Question about Kitchen Ranges
Door handels are loose (borrom of ref side). There is a small cover over the are where the bolts are located. How do you remove the cover?
  • 24 Answers
Most often it is best to use a utility blade as it is slim enough to pry under the cover without bending it and marking it .. be careful and gentle this is a thin piece of plastic and easy to damage.. in the future always indicate what make and model .. as some are metal and some are plastic and it does help.. but in either case metal or plastic same care should be taken..
Posted on Jan 02, 2011
Replacing rear passenger door window
First remove inner handel and door unlock latch then remove the door cover locate the bolt holding the window and remove them, lift the window
Apr 04, 2014 | 2005 Fiat Multipla 1.9
Changing mirrors to camping mirrors, 2009 silverado 2500 HD crew cab LTZ. got mirrors loose, but can't get cord out to unplug and plug in. appears that I have to take door panel off to remove cord and...
remove any snap in covers
remove retaining screws
panel will then lift straight up
snap in cover around door release (open) handel
power windows etc.etc.
retaining screws aroun handel (under plastic snap trim)
around lower section etc. etc.
Jul 02, 2011 | 2009 Chevrolet Silverado 2500HD
Driver side door wont open.solution on opening the door
This is usually caused by a broke plastic retaining clip.the inside handel should have a insert covering a screw pop out the insert and remove the screw. If there is no rod atached to the handel (broke clip) locate the rod in the door (a metal coat hanger works good) pull on the rod towards the front of the door and it should open.Replace the clip or sometimes the handel itself breaks needing replaced.
Hope you get a handel on it!!
Oct 23, 2009 | 1993 Honda Accord
Need to remove the driver's side inner door panel to replace the door lock due to vandalism of the lock
CLIP OFF COVER ON DOOR HANDEL /REMOVE BOLTS FROM HOLES IN HANDEL/ PUSH UP ON PLASTIC RING ON WINDOW WINDER NOW PRISE OPEN DOOR PANEL FROM DOOR.
Oct 21, 2009 | 2005 Ford F 250 Super Duty
Tahoe passenger door won't open
remove vertical screws from arm rest. ther may be other screwscovered by plastic caps. pull small triangular cover at top near dash covering mirror mounting bolts. pop window and lock switches up and out of the door pannel and be carfull when removing electical connections from those switches. then pop plastic panel around inner door handel out and turn to free from handel. Now u can start to remove the door panel. U can by a special tool at your parts store to pop the clips on the inside of panel or just pull it off starting from the bottom and working yourwhay around the sides and up to the top. then push upwards from the bottlm and the top lip should pop free of the door.
hope this helps
Aug 09, 2009 | 1998 Chevrolet Tahoe
Can't get door open, so can't remove panel to fix door open prob
These door panels are held in place to the interior door frame with push-in fasteners which are located around the side and bottom perimeter of the panel. These fasteners are popped out by placing a screw driver or other flat tool between the panel and the door frame. Usually there are screws and/or small bolts which hold the arm rest and door handle portion of the door panel. You need to locate any of these first and remove them. some screws/bolt heads may be hidden by small plastic caps which cover the heads. In some models, there is a piece of molding which is snapped in around the handle or on top of the arm rest. Once the perimeter fasteners are loose and all screws are removed, the panel is lifted up to disengage it from the bottom window frame. Be careful not to move the panel too far away from the door frame until you disconnect all wiring connections on the back side. Those nylon buttons that hold the panel in place sometimes break off when you remove them. They are replaceable(auto parts store).
Aug 08, 2009 | 2003 Nissan Maxima
Can I remove the door handles from my refrigerator?
should be a screw at top and bottom contact points of handels, under decrotive covers. use small straight screwdriver or something like that to remove covers. be carfull not to scratch doors or covers (it's yours so it's your call)
Jun 02, 2009 | Hotpoint HSS25GFP Side by Side...
Driver side mirror loose how can i tighten it
Most mirrors have a removable cover just on the inside of the door. If you look closely where the mirror meets the door on the inside should be a snap in place cover or three screw holes with snap in covers that you remove and then use a screwdriver or small socket wrench to tighten the screws or bolts.
Joe
May 20, 2009 | 1993 Saturn SC1
Removing carbine 4011 deadbolt
remove the screws with proper screwdriver then perform the replcment
if u need any details
Oct 04, 2008 | Deadbolt RF Remote , Satin Nickel
Door Handle repair
The fastner must be loose. Remove both set screws remove your handel. Then tighten the fastner. reinstall the handel and tighten your set screws. let me kniow if this helps
Aug 18, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Kitchen Ranges Logo
18 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
