Question about Bosch B22CS80SNS (220 cu ft) Side by Side Refrigerator
Hello, My Bosch B22CS50SNS Side by Side Refrigerator no longer has lights in the refrigerator or freezer section. The control panel on the freezer door does not have power and does not function. The refrigerator side appears to be off and the freezer side appears to be working at a lower capacity. There is power to the unit and it sounds like a fan is working. Any advice?
  • Nicole May 29, 2012
    Did you ever figure out what the problem was with the refrigerator and how to fix it? I have same refrigerator and it is doing the same thing. Any info would be greatly appreciated. Thanks
  • Anonymous Mar 12, 2014
    installing a bosch B22CS50SNS refrigerator. do the rear wheels have to come off, the unit looks as thou take thgh it is leaning forward and doesn't want to slide under the old cabinette
Same thing just happened to mine. Was a solution found for this or did you call for a repair?
Posted on Jan 19, 2011
    Sergeant:
    Champion:
  • 342 Answers
The solution for this problem is to in plug the fridge and wait then plug it back in If that does not fix it thenyou need to call the company and see if they can give you a quote of how much it will cost to fix it and there is a way to make the repair cost less is to purchase an extended warranty and then have them come and fix it
Posted on Jan 02, 2011
My bosch no longer cools, all fans and lights work but the compressor does not kick in. This a bosch side by side b22cs50sns/01. I tested two sensors in different temp ranges and they check out.
Hi. This compressor uses a inverter module to operate. This a common issue with bosch S by S fridges. Replace inverter control board and its up and running again. The downside, its expensive
Feb 16, 2016 | Bosch Refrigerators
Why are control lights on continuously and no water or ice?
I won't be able to get too much info from Bosh because the keep all information solely for their people/service technicians but it does sound like the controls printed circuit is being affected by some type of PC failure..... B22CS50SNS Parts APPLIANCE 911
Sep 27, 2015 | Bosch B22CS50SNS Side by Side Refrigerator
Why won't the water filter light up on the display panel?
The lamp should only be lit when the filter is due for replacement.
Jan 08, 2015 | Bosch B22CS50SNS Side by Side Refrigerator
My Bosch Fridge makes a loud gurgling sound every twenty five minutes even after freezer fan &emotion were replaced.
It's a normal noise! When the liquid refrigerant becomes less pressurised, usually when the thermostat clicks off,, it still bubbles through the system until the pressure equalises.
Dec 17, 2014 | Bosch B22CS50SNS Side by Side Refrigerator
ED25PQDW01 side by side refrig -freezer is inconsistent. Need to have full cold to maintain freezer temp. cleaned coils, but still an issue.
Do you see a light coat of frost in freezer section about 12 inches up (defrost problem indication) ? Has the icemaker slowed down a bit in ice production ? What is the refrigerator control set on ? When you turn the freezer up completely , it cuts off the cold air flow which cools the refrig section . If refrig control is set mid way , turn it up higher , so refrig will run longer , but lower the freezer setting so some cold air will enter the refrig section . Also check to see if the freezer fan is working .
Aug 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Bosch B22CS80SNS (220 cu ft) Side by Side Refrigerator Logo
565 people viewed this question
Top Bosch Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
