Question about Dishwashers
3yr old fisher paykel dishwasher not hot.
Hi, my 3yr old f&p dishwasher is only getting hot some of the time. It averages about 1 in 3 washes where it actually gets hot and cleans properly. We have tried all of the obvious things like clearing the drain and cleaning out the squirter bars. It seems to respond well to adding a little bit of disinfectant in with the tablet but it may just be coincidence. The machine is plumbed in to the cold water supply. The water supply is hard water supplemented with rain water in the winter months. Any ideas for a fix? I thought it may be a poor connection on the heater element?
Buy a new one.
Posted on Aug 07, 2008
I have a fisher and paykel dishwasher. 2drawers. Just ran. Stinks now and when I take out bottom stuff, stinky stagnant water inside
Do a hot wash with 2 cups of bleach in the dishwasher. No other chemicals, just bleach. It will kill the mold and clean it.
Aug 18, 2017 | Fisher and Paykel Dishwashers
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
On the 2nd draw will start washing but not even a minute flashes the F2 error and stop washing, what this means?
Hi Francesca, The link below is a short youtube video on how to simply fix f2 on your fisher and paykel dishwasher.......CHEERS..
https://www.youtube.com/watch?v=qP_X9iG0f-g
Mar 29, 2016 | Fisher and Paykel Dishwashers
Hi I am buying a MW512 but only have a cold water supply, does this model have an internal heating system so I can do a warm or hot wash?
Hi - Fisher & Paykels does not come with heaters fitted, the two hot/cold inlets are used in prortion to the settings of the wash cycle in use.
So with a cold tap only you would expect cold wash functions only, if you accidently chose a warm wash the machine will start beeping as there is nothing to bring the temp level to the expected setting.
Hope this helps you choose..
Jun 16, 2011 | Fisher and Paykel Fisher & Paykel Washer
Need to get out old motor rotor assy so we can put new one in.
This video will wok you through your Fisher Paykel repair, how to fizz a f1 error code and how to replace the rotor.
http://www.appliancerepairlesson.com/shop/dishwasher-videos/fisher-paykel-dishwasher-repair/
Sep 29, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel nautilus. Cycle stalls with 15 mins to go. On any setting.
OK, when you say it sounds like a record skipping does that mean its washing then not washing? what cycle are you using ? sorry to ask these questions but sounds like an unusual fault.is the water hot? could be control module or pressure switch fault. please reply and we can hopefully track down this fault.
May 22, 2010 | Fisher and Paykel 24 in. DS603H SS...
Fisher/ paykel dishwasher says F3
f3 water temp sensed at greater than 85 c or 185f check temp sensor or is element on all the time
Jun 29, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
FP Hot water used when cold selected
YOU NEED TO CHECK THE WATER TEMPERATURE AFTER THE TUB IS FILLED WITH WATER WHEN COLD IS SELECTED. NEW MACHINES WILL USE BOTH THE HOT AND COLD WATER VALVES TO FILL THE MACHINE. THEY DO NOT WANT YOU WASHING WITH STRICTLY COLD WATER AS THE DETERGENT WILL NOT PROPERLY DISOLVE. COLD WASH TEMP SHOULD AVERAGE 65-70 DEGREES.
Mar 30, 2009 | Fisher Paykel EcoSmart GWL15
Fisher Paykel double dishdrawer
pour some vinger in and run it thru a few cycle this will flujsh it out also if you have a hot tub supply store near you can buy a bottle of Foam Down and that will cut the bubbles down so you can wash again
May 02, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel ECO Intuitive IWL16 Top Load Washer
Try running a hot wash with no clothes in the machine add a little washing powder with it. Make sure it does a full cycle
Dec 16, 2007 | Fisher and Paykel GWL11 Top Load Washer
Dishwashers Logo
93 people viewed this question
Top Dishwashers Experts
