I have a Dell Inspiron 1520 laptop that has a dim screen while running on battery power. It is fine while plugged in to the charger. I have adjusted my brightness settings to 100% on battery and plugged in. What would you suggest I try?? Thanks for your help!!
    Brigadier General:
  • 4,044 Answers
This is normally a power saver setting. If you have all ready set your power saver options to correct this then your battery is weak.
Posted on Jan 02, 2011
    Brigadier General:
  • 8,909 Answers
That sounds like a setting in the Power Management section.
Right click on the battery icon and select Power Options and have a look at the brightness settings on battery also while there check Adjust Brightness as well.
Hope that fixes it.
Changing battery motherboard
Gciappa,
Dell Support > Inspiron 1520 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/ins1520/en/sm/index.htm
Click on Coin-Cell Battery in the right hand list.
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Suggest lay a soft static free cloth on the table you're working on. Helps prevent scratching the table, and laptop.
Turn the laptop over, Battery Compartment facing away from you.
3) Remove the Memory Compartment Cover,
http://support.dell.com/support/edocs/systems/ins1520/en/om_en/html/about.htm#wp1175774
(Number 2 - memory module/coin-cell battery compartment )
The RTC Battery is that small plastic 'bag', that has a Red and White wire coming out of it, and ending in a small white plug connector.
(Real Time Clock Battery. Term coined now for CMOS Battery )
Replace battery, close cover, reinstall main battery, and AC adapter.
Regards,
joecoolvette
Nov 04, 2012 | Dell Inspiron 1520 Motherboard
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
My screen on my dell inspiron 1520 has gone black
You've lost your desktop display.
The first thing I would do is to start the computer in safe mode. Once there, do a system restore back to the time that it worked.
I would also, just to be safe, do your disk management tasks like checking your hard drive for errors and running defrag.
Oct 22, 2009 | Dell Inspiron 6000 Notebook
Dell Laptop Inspiron 1525, boots up but once booted the screen only stays bright for a few seconds - a minute and the it seems to fade/ become very dim, you can barely see the windows behind it. This only...
Theres a good chance that you have a power settings problem.
goto:
control panel / power options / power schemes
and make sure you dont have quick time out for ac or battery.
even it if looks right, change both. and reboot see if helps
Aug 26, 2009 | Dell Computers & Internet
Dell inspiron 1520 laptop computer screen goes dark when plugged into power supply,not sure if it is due to power issues or computer itself, the screen had started to go darker on one side before i...
Check your display settings in the Power save part of Control Panel. You can set a brightness for battery and AC. Normally you set it brighter on AC and dimmer on battery (to save battery life) but if you've adjusted it for some reason that would explain it
Aug 21, 2009 | Dell V305w All-In-One R840635AU InkJet...
My laptop dell latitude d600 turns itself off its screen and fan
If your laptop with battery is OK
That is because the adapter connect to power is not very firm.
My inspiron 1520 LCD screen also has this problem, I change the adapter and Patch board . so it work fine now.
If your laptop work with battery also have this problem, it maybe caused by power supply system setup.
Apr 30, 2009 | Dell Latitude D600 Notebook
Dell inspiron 1520 screen dim on left side
make sure there are no speakers at the side of the monitor as the may not be sheilded. then unplug monitor from the mains and plug back in to reset. or in the monitor menu select degauze .
Apr 05, 2009 | Dell Computers & Internet
Black out screen dell inspiron 6400
Try to turn on the system with the charger plugged in and also how old is the system.if the system less than a year then try to get the battery changed and may be the motherboard.
Sep 07, 2008 | Dell Inspiron 6400 Notebook
Screen is dim
Try looking for a function key (usually used by holding down the Fn key and then pressing one of the "F" key at the top) the key will be marked with a brightness indicator.
Is your screen only dim when running off the battery is it dim when running when the charger is plugged in as well. If it is only dim when the laptop is running on battery then this may be caused by a setting in Power Options which is located in Control Panel (that is if your running Windows). In Power Options look for settings about running on AC Power and running on Battery power.
Jan 07, 2008 | Dell Inspiron 8500 Notebook
Computers & Internet Logo
David Payne
David Payne
