Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have a crafstman garage door opener 1/2 H.P. Ichecked the sensors but there is lights red or green
    President:
  • 3,197 Answers
Are you having a problem with the opener or just checking the lights?
Posted on Jan 03, 2011
Why does the monitor's red and green light keeps blinking
Unplug, let it sit for a minute and plug back in. Ours does that when power is interrupted.
Sep 07, 2014 | Chamberlain UNIV GARAGE DOOR MONITOR
My crafstman garage door opener goes down and then
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear and is probably stripped.
May 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
We had a 1/2 horse opener with the model # 41A5021-3C in our garage .I put up another opener 41A3621 .Would like to know the wiring for the sensors and wall switch openers..The courtesy light comes on and...
The wiring should be.
Terminal #1 - White wire with red tracer from wall control.
Terminal #2 - White wire from wall control and a white wire from each of the sensors.
Terminal #3 - A white wire with black tracer from each of the sensors.
Apr 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remove the cover and check the drive gear. It could be stripped.
Mar 26, 2010 | Sears Craftsman LiftMaster Chamberlain...
My red light sensor is blinking constantly and the green light sensor is steady. I grab hold of the red light sensor and squeeze and the light goes solid and I am able to close the garage door. when i let...
It sounds like there might be a loose wire connection on the inside of the sensor. You could also be moving the position of the sensor slightly into alignment when you squeeze the sensor. You will need to disconnect the wires for the sensor on the garage door opener or disconnect the power. Then use a flatblade screw driver and carefully seperate the sensor case. Check for any loose connections on the wiring(you might need to re-solder the wire to the sensor eye). It sounds like a loose wire connection to me.
Jan 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
Crafstman 41A435-7A
If the board you say is broken is the one you got the part #41A4315-7A, that is the part number you need. You can get it at Sears or any good door service company.
Sep 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Garage door is not opening or closing. One of
depending on model, both are green or one green/one orange. that is not your problem, however you really do not give me much to work with. "It does not work". Does chain move? Does motor run? What is you hold wall pushbutton? Give more info.
Apr 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Wayne Dalton garage door will open with remote but not close. The only way it will close is to hold down the wall mounted garage door button. Then the light goes on and off while clicking. I have...
your infrared sensor is either misaligned, faulty, or you have a broken wire from your sensor to your door opener. (Flashing light indicates infrared light path is broken). both sensors should indicate green led. door wil not come down is safty feature to prevent door from closing when light path is broken.
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
74 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
