Question about Diesel Garden
Hi, I have a BX2200 Kubota. After it runs for maybe 15 minutes and it gets warmed up it begins to run rough and blows white smoke out. Then it shuts down. HELP
3 Suggested Answers
SOURCE: Lawn mower engine runs rough and puts out white smoke
Pull the carburetor and clean it for staters.Be sure to change oil any little bit of moisture in the crankcase will let it smoke white by seeping by the valves and piston rings.Also put a little small amount of dry gas in the gas tank to rid all of the water that may have been left in the tank. I some of this will help you.
Posted on Mar 19, 2009
harlan301
  • 205 Answers
SOURCE: my T1760 blows white smoke for 60 sec when starting
it could be your choke stuck, but check you oil level and smell it does it smell like fuel. if so have your carb check out. Little lube on the chock lever. you may want to have your compression check and a leak down test done.
Posted on Oct 11, 2009
I just replace hydr. pump on a bx2200 Kubota tractor but it keeps blowing the filters apart . can you help me ?
connected the pipes to the pump incorrectly
filters go on the return lines or suction lines not the high pressure side of the pump
they are only good for a pressure of 30psi not 2000psi
Sep 02, 2017 | Kubota Garden
My Kubota BX2200 will not run it will run fine if you hold the key to start but when you let it go to on it stops running
Sounds like the fuel shutoff solenoid. cost around $!50 for the part.
Whats happening is when you turn it over the solenoid is holding the pin and when you let go of the key the solenoid is releasing the pin and shutting off the fuel.
Hope this helps
Apr 17, 2015 | Kubota Garden
4g63 delica black smoke running rough
You have a failed head gasket
Major repair
Hope you didn't think the stop leak was
a genie in a bottle,never need any product
in any vehicle,just the proper repair
White smoke was coolant ,should have known that
Nov 24, 2012 | 1996 Mitsubishi Eclipse
Grand prix has a 3.1 6cyl. and 166000 mile, it blow white smoke
Sorry to inform you of the bad news but the white smoke is engine coolant burning off and the rough running condition is also associated with coolant leaking into the combustion chambers.This will be a head gasket repair, basically a head job where you will need to machine the heads down and install new gaskets from the heads up.Get back to me if you have any more questions, thanks and I hope I could help!!!
Apr 11, 2010 | 1999 Pontiac Grand Prix
I have a 1998 chevy 2500 4x4 6.5 diesel pu.truck starts and seems to run normal ,maybe a little loud, i heard chevy diesels this year are louder than fords etc. blows a little white smoke at startup some...
the head gaskets are blown you can believe that anytime on any engine gas or deisel that you get oil in the radiator and there water/ antifreeze in the oil pan the gaskets and or cylinder heads are bad
Jan 20, 2010 | Chevrolet 2500 Cars & Trucks
I have a 1998 hyundai excel running rough as if only on 2 or 3 cylinders starts 1st time but running realy bad and blows heaps of white smoke I can drive it and you can feel it not running on all cylinders...
Is the heaps of white smoke come out of the tail pipe LONG AFTER the 15 minutes period?
To pin point a blowing headgasket you will need
1)coolant system compression tester
or
2)chemical reaction test for combustion test gas
If it's the org. engine from 1998,with over 120,000 then blown headgasket is a good possiblity.
Tow it to the shop and let the pro to do the coolant pressure test and combustion gas test.
A full head gasket job with head re-surface (if it can be re-use) is worth it.
Shop around on well estiblished independent shops.
Aug 12, 2009 | 1994 Hyundai Excel
Mar 18, 2009 | Garden
Garden Logo
130 people viewed this question
Top Diesel Garden Experts
Dennis Key
Dennis Key
john h
Ted Maxwell
Are you a Diesel Garden Expert? Answer questions, earn points and help others
