When i turn on my dell vostro a860 the screen is black.When I plug in external monitor shows pictures on both (monitor and laptop).When I disconnect external monitor the laptop works fine.The trouble is only when I turn on laptop I dont see anything just black screen.I must always conect and disconnect external monitor to work properly. Problem is on WINXP and WIN 7 Best regards Dejan
  • 27 Answers
Check your "display setting" and make sure your laptop monitor is set as the defaut monitor and not the extended. What you describe is that your laptop is using the extenal monitor as the default and your laptop as the extended.
To get to your display setting for
Win XP: just right click anywawhere on your desktop and click "propertery".
Win7: right click anywhere on desktop and click "personalize"
Once there, click on your "monitor" tab. You should see a drop down of the monitor thats connected. Choose your laptop monitor from the dropdown. Under the dropdown list make sure there is a check on "make this my main monitor"
Click the "OK" button and reboot.
Hope this help.
Posted on Jan 02, 2011
    Guru:
  • 2,178 Answers
Windows Vista® 1 Right-click an open area of the desktop. 2 Click Personalize. The Personalize appearance and sounds window appears. 3 Click Display Settings. 4 Select the external LCD monitor in the drop-down menu.Monitors and Displays 51 5 In the Display Settings window, move the Resolution slider bar to the left or right to select a screen resolution that matches the native resolution of the external LCD monitor. 6 Click OK. Windows® XP 1 Right-click an open area of the desktop. 2 Click Properties. The Display Properties window appears. 3 Select the Settings tab. 4 Select the external LCD monitor in the Display drop-down menu. 5 Under the Screen resolution section, move the slide bar to the left or right to select a screen resolution that matches the native resolution of the external LCD monitor. 6 Click OK.
I tried to clean the dell vostro 1014 fan, after i assembled the fan and turned on the laptop it appear black screen with dim image on my laptop screen, When I plug in external monitor it shows boot s
It sounsd like your GPU may be BGA chip and would require a re-flow/re-ball if your laptop shows graphical distortion on both monitors.
However I would first try taking the laptop apart again and double check you have connected everything properly.
Mar 20, 2014 | Dell Vostro 1014 Laptop Computer
Dell vosrtro brightness off
Maybe your LCD Inverter is going bad or the screen is going bad.
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 05, 2012 | Dell Vostro A860 Notebook
When i turn on my dell vostro a860 the screen is black.When I plug in external monitor shows picture only on external monitor. No boot screen when turning on, nothing, only sound that windows loaded.
Since you say the screen was blinking when you opened or closed the lid: 1) It could be as simple as the cable that attaches on the back of the monitor is loose and needs to be reseated (pulled out and plugged back in) then secure it with tape where the connections meet. 2) It could be that the cable from the monitor that plugs into the motherboard needs to be reseated. You'll need to disassemble the monitor to remedy the 2 problems mentioned. And for problem 2 mentioned you'll need to remove the Keyboard and Palmrest.
Have you shined a flashlight on the black monitor screen to see if you can faintly see images on it. If so, then the problem is your LCD Inverter. You can purchase them for less than $10, but you'll have to disassemble the lcd screen. It sits at the bottom of the lcd screen just above the keyboard.
If you don't see anything when you shine the flashlight on the lcd screen, then your screen is out and will need to be replaced.
Get a quote from your local computer shop, then try these guys:
httpp://www.generalsystemsconsulting.com
They will fix it and ship it back by Fedex or UPS and beat most quotes including the shipping.
Mar 22, 2012 | Dell Vostro A860 Notebook
My dell vostro a860, when i plugged adapter its showing me plugged in not charging and continuously battery is not charging.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jan 26, 2011 | Dell Vostro A860 Notebook
My Dell vostro A860 Laptop shuts off after 5 seconds that I have turned it on, the blue light showing that is has turned. The screen is black, I don't even get the boot up screen.
Its stuck on finding a bootable device. your PC has a virus or HDD is gone bad (unlikely). Try putting in the OS disk n boot for it.
Nov 02, 2010 | Dell Vostro A860 Notebook
My Dell vostro A860 Laptop shuts off after 5 seconds that I have turned it on, the blue light showing that is has turned. The screen is black, I don't even get the boot up screen. What will I do. thanks
Enter to bios after powering and watch if it still go off. If not, go to Healt or sensors section and watch the temperature of CPU and system. The computer might turn off because of overheating.
My Dell vostro A840 Laptop shuts off after 5 seconds that I have turned it on, the blue light showing that is has turned. The screen is black, I don't even get the boot up screen. What will I do. thanks
Need to reinstall windows, insert your windows disk and boot from it.
If that does not work buy/get a new AC adapter and/or battery.
if that gets you no where open the case area around the fan use a can of compressed air n blow it all out.
Dell vostro sound low,using windows xp
Dell Vostro does not have an entertainment integrated speakers. These are just small speakers designed for basic usage. You may connect an external speakers. For adjusting the volume, on the bottom right of your screen, beside the clock, click on the speaker icon and adjust the volume slide
Jun 14, 2009 | Dell Vostro A860 Notebook
Dell Vostro 1400 LCD Showing Black Screen
If you connected the laptop to an external monitor via VGA and the display, then it is not "an NVIDIA GPU defect" .
The video chipset connected to the LCD screen is the same connected to the external VGA port, and is working fine since picture is OK on monitor.
More likely the problem is either LCD ribbon cable, or LCD display, the fact that the backlight is working means that the inverter is also working.
Apr 18, 2009 | Computers & Internet
Computers & Internet Logo
380 people viewed this question
David Payne
David Payne
