Question about Velocity Micro Cruz Reader R101 Tablet PC
Just bought a cruz reader r101....usb says device not recognized. I am on XP sp3
  • 4 Answers
Before you can communicate with your computer you must run CruzSync from the desktop. There are some driver files that must be sent from cruz to point the way to the reader. After you do this it should connect every time. Some time you will have to pull the USB out and put it back end, especially if the reader or the computer has just woke up from a sleep or hibernation mode. ZumoDrive is the account you must set up when you click or press on CruzSync to make all of this happen. Hope this helps
Posted on Jan 02, 2011
PROBLEM WITH TABLET CRUZ READER R101
To update the firmware you can follow the directions here http://www.ehow.com/how_7890482_update-cruz-reader-firmware.html
I used a similar method when I had my Cruz Reader R101. This process is called "side-loading"
You will have to download a file to your computer (not your tablet), remove the SD media card from your cruz, then transfer the downloaded file from your computer to it, then replace the SD card to your cruz.
Also you can download the user manual here http://www.retrevo.com/support/Velocity-R101-Tablets-manual/id/23894dj696/t/2/ which shows how to remove the card, and this is a great reference to keep on your reader. For example, page 14 shows how to transfer files to and from your reader. Good luck!
Jul 21, 2012 | Velocity Micro Cruz Reader R101 Tablet PC
I forgot my lock pattern on my cruz reader
If you are running Android on the Cruz Reader and you have set up your Gmail account on it, then the reset is pretty simple. If you enter the pattern incorrectly several times, and option will come up for resetting a forgotten password. If you select this option, it will ask you for the username and password to the Gmail account that is set up on that device. Hope this helps and good luck!
Mar 03, 2012 | Velocity Micro Cruz Reader R101 Tablet PC
How do i unlock my cruz reader
Update your firmware... Go to cruz reader website and follow the directions on updating or downloading firmware... This worked for me... Unlocked and brought cruz back to factory settings good luck
Dec 17, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
HOW DO YOU DOWN LOAD MUSIC ON THE CRUZ TABLET?
Hi there:
Please refer to page 13 of this guide. It tells you how you can transfer files from your computer onto your Cruz Reader. You can transfer all your songs this way:
http://s3.velocitymicro.com/vmcruz/R101/manual/ReaderGuide12-30-10.pdf
If you need additional help feel free to leave a comment here.
Sep 08, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
When i plug in my velocity cruz reader into the usb port it tells me that the USB Device Not Recognized?????
Chances are the reader is defective. Try to plug it into another computer to confirm this. If it works try another USB device to confirm that the port is working.
Jul 21, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
My Velocity Micro Cruz Reader (R101)'s screen appears to be frozen... It just shows the "CRUZ" logo and stop loading after that... What should I do?
press power button in for about 6/7 seconds then start again,should reset.Otherwise corrupted installation ,,re-installl OS.
Jul 15, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
Hi, my reader is saying "android.process.acore has stopped" Force closing won't work. I know firmware update via zip file is available but it's midnight here and I don't have an sd card handy....
Sorry to hear your are having issues with your Cruz Reader. I have a Cruz Reader R101. Unfortunately you have to update via the SD card for the Cruz Reader. It doesn't do a firmware update from the USB cable.
If you don't want to try and update it now you could also try to just restart it. If you can't get it to restart normally you can remove the back cover and unplug the battery, then plug it back in.
Apr 25, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
Where do I download a driver for my 2.0 adroid tablet.
hi click link here and it will take you to the cruz site where you can download the usb drivers for your device..
http://cruzsupport.velocitymicro.com/ics/support/default.asp?deptID=5758
hope that helps
Jan 14, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
How do i get it to connect to my computer to get files from there?
Plug in the USB cable. My Vista machine recognized the Cruz as an external storage device (like a flash drive) and displayed a folder for the internal 4gb flash and another folder for the 2gb SD card I added. You can't access the folders from the Cruz while the PC is connected but you'll see any files you copy over once the cable is disconnected. (use Astro to view files in the folders)
Jan 05, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
I turned the Cruz Reader off and I can not get it to turn back on. I tried to charge it but no light will come on. Any suggestions?
Taken from Velocity Micro Support Center:
What should I do if my Cruz device will not turn on?
If your Cruz device will not turn on or freezes, follow the steps below to resolve this:
  • Locate the Cruz RESET location between the Power Button and mini-USB port.
  • Using the straightened end of a small paperclip, insert it perpendicularly into the RESET hole and hold for 5 seconds.
  • Turn on your Cruz
If the steps above do not allow you to power on again, then continue with the steps below:
  • Remove the Cruz from the charger and eject the External SD card.
  • Place the Cruz face down on the desk, starting at the External SD slot, pull off the back cover of your Cruz.
  • In the lower left corner of the back of your Cruz, locate the battery power cable. Unplug the cable and replug it again.
  • Return the back cover to your Cruz and snap it into place.
  • Re-insert your External SD card and power on your Cruz.
Jan 02, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
Velocity Micro Cruz Reader R101 Tablet PC Logo
1,891 people viewed this question
Top Velocity Tablets & eReaders Experts
 Mikey
Mikey
deton8 von Splosion
Are you a Velocity Tablet and eReader Expert? Answer questions, earn points and help others
