Question about Dremel Garden
380-6 model I have a dremel that is quite old probably mid 1995ish hardly used it though/ Finally decided to use it and last night I was cutting into a dried gourd and all of a sudden I have a pop a flash of light and lots of smoke and now I have a non working machine. Do you think I burnt out the motor or is there something else that is minor> and do you think it is fixable.....or worth fixing. Any info would be greatly appreciated.
    Top Expert:
  • Dremel Master
  • 51,186 Answers
Sadly it is not worth trying to fix just get a new one
Posted on Jun 25, 2017
catriver
  • 878 Answers
SOURCE: Dishwasher
Tom, three things you want to check. 1. the heating element. Remove the leads from the element and ohm it out. Should read between 11 and 31 ohms. 2. Check the high limit thermostat. This sits right behind the drain pump on the right and inserts into the tub housing. Remove the leads and check for continuity. 3. The vent wax motor is inoperable. Check for continuity on the wax motor terminals. You can also put the dishwasher into a service mode to check the operation. In this sequence press high temp scub-energy saver dry-high temp scrub-energy saving dry. This will put it into a auto test mode. Let it do it's thing. If you need any further details, you can email me at catriver1@gmail.com Catriver..post back.
Posted on Mar 19, 2007
welcomejee
  • 10594 Answers
SOURCE: Pop sound, flashing standby light, blank screen
How many times this light flases in TV?
Posted on Aug 01, 2008
SOURCE: Ryobi pcn 4040 chain saw
I have the same model chainsaw with the same fault. The brake is not releasing when the brake handle is pulled right back. I can only run mine if the brake handle is pulled back to the main handle with a tyrap - defeats the object of the auto-brake completely. Design fault I reckon.
Posted on Oct 20, 2008
EsWorld
  • 1618 Answers
SOURCE: Gaggia Titanium - Cold coffee although producing steam.
The only thing that comes to mind is one of the thermostats on the boiler.
Posted on Jul 22, 2009
  • 52 Answers
SOURCE: start light flashes - lot of water in machine - she no work!
check to make sure the drain hose and filter is clear
Posted on Jul 26, 2009
Dremel 3000 stopped
My Dremel 3000 suddenly stopped working also. No idea where the receipt was so i decided to investigate. I found one of the two stator windings had blown. I'd Barely used the thing, so that's the last dremel I'll be wasting my money on.
Feb 01, 2014 | Dremel Tools & Hardware - Others
Dremel 4200 stopped working
No.. the issue issue is the switch inside. when your Dremel 4200 stop working, press firmly the grey area between the speed selector and the brush housing. I think this a defect in the design of the 4200. 9f840401-fb84-4f7b-8c68-75a9be3ceb9e.jpg
Dec 31, 2012 | Dremel Tools & Hardware - Others
I can't seem to get the attachment out of my dremel model 380-5. i do not want to damage the tool trying to get it out.
If you have loosened the collet, just tap the bit end on some hard wood which drives the bit inward a little and releases it. Tighten the new bit in the regular way. Hope this helps!
Nov 14, 2010 | Garden
Only runs for 3-5 seconds before turning off dremel stylus, with very little use
THIS SEEMS TO BE A MAJOR PROBLEM FOR DREMEL AND I AM SORRY BUT I HAVENT A SOLUTION (NEITHER HAS DREMEL). I AM A DOMICILLARY CHIROPODIST AND FOUND THIS ITEM ABSOLUTELY FANTASTIC FOR MY WORK...ORIGINALLY I RETURNED MY FIRST ONE WITH A COMPLAINT AND IT WAS REPLACED WITHOUT QUASTION ..HOWEVER IT HAS HAPPENED AGAIN AND MY ONLY SOLUTION IS TO ALWAYS CARRY TWO FOR BACKUP..WHEN I RECHARGE AT NIGHT THOUGH IT ONLY PARTIALLY RECHARGES BEFORE CUTTING OFF LOOKS LIKE I SHALL HAVE TO CARRY THREE......
Sep 02, 2010 | Dremel Stylus Rotary Tool
I have a dremel multi master that suddenly quit. my first one did the same thing I did kick the **** out of the first one and got my moneys worth. the next one died suddenly , wasnt overheated and used...
they do that a lot dont they? sorry all you can do is strip it down and see if there is a fault in it that an easy fix but normaly they just go in the bin when they stop working
Mar 27, 2010 | Dremel Multi Max Kit
How do you cut a slab from rock with the dremel? Do you run water over it while cutting
You can run a stream of liquid, (water or cutting oil) to reduce the heat, though it isn't always necessary. If you do use a liquid you'll need to be sure the cutting disc isn't to hot when you apply the liquid as the sudden temp change will cause the disc to fracture.
Mar 12, 2010 | Dremel 10 Diamond Cut-Off Wheels Saw Disc...
PS2 Reset button stays Red and won't change.
try this:
go here and go to the very end
www.powerfulguides.com/ps2
no model # was given
hope this helps :D
Jul 31, 2009 | Sony PlayStation 2 (PS2) Console
New Dremel 300 stopped working. What's wrong?
Something amazing just happened! On my monitor screen, window popped up that said, "ASK A QUESTION - LET OUR EXPERTS SOLVE YOUR PROBLEM FOR FREE".
I couldn't resist getting expert advice for free, so I clicked on the window. I was immediately taken to a magical world where I can pay for expert advice. I opted not to pay for expert advice. The next day, I was asked if the help I received was helpful. So here I am posting this response. I haven't received any expert advice yet, but when I do....!
Jun 14, 2009 | Dremel 395 Variable Speed Multipro Rotary...
Switch
Definitely not Home Depot. Try googling 'dremel model 395 switch', you'll probably come up with something. If not, there's always dremel themselves. This is a current model so there shouldn't be any real problem getting parts.
Sorry, don't know about installation, but I can tell you most of these dremels are real easy to fix in general, not complicated at all.
Jul 20, 2008 | Dremel Variable - Speed Multipro Rotary...
I have a 27 inch rca v. model # 27v513t.
How old is this TV?
My experiance is to not put money into a TV that is over ten years old. TVs stress out their electronic components worse than almost any other electronic product. After 10 years, there are so many parts that are ready to fail that your are probably wasting your money trying to get any more life out of it.
Another option is to wholesale replace the main board from an outfit like Module Exchange at 972-298-1212
Be careful on buying a new one though. Often times, these new technology ones are much worse. Always Google the model number of the set you intend to buy and add the word 'repair' or 'complaint' to see if it is one of the many models that are customer service nightmares being produced by even the most reputable companies today.
Hope ya fix it!
Jan 07, 2008 | RCA 27V530T 27" TV
Garden Logo
213 people viewed this question
Top Dremel Garden Experts
Clyde Ottaway
ray gallant
Are you a Dremel Garden Expert? Answer questions, earn points and help others
