Question about Goodman Heating & Cooling
Burners come on every 60 seconds untill temp is reached.
  • 1,420 Answers
How long does the flame stay on for? Seconds or minutes?
Posted on Jan 02, 2011
Model sf35f furnace wont quit heating after reaching thermostat setting
Sounds like the heat anticipator in your thermostat is either bad or out of adjustment. Turn of the furnace power. Remove the thermostat wires from the thermostat. Turn the power back on. Connect the white and red wires together. The furnace should start up. Let it run a couple of minutes. Then disconnect the wires. The burners should shut off immediately. The blower will continue to run for 60 to 360 seconds then shut off. If this happens replace your thermostat. If the burners continue to burn, then your problem is either the furnace or the thermostat wires.
Sep 12, 2014 | Heating & Cooling
Tip
How to change temperature sender on AUDI 1.9 TDI
The specific location of the sender is on back of cylinder-head near by vacuum-fuel double pump. There is an assurance clip and a rubber sealing O-ring. Heed of antifreeze solution temperature!!!
Before you try to change the sender you must be sure that the sender is out of order. First you must check the thermostat operating. Thermostat checking:
1. Cold engine. Start up the engine and watch of the water temp indicator. After first value 60 Celsius Degree you still warm up the engine until the lifter (pointer) reach 80 C deg. (second mark after 60 C deg.). At this time you let engine running at idle speed and check with your hand the thermostat plastic housing and hose temperature in bottom left side of the engine. Heed of alternator driving belt and ventilator fan !!!
2. If the thermostat is good the hose must be cold until the water temp indicator reach almost 90 C deg.
3. The thermostat opening temperature is 87 C deg.
4. If the hose is already warm the thermostat is out of order.
5. If the thermostat and the temp sender are OK the last piece out of order will be the instrument cluster.
on Dec 19, 2009 | Audi A4 Cars & Trucks
Tip
How to change thermostat on AUDI 1.9 TDI
You must check the thermostat operating. The thermostat location is on back of alternator at the bottom side of the bracket. IMPORTANT: It is NOT necessary to replace the alternator if you want to change the thermostat !!!
Audi a4 1.9 tdi thermostat diagramm
First time you might check the thermostat operating.
Heed of antifreeze coolant temperature!!!
The thermostat location for a 2000 Audi A4 1.9 TDI is on back of the alternator at the bottom side of the bracket.
IMPORTANT NOTE: It is NOT necessary to replace the alternator if you want to change the thermostat !!!
Thermostat location, Part number: 044121113, in german - "Kuehlregle" (Price around $25):
Important note: Always replace the thermostat round seal, position 7 in the above picture.
Jul 06, 2011 | 2000 Audi A4
Where is the thermostat located on golf v1 1999 1.6,car been standing 6 months worked fine now water not circulating!!!!!!
The thermostat location for VW Golf 1.6 is inside of coolant thermostat housing placed on back side of the cylinder head. See pictures below.
Thermostat location, Part number: 032121110B, in german - "Kuehlregle" (Price around $20):
Important note: Always replace the thermostat round seal, position 6 in the above picture.
Please do rate my response. Thanks!
Jan 29, 2011 | 2001 Volkswagen Golf
I need to change the thermastat ,,, where is it and whats the easiest way
You must check the thermostat operating. The thermostat location for 1997 Audi A4 1.9 TDI is on back of alternator at the bottom side of the bracket.
Dec 04, 2010 | 1997 Audi A4
Where is the thermostat on an Audi A4 diesel, 1998
Feb 22, 2010 | 1999 Audi A4
Burners shut down at set temp but fan continues lowering temp
the reason he told you not to cycle the power is because some where there is a flashing light that he can decode and tell him where to start looking for the problem. Call him next it happens and don't touch the power or the stat until he gets to see the unit.
Aug 03, 2009 | Heating & Cooling
Heater cycles on and of, pool/spa does not reach desired temp
hello, It sounds like you may not be getting circulation thru the heater. Make sure the valves are open to allow water to pass thru the heating system. Some systems use a bypass on the heater so there is not a lot of wear on the coil system in the heater. If it is not circulating it will get too hot and the safety shut down will occure. If you are getting water circulating thru the heater, then the thermocouple or auto start igniter system is not working correctly. It is trying to start and can't then recycles. If the burners are igniting on the startup and then shutting back down you may have a bad control unit or thermal sensor unit. Since the unit is gas have a professional service it for you. Good Luck, RAC
Apr 20, 2009 | Pentair Mastertemp Heater
Heating & Cooling Logo
11 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
