Rig'n'Roll stops working once in a while. It also lags or pauses for a few seconds. It can take a long time for the game world to load near Los Angeles and Reno. There's also invisible walls near Los Angeles and Reno. Why do you think Rig'n'Roll stops working sometimes? My computer specs are: Windows Vista Home Premium 32-bit 2.00 GB Ram NVIDIA GeoForce 6150SE nForce 430 Hard Drive Space: 144 GB
harshavarma
  • 59 Answers
SOURCE: cannot load "arthur" with widows vista home premium stops installing
Hello... Please go thru this. Souce:http://www.ataricommunity.com/forums/showthread.php?t=573497
I may have a work around
It is a way to give admin privs to the msi file
First, create a file called Arthur.bat
- Open a folder, say C:\temp
- Right-click and select new, Text Document
- name it Arthur.bat
Next, edit the file
- right click the file and select edit
- put this in the editor ... msiexec /a d:\Arthur.msi
- save and exit
Then, right-click the file and select "Run as administrator"
Worked for me.
There is another msi file (ISScript11.msi) on the CD which I didn't run which may be needed ? But, I managed to play through the tutorial/start so ... we w ill see.
So, it is a permissions thing. Hopefully this will get passed on to the developers and they can resolve it tout-de-suite
Posted on Nov 03, 2008
  • 21 Answers
SOURCE: Vista Home Premium fails to
you will have a very hard time finding drivers for xp. dell will not support and dell does not have drivers for xp for your system. try vista sp1. i have no problems with my 1530
Posted on Jan 18, 2009
  • 1602 Answers
SOURCE: visiontek hd 2400 pro game graphic lag
most computers systems have certain drivers configuration setups for certain games so you dont have that problem.
control panel, open up personazation,open display setting, find advance setting, open the folder that matches the type of graphics card you are using.
open the control center
3d settings
game setting
display options
avivo tm video
power players
graphics: hardware & software options
rod
Posted on Feb 26, 2009
SOURCE: I have an HP imedia
I fitted HD4350 512M DDR2 PCI-E ATI RADEON CARD IN SPARE SLOT, GOT IT AT PC WORLD.
Posted on Oct 22, 2010
RyanFanMan
  • 342 Answers
SOURCE: Here's my issue. Ok i
the issue may be the ram is not the same like a PC100 will not work with a PC300 ram card but if you have the same like a 2GB DDR2 and a 1GB DDR2 it will work unless your computer can only see 2GB of ram then i cannot help you
Posted on Jan 02, 2011
I have linksys 54g v8 and i am haviing a issue connecting to second life
That may be a game issue. It's a on-line game, right? Does the computer lose a signal? Once the connection is out in the cyber world, anything could disconnect you. Have you tried the games support? I don't think it's your equipment. If your devices stay connected to internet, in general, then it would be second life.
Jan 22, 2013 | Linksys Wireless-G WRT54G Router
Hi i have downloaded Rig n Roll on my laptop, vista home premium. In game play it keeps starting and stopping, so i restarted my laptop and now when i come to start it all my icons and everything inlarges...
I try to look at your issue but, when I visited the Rig-n-Roll site my pc acted weird, I think that site has a virus on it. I would recommend that you remove it, and try purchasing it from a store instead of downloading it. Good Luck!!
Jan 22, 2011 | Video Game Consoles & Games
The printer is not printing receipts and the error indicator is blinking on and off, what is the solution to this?
Flashing (approx. once every second): Out of paper
Flashing (approx. twice every second): Mechanical error (Buzzer sounds once.)
Most likely your paper feed is giving you the error. Remove the current feed, ensure there are no paper jam & insert fresh paper.
If
Mechanical Error :: Quick blinking Buzzer Sounds continuously for a pprox. 1 second :: Reset the Power
switch
Paper End Blinks.:: Buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Paper Near End Blinks.(Once a second) :: buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Mechanical Error : If the printer mechanism has a greater load due to a paper jam, etc., the buzzer will sound and the SEL/ERROR lamp will blink to stop the printer mechanism.
Paper End : If the printer has run out of paper, the paper sensor in the paper path near the print head will detect the end of the paper roll, turn on the buzzer, and blink the SEL/ERROR lamp to stop the printer mechanism. If the paper is inserted into the paper path, the paper will be loaded.
Paper Near End : If the paper is running out, the paper near end sensor will be activated to turn on
the buzzer and make the SEL/ERROR lamp blink. Even after the paper near end is detected, a command can be used to print by the specified number of lines. (See a description on the command for setting the number of print lines after paper near end detection)
Finally
Backup Data Clear : When the power is turned on, depending on the SEL switch operation, the
backup data in the input buffer will be cleared according to the flowchart on the next page.
To clear the input buffer, turn on the power while pressing the SEL switch.
The following messages will be printed.
"Clear Data in Buffer"
"Cleared Data in Buffer"
To print the data in the input buffer, simply turn the power on.
The following message is printed and the data in the input buffer is printed.
"Power Down(Data in Buffer)
Dec 13, 2010 | Citizen iDP-3550 Matrix Printer
Having problems with playing video's on my computer via websites (news page etc) will work for @ 10 seconds then pause for @ 30 seconds then work for 10 seconds and continue to repeat this process I have...
Videos on websites need time to load before they will play seamlessly. When you first load the video, pause it and wait for a few minutes. You may see a bar loading across the part of the window that shows how much has loaded. This will take a few seconds or a few minutes depending on how fast your internet connection is.
Jul 19, 2010 | Dell Dimension 2400 PC Desktop
Does my 360 have a disc drive issue?
The lag you're experiencing most likely isn't the result of any physical abnormality, but rather you're network. How many people in your household share the same network? The more people on a network, the slower it will run. (I've actually experience this first hand) You might have too much people sharing your network for your game to run smoothly. Try to go on hours that everyone is not on. As for the repeated starts and stops, during game play, don't stress that. Its normal.
Jun 20, 2009 | Microsoft Xbox 360 Console
Do I have a disc reading issue?
try to clea the Disk that you are using then try also to insert other disk that is working to check if the problem is the disk itself. Only then if the result is the same then the problem would be either the Player hardware or the Support software maybe its corructed or not compatible to the disk you want to insert. Then if the hardware has a problem contact the PS3 repairshop in your place. But if the support software has the problem then you can update it or reinstall your software support in your PS3.
Hope it helps your problem.  If you need more assistance just conatc me or reply to this post.  Thanks you
Jun 19, 2009 | Microsoft Xbox 360 Console
Call of Duty World at War - PS3
Well here you to go the answer to your problem is.....................................1. Sign out of your playstation account.2. Load game (the game will load fine without being logged in.3. Stop at the start menu do not press start when it is blinking "Press Start to Continue"4. Tap the Ps home button and log on to your account.5. After logging on hit the ps button to return to the game and hit will play fine.
Apr 25, 2009 | Dmm Call of Duty: World at War
360 acting strange
it sounds like 3 red lights are around the corner. my advice would b 2 keep playin it till it gets the red lights then send it in 4 a free fix.
Jan 01, 2009 | Video Game Consoles & Games
Gh world tour mic has terrible lag
Yes, unfortunately, USB ports just aren't fast enough for live vocals. Some stereo setups have longer lag times than others, as well. A couple of ms is very noticeable. Have you tried adjusting the settings on the game? Go to "Options" on the Home Screen and select "Calibrate Lag." Here you can delay either your Audio or your Video in 1 ms increments to try to adjust for lag times. You may find a happy medium after adjusting these settings.
Dec 28, 2008 | Activision Guitar Hero World Tour Guitar...
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
