Question about Sony Reader Touch PRS-600
Prs 650 stuck on sleep mode, wont charge or connect to pc
  • Sony Master
  • 890 Answers
Please click hear to get the information to resolve the issue.
Please click here to get clarification from my side.
Thanks.
Posted on Jan 13, 2011
Stuck sleep mode
http://esupport.sony.com/US/p/model-home.pl?mdl=PRST2
Apr 30, 2013 | Sony PRS-T2 eReader with Free Harry Potter...
Tip
Sony Reader Frozen
This solution applies for issues with Sony Reader Frozen in any model. PRS500, PRS505, PRS700, PRS600, PRS300, PRS900, PRS350, PRS650 and PRS950.<br /><br />1. Connect the reader to the AC Adapter (If available). If not, then connect the Reader via USB to the computer<br /><br />2. Hit the reset button for 3 seconds.<br />Location of RESET button:<br /><br />On the back = PRS500 - PRS505 - PRS 700<br />At the bottom: All the other models<br /><br />3. The red steady light should come on, if not, try the reset again while the unit is connected<br /><br />4. Allow the reader to charge for 40 Minutes (on PC make sure the computer does not go into sleep mode.<br /><br />5. Disconnect the reader and see if operational.<br /><br />GoodLuck!<br /><br />eBookBoy<br />
on Jul 11, 2011 | Computers & Internet
Tip
Sony ebook Reader is Frozen, Not charging
The Sony Reader used a special type of display; the LCD can retain an image without having power. It takes power while changing the pages. In most of the cases, if the power is fully discharged, the LCD will keep the last image that was displayed it makes an impression that the Reader is frozen. However, the Actual thing is, the screen retains the last image on the screen and there is no power to change the pages. These type of situations can be resolved by charging the Reader sufficiently.
Each step in my solution is a possible resolution. Hence I suggest thatyou perform each step and check the operation.
  1. Charge the battery fully by connecting to a computer or by using a compatible AC Adaptor. It may take a few minutes (up to 15 minutes) to displaythe charging symbol if the Reader is fully drained in its last use.
  2. Once the reader is charged fully (at least 45 minutes), slide the power button to turn ON.
  3. Perform a softreset. We can perform a soft reset by pressing the reset button on the Reader.
  4. After the RESET button has been pressed, slide the POWER switch to activate the Reader device again. If the Indicator light nextto the power button on the Reader device is yellow, the unit is attempting to start up. If this is the case, allow it a few moments to complete startup.
  5. If the Reader is still not charging up properly, connect the Reader to computer or AC Adaptorand then press the reset button.
  6. Disconnect the Reader device from the computer (if applicable) and then slide the POWER switch to activate the Readerdevice. Check if the Indicator light next to the powerswitch on the Reader device is yellow (indicating it is turning on) and if the unit is responding.
    If the unit isstill frozen, connect it again to the computer or AC adapter and while connected,check if the Indicator light next to the power switch on the Reader device is red. If this light is red , allow the Reader device tocharge for one hour sothere is sufficient charge for troubleshooting.
    If the issue persists, perform a hard reset to resolve the issue. Please follow the steps to perform a hard reset:
    Under certain circumstances, moisture condensation can occur. Moisture condensation can becaused by moving the Reader device between temperature extremes or if theReader device has come in direct contact with moisture. If you suspect moistureas the cause, allow the Reader device to sit for a few hours before attempting to turn it back on.
Reader is frozen, PRS650 frozen, image stayed in PRS650, Help to reset PRS 650. RESET PRS650. how to reset PRS-650. Hard reset PRS650. How to perform a hard reset for PRS 650. PRS650 freeze, PRS-650 frozen.PRS-650 is not charging, does not turn on PRS 650, PRS650 is not turning ON. PRS-650 does not charge.
on Jan 12, 2011 | Audio Players & Recorders
Can't get to booklist won't respond to touch
Hi!
You can try hitting the reset at the bottom for 3 sec. and then slide the power switch.
If the unit gets froze you can try the following:
GoodLuck!
eBookBoy
http://digialreader.freeforums.org/
Aug 04, 2011 | Sony Reader Touch PRS-600
It is stuck on low battery screen and charging light won't come on.
Hi imrydn!
You can try these steps:
2. Hit the reset button for 3 seconds at the bottom
GoodLuck!
eBookBoy
Aug 01, 2011 | Sony Reader Touch PRS-600
When i turn on my prs 300, the screen flickers and the light on top is yellow. when its done trying to turn on the light flashes a few times and thats it.. i've tryed several computers and they cant...
Hi jmjohnson198!
GoodLuck!
eBookBoy
Jul 16, 2011 | Sony Reader Pocket PRS-300
Won't charge fully
Hi jbanfill12,
To fully charge the reader it will take approximatelly 4 hours using a PC and 2 Hours using the wall charger ACS5220 for your PRS600.
Note: Make sure the computer does not go into sleep mode, if so, then the battery of the reader will drain out instead of charge.
eBookBoy
Jun 11, 2011 | Sony Reader Touch PRS-600
My sony ereader prs-650 is stuck on sleep mode and it wont do anything ,, it wont charge when connected to the computer
Each step in my solution is a possible resolution. Hence I suggest that you perform each step and check the operation.
Charge the battery fully by connecting to a computer or by using a compatible AC Adaptor. It may take a few minutes (up to 15 minutes) to display the charging symbol if the Reader is fully drained in its last use.
Perform a soft reset. We can perform a soft reset by pressing the reset button on the Reader.
After the RESET button has been pressed, slide the POWER switch to activate the Reader device again. If the Indicator light next to the power button on the Reader device is yellow, the unit is attempting to start up. If this is the case, allow it a few moments to complete startup.
If the Reader is still not charging up properly, connect the Reader to computer or AC Adaptor and then press the reset button.
Disconnect the Reader device from the computer (if applicable) and then slide the POWER switch to activate the Reader device. Check if the Indicator light next to the power switch on the Reader device is yellow (indicating it is turning on) and if the unit is responding
If the unit is still frozen, connect it again to the computer or AC adapter and while connected, check if the Indicator light next to the power switch on the Reader device is red . If this light is red , allow the Reader device to charge for one hour so there is sufficient charge for troubleshooting.
Under certain circumstances, moisture condensation can occur. Moisture condensation can be caused by moving the Reader device between temperature extremes or if the Reader device has come in direct contact with moisture. If you suspect moisture as the cause, allow the Reader device to sit for a few hours before attempting to turn it back on
Jan 12, 2011 | Sony Reader Touch PRS-600
How do I download music to my sony reader prs 650
Personally, I find the Digital Library interface for Sony is slow, cumbersome and irritating.
I found the quickest and easiest way to get files on to the e-reader is to load any files you want to use on to a SD flash memory card on your PC. Then, make sure your e-reader is totally switched off, not just in "Sleep" mode. To do this slide the "Off" switch over and hold it for 2-3 seconds and confirm "Yes" when asked. Then insert the SD card in the e-reader. When you power up the reader again you will find the files show up in menu system of the reader.
Oct 26, 2010 | Sony Digital Reader Touch Edition
Compaq Presario stuck in sleep mode
Connect the monitor to some other computer, e.g., a notebook, and see if it does the same thing. If it does, then the monitor is the problem.
If it does not, then your computer is not putting-out any "video" signal, and so the monitor goes to "sleep".
If you have MORE than one VGA-output port on your computer, connect your monitor to the "other" VGA port.
Or, press-and-hold the ON/OFF button on your computer, to force it to completely shutdown.
Jan 13, 2010 | HP Pavilion a1710n (RK573AA#ABA) PC...
Sony Reader Touch PRS-600 Logo
495 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
