Loop back with test plug: Fail RAM tes: Pass ROM cHECK SUM = 239E: Pass
SOURCE: bios rom check sum error (report)
may be your os is correpted
Posted on Mar 17, 2009
  • 788 Answers
SOURCE: HP Pavilion zv6000 cycles through POST over and
You have your Lan Boot ROM loading.
Enter your BIOS and set to default.
Save and exit.
Posted on Oct 22, 2009
TechnoMarine
  • 132 Answers
SOURCE: Linear rudder refernce Furuno 500 auto pilot will not pass test?
light on board is probably normal no, this is an inductive pickup, can not test with ohmeter, sorry. Test with display, observing rudder angle display. Do rudder setup repeatedly until it works, it is a little fussy for placement and clearance but patience and the correct "bracketry" will make this pilot perform great.
Posted on Jan 18, 2010
jsmes1027
  • 749 Answers
SOURCE: high nox fail smog test any remedies? 99
NOX is created when the internal combustion temperature gets to high.The egr system uses burnt exhaust gases to line to cylinder walls.The purpose of this is decrease internal combustion temperature therefore reducing the amount of NOX created.Would look to a possible egr malfunction usually they will trigger the check engine light but not always.The 4.3L has been known to have issues with carbon buil up in the egr and the egr pintle not open and closing properly.
Posted on Jun 07, 2010
Geekman
  • 32281 Answers
SOURCE: pxe-e61
PXE-E61 ERROR
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Posted on Aug 07, 2012
08 CHEVY EXPRESS VAN NO POWER TO THE FUEL PUMP, CONTINUITY TEST FROM RELAY TO PUMP OK
Sounds like ur having issues with a dodgy pump there m8. Check all ur cabling loop an relays as it cud be a weak connection sumwhere as it cud still pass continuity check as its still putting a small amount of current thru the loop but just not enough to kick pump over. Also check for frayed or bare wires any where in the loom cos if its earthing out sum where it will given the exact same results u just mentioned m8. Wud defo b my 1st port of call bud
Oct 26, 2016 | Cars & Trucks
Tip
Samsung Secret Codes its work for all SAMSUNG USER..
*#*#4636#*#* phone information *2767*3855# hard reset **#*#7780#*#* factory reset ***#*#7594#*#* change end call/power option *#*#197328640#*#* service mode *#*#273283*255*663282*#*#* file copy screen (backup media files)*#*#526#*#* wlan test *#*#232338#*#* shows wifi mac address *#*#1472365#*#* gps tes t*#*#1575#*#* another gps test *#*#232331#*#* bluetooth test *#*#232337#*# shows bluetooth device address *#*#8255#*#* gtalk service monitorcodes to launch various factory tests:*#*#0283#*#* packet loopback *#*#0*#*#* lcd test *#*#0673#*#* melody tes t*#*#0842#*#* device test (vibration test and backlight test) *#*#2663#*#* touch screen version *#*#2664#*#* touch screen test *#*#0588#*#* proximity sensor test *#*#3264#*#* ram versioncodes to get firmware version information: *#*#4986*2650468#*#* pda, phone, h/w, rfcalldate *#*#1234#*#* pda and phone *#*#1111#*#* fta sw version *#*#2222#*#* fta hw version *#*#44336#*#* pda, phone, csc, build time, changelist number
on Jul 11, 2011 | Cell Phones
Dell inspiron m 5030 7 beep code
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Nov 10, 2012 | Dell Computers & Internet
How to fix? Dell mini inspiron 10. Its has a 8 beeps. Failure displays.
DELL BEEP CODES
Nov 09, 2012 | Computers & Internet
Dell studio 2 beeps
DELL BEEP CODES
Oct 18, 2012 | Dell Studio Xps 9100 Desktop Computer
7 beeps will not come on
DELL BEEP CODES
Oct 13, 2012 | Dell Computers & Internet
No display ma mother bord how to test sum coponant or chip level
Refresh the connections to the motherboard (HDD and CD/DVD ROM cables) and clean the RAM as shown in the image below:
Hope this helps.
Oct 13, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
When i'm turn on my pc this message would appear ''bios rom chesum error'' what should i'l do?
the ram has some error
better remove the rom blow air to it wipe it wit a clean soft  material
then replace the same
Mar 06, 2009 | Computers & Internet
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
General Use
The self-tests are described in the manual
Testing Calculator Operation . . . . . . . . . . .. A-9
Self-Test . . . . . . . . . . . . . . . . . . . . . A-I0
Keyboard Test . . . . . . . . . . . . . . . . .. A-ll
Port RAM Test . . . . . . . . . . . . . . . . .. A-12
IR Loop-Back Test . . . . . . . . . . . . . . .. A-13
Serial Loop-Back Test . . . . . . . . . . . . . .. A-14
You can download the manual from hpcalc.org or the HP website.
I would personally include photos of the screen during the test (e.g. "KBD OK").
Nov 28, 2007 | HP 48gx Calculator
22 people viewed this question
k24674
