Question about Tomtom GPS
Not getting a GPS signal. What do I need to do?
    President:
  • Tomtom Master
  • 485 Answers
Usually, after you turn on the GPS device, it may take a minute or so to start up and lock into the satellite signals. While it is waiting to get a valid GPS signal, it is "listening" (scanning) for satellite signals to establish your current location.
If you are in the open outdoors, i.e. not inside a building or under extended covers, it should get the satellite signals within a minute or so.
If you still can't get a GPS signal, consider shutting it down ... using a "hard" shut-down (hold down the on/off button for 5 seconds or more ... to re-boot the system/software programs. Then, wait a while before starting it up again. Make sure your device is plugged in and/or the battery is NOT low when you're doing this.
Posted on Jan 02, 2011
Why doesn't the GPS pick up a current GPS signal?
You may need to do it outdoors; a building may interrupt enough satellite signal that it (the GPS) won't lock to it (the signal).
If it always says "GPS SIGNAL NOT DETECTED" when it's outdoors, I don't think you're going to get it to ever work. It may have been dropped & the internal antenna damaged.
Jul 26, 2014 | InVion GPS
Gps singal lost
Often, when your GPS is in a "covered" area ... e.g. inside a building, in a tunnel, under a bridge, amongst / under tall buildings, etc... when there is no open space (directly) between your GPS and the satellites, your GPS will loose its satellite signals. If you're in such locations, try to find some "open space" and wait a bit for the signals to be picked up again.
Another common reason why the GPS doesn't get signals, or doesn't get the signals quickly, is because the "latest" satellite positions (locations) have not been updated in your GPS. If/when you connect your GPS to your computer (e.g. using HOME ) and download the GPS satellite (QuickFix) location information, your GPS will have the most recent locations of the satellites in your vicinity/region. With this information, your GPS can pick up the signals more quickly ... instead of having to search/scan around to find the signals ... which can take a bit more time. While your GPS is searching for the satellite signals, it shows the "signal lost" or "no GPS signal" message.
Jan 16, 2014 | Tomtom GPS
I am using samsung corby pro mobile in Dalian,China. So here I am using China unicom sim card but GPS is not getting connected here. The officials of China unicom are saying that its the Work need to be...
Yes, that seems true. Telephone companies are more or less not responsible for GPS signals, unless they're using assisted GPS (aka A-GPS or something like that) which means that they're using the cell signals to help determine your position. Maybe your phone has problems getting GPS signals.
Mar 05, 2011 | Cell Phones
Why is my gps losing its signal
Try connecting it to the computer and running an update from TomTom Home, there is a GPS fix that might help. Obviously the TomTom needs clearence to see the satalites in the sky otherwise try a hard reset with a pen in the bottom.
Jun 25, 2010 | Tomtom ONE GPS Receiver
NO GPS SIGNAL
hi go online and update automatic. it wil receive new info about satts an wil function like before. do this couple of times a year. good luck
Feb 04, 2010 | Tomtom ONE GPS Receiver
No satellite signal
Some vehicles have a coating in the windshield that can interfere with the GPS unit receiving the satellite signal. It is not the unit's fault. You may need to purchase an external antenna to allow your unit to work inside your vehicle. These are available at www.garmin.com or at your local GPS retailer.
Nov 29, 2009 | Garmin nuvi® 200 Car GPS Receiver
Can't get a GPS signal for last 24 hrs
I had a similar problem and did solve it with the soft reset (pressing reset button). I have a One XL and there is a small reset button that you push with a paper clip. On the XL 330 you press and hold the on/off button for 15 seconds and the unit should reset.
My symptoms: Would not find a GPS signal. When I looked at the GPS Satellite status (press on the GPS signal strength bars, again on the GPS/battery status) you can see it locking on up to 8 satellites but would still not show a gps signal lock. Normally it only takes 4 satellites to get a gps lock. My other sympton was that when I attached the GPS unit to the computer and operated it with TomTom Home, it worked fine and locked on to the gps signal quickly (even inside my home). But it would never (at least for 30 minute trips) lock on to a gps signal. After doing a reset it began working normally and locked on to a gps signal after finding 4 or more satellite signals.
Aug 06, 2009 | Tomtom XL 330 Car GPS Receiver
STOCK IN ONE POSITION
Try a GPS reset, exit navigation, click on setup, click on GPS reset. then restart navigation. check the gps status screen to make sure you are getting signals. if not, you could have a failed antenna or GPS receiver in the unit.
Jan 26, 2009 | Fine Digital FineDrive 400 GPS Receiver
Always "Waiting for GPS Signal"
The waiting for signal message just means it can’t get satellite reception where you are. you most likely need to utlize the Optional external GPS antenna. This is a common problem in the midwest and southwestern states. if this has happened since you bought it. the internal antenna couldve come loose. Which means you may have got a defective unit from the factory. But my guess is you just need to utilize the external antenna.
its like thinking of a cell phone and how some people dont always get a signal. now in gps it needs 3x the signal. with 1/8th of the communications satellites cell phones have.
so as more and more people get tom toms the harder it is for each unit to work, and less signal can be partitioned to your unit at the time of use. where as cell phones only need 2 towers, GPS needs 4 satellites.
Jun 11, 2008 | Tomtom GO 700 GPS Receiver
GPS Logo
408 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
