Question about Kodak EasyShare C663 Digital Camera
Camera does not power up. rattiling inside.
My camera would not power up, c663, and there was something loose inside. So i took the case apart with the philips screws, and found that the noise was a small screw that appears to hold the lower left hand side of the screen down.
It still does not power up, so i am thinking that the screw, hit something such as a contact somewhere, and caused a short in the board- that goes beyone my technical abilities at the moment.
is this a common problem, any solutions
  • 2,427 Answers
Chances are One of the controll Ic's has been dhorted out. You will need to find a replacement board for it. If nnot then you need a new camera sadly..
Posted on Jul 09, 2008
Kodak c663 doesn't recognize any memory cards
What types and sizes memory cards have you tried? The C663 works with MMC and SD cards, 2GB or smaller. It will not work with higher capacity SDHC cards.
Oct 12, 2013 | Computers & Internet
Can C663 work with a 4 GB SD card?
No. The C663 uses SD cards 2GB and smaller, not SDHC cards 4GB and larger.
Aug 30, 2010 | Kodak EasyShare C663 Digital Camera
We have a C663 and C360 Kodaks. Both doing same
This problem is frequently the result of corroded battery contacts inside the camera. Remove the batteries and wipe the inside camera contacts with a soft cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Make sure there's no cleaning residue left inside the camera, then clean the battery contacts and reinstall the batteries. If this doesn't solve the problem you may have something more serious wrong with camera and I recommend checking the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format do diagnose problems and attempt to find a solution.
Jun 07, 2009 | Kodak EasyShare C330 Digital Camera
E18 problem
if it is E18 error u might get help from HERE
it may be broken GEAR u can try EBAY for parts or www.partstore.com
KINDLY RATE ME WELL !
May 28, 2009 | Canon IXUS V2 Digital Camera
Kodak c663 camera not working !
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
Apr 24, 2009 | Kodak EasyShare C663 Digital Camera
How do you get the case apart?
You have to remove the shutter button assembly first. Please see the following for a similar A70:
http://www.thustra.com/A70mod/
Aug 25, 2008 | Canon PowerShot A75 Digital Camera
No power
I can't get my camera to power up. I've bought batteries after batteries. Is it just history or can it be fixed. Cindyo
Aug 25, 2007 | Kodak EasyShare CX4300 Digital Camera
Ejection Door won't Close
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR, VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
May 22, 2007 | Sony Handycam CCD-TRV87 Camcorder
Kodak EasyShare C663 Digital Camera Logo
60 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
