Question about Zyxel P660HW-D1 Router
I have a Zyxel wireless router and a Dell Inspiron. I can't get around having to type in the security key every time I connect. I have checked it to connect automatically, but still have to type in the key. Can anyone help?
    Brigadier General:
  • 4,044 Answers
You should have entered the key in the computer to setup the network and then save that connection. Check your setting on the Dell for that connection to make sure it saved correctly.
Posted on Jan 02, 2011
Cant connect to my dell inspiron 8100
I think you should check the wireless settings of your router first.
If your wireless network is secured then make sure that you have the correct wireless network key WEP / WPA .
If your router is too old then it will be better to upgrade the firmware of your Linksys router.
Jan 01, 2012 | Linksys Wireless-G WRT54G Router
I cannot get my new dell mini inspiron to connect to the linksys wireless router in the home network. it cannot even detect the network. How do I fix this?
Have you been able to connect your netbook to other wireless networks? Do you have anything else connected to your home wireless network? Can you see your home wireless network using a different computer?
If you can't see other wireless networks check to make sure your wireless card didn't get shut off. Usually there's an on/off switch on a laptop to do this, or a combination of function keys.
If you can see other wireless networks and just not your own, try the wireless network's settings on the router. If you do have some type of security, I'd start off troubleshooting with no security, then move up to WEP, then WPA, then WPA2 in that order, or at least as high as you can get with the options available on your router. It might be that your wireless network is too secure for what your Mini 10 can handle.
May 11, 2011 | Dell Inspiron Mini 10 Notebook
Hi, I have reinstalled my window XP SP3 but after reinstalling window my wireless(Adapter name: dell wirless 1395 WLAN mini-card) is not working properly. I have installed latest driver on my Dell...
Verify that you have the correct type of authentication in wireless- if your router is set to WPA2, then you would have to go under the connection properties > security tab to change it to match that setup. If that does not work, then the issue may be that the wireless card is defective and starting to fail.
Nov 22, 2010 | Dell Inspiron 1525 Notebook
Wireless key doesn't work
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Feb 22, 2010 | Zyxel Prestige 660HW Wireless Router...
My Latitude D610 Dell laptop is not connecting to the internet via my ZyXel broadcom router. In fact, the laptop doesn't even recognize the router or show the router as an option when I click on "Available...
1. Connect your router via LAN.
2. On your internet type in 192.168.1.1
3. Type 1234 on the password screen.
4. Go on the Wireless LAN tab
5. Un-check the option for Hide SSID
Dec 22, 2009 | Dell Latitude D610 Laptop Computer -...
ZyXel gives nothing
Can you go to http://192.168.2.1 in your browser? See if it brings anything up. You should see tabs for security settings. Also, you could "reset" your router back to factory defaults as well if no other option.
Jul 08, 2009 | Zyxel P660HW-D1 Router
How can I secure my zyxel Router P-330W at home?
hi...
you need to go to the computer which is connected wired to the zyxel box,in the computer click on start,run,type in cmd,and hit enter,on that black box type in ipconfig,hit enter,you wil get a list of result check default gateway(eg of default gateway is 192.168.0.1)go to internet explorer page,in the address box type in the default gateway without http or www,it will open the zyxel page for you,it might prompt you to put in the user name and the password,if it does then donot put anythingin the name of username and put 1234 as password,in this page you will see an option that says wireless,click on wireless and then click on advanced,under you will see the wireless security option where you can go ahead and make you wireless connection secured.
http://us.zyxel.com/upload/download_library/P330W_UG_V_1%201(5).pdf..this is a link for user guide u can download this to udnerstand other features that there in you router..
vedhick
Feb 26, 2009 | Zyxel P660HW-D1 Router
Can not connect to internet using wireless
Did you input the WEP key? I will assume you are using Windows XP. So go to control panel, network connections and then go to the wireless connection and then select view wireless connections double click on the one with the highest strength, which should be your 2wire. When it asks for the network security key type in the numbers that are located on the sticker on the bottom of your router between the [########] brackets.
Jan 16, 2009 | Dell Inspiron 1200 Notebook
TCP connection
hi i two laptop one is sony and is working perfectly with wire connecter to router n with wireless but i buyed another laptop toshiba and try router connection its working brilliant but when i try connecting wireless its keep asking me a network security key or passphrase for zyxel and under that it say the person who set up the password can give u the key or the passphrase
please help me my email is ashwaq_20002001@yahoo.com
Jun 18, 2008 | Zyxel Prestige 660HW Wireless Router...
Modem router
I can tell that your network topology is not the most complicated ever.So u ve got 3 terminals,1 desktop pc and 2 laptop.Simple,reset your zyxel(from the button on the back) and reconfigure the Local area interface connection(ip & subnet mask for the zyxel),reconfigure your internet connection,(WAN zyxel interface) in case the zyxel is your Internet gateway too.Third,make sure NAT & Firewall are up and running(usually are by default) Finally,reconfigure the WiFi interface with the correct SSID name & WEP key or whatever security you prefer.Write down the security pass for your wireless and you are done.Good Luck.
Apr 19, 2008 | Zyxel Prestige 660H Router
Zyxel P660HW-D1 Router Logo
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
