Question about Sharp R-9H66 Microwave Oven
How to replace a fuse on my sharp r-9h66 model microwave?
    Brigadier General:
  • 8,909 Answers
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Posted on Jan 02, 2011
Sharp R402JK-T sparking on starting
Unplug the unit and do not plug it back, I can almost picture someone doing this, watching the sparks and smoke and oh the lights dim--Be smart here===either replace it out of hand or take to a repair shop to see if worth fixing or not and do not attempt to turn it on again.
Dec 12, 2012 | Sharp R-9H66 Microwave Oven
My microwave convection touch pad is not workin
The touch pad control board will need to be replaced, I recommend a professional to assess the rest of the oven.
Apr 07, 2012 | Sharp R-9H66 Microwave Oven
I need to replace the monitor switch on my Sharp R-9H66, I'm not a 100% sure which switch it is. The diagram on the microwave shows it in the middle but the part that is being sent to me looks a little...
This model is obsolete, so information is hard to find.
Until the keypad (which is no longer available) finally fails, though, it's worth replacing other parts.
These were great old units.
The monitor switch will usually be in the middle near the fuse.
Assuming there is not a lever on your monitor switch, a universal type will do.
If there's a lever, you may need to break the old switch apart and move the lever to the new switch. See this video for instructions.
See these files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
May 25, 2011 | Sharp R-9H66 Microwave Oven
Carousel will not rotate
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 22, 2010 | Sharp R-9H66 Microwave Oven
For a 1995 Sharp Carousel Convection Microwave oven Model # R-9H66 it has on display screen ''LOCK'' and will not allow any function, is there a solution? The light inside works when the door is opened...
Check the user book for the unlock code. This could be the child lock mode.
If one of the safety switches are defective, or if there is a sensed power supply fault, the uPC will put the oven in the lock mode for safety reasons.
Jerry G.
May 12, 2010 | Sharp R-9H66 Microwave Oven
Oven just went dead, no lights, no power etc. checked power source and everything works fine. Sharp Model R-9H66. looking for repair in spokane , WA..can you help?
Possibly the internal fuse. Unplug unit, remove all case screws on the back of the micro. Slide the case toward the back and remove. Look for a glass tube type fuse, simular to automotive fuses of the past. It should be located near the controls. If bad, the internal wire will be broken or burned, I have been able to find replacements at Radio Shack. Take the old one with you. If the fuse is good, I'm sorry, it's beyond my microwave knowledge level.
Mar 03, 2010 | Microwave Ovens
Microwave Will not Run
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
You will need to remove the outer cover, then shut the door and then you can adjust the door latches.
Dec 26, 2008 | Sharp R-9H66 Microwave Oven
Sharp carousel under counter microwave start doesn't always work
Sounds like an intermittent door switch or a loose door switch mount. Very common.
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Oct 14, 2007 | Sharp R-9H66 Microwave Oven
Microwave Ovens Logo
120 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
