Question about Haier Washing Machines
My HMW1260K won't spin and is showing an error2 message. It won't pump the water out or spin loaded or empty. Can you help me please Regards Marie
  • marie_lenard Jan 10, 2011
    Yes it was thank you
  • Haier Master
  • 1,902 Answers
Hello & Welcome to FixYa
Error code 2 means water is unable to drain and is displayed due to blocked drain filter/hose or the pump/motor has gone bad and needs replacement. First you will have to clean the drain filter and drain hose, after cleaning if the problem is back then replacing the pump/motor is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Jan 02, 2011
Won't spin and water is left and error message 3d
Please check the program controller unit and also the drain pump which could be clogged.
Check this link for tips and advice : www.espares.com
Jun 25, 2012 | LG WM2688HWM TROMM SteamWasher
Washer won't spin
Hi hometownrock,
The washing machine may have a problem draining the water, if it cannot drain the water, then the cycle will not progress to Spin. You may have a foreign object in the Drain Pump Filter, this must be checked.
Please follow my below Tip on how to do this:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 15, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
My samsung washing machine J1453S is having a problem with spinning, no problem with loading water, drive belt is fine.
Hi donna sarmie,
It could be your machine is stuck on the drain cycle, and won't continue to spin, because the drain filter is clogged.
You may need to clean the Drain Filter, please find my Tip below on the procedure:
Kind Regards :-)
JEDEMEYER1
Aug 01, 2011 | Samsung Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
My washer fills with water on starting a load but then it does nothing won't start spining to empty water
If the machine loads ups with water and does not stop then the water level sensor is fautly . But if the inlet valve stops on fill up but there is no spin of the motor or thereafter there is no spin/rinse or drain then the program controller / drain valve/pump must be checked.
Jun 14, 2011 | Washing Machines
My machine saying error2 what does that mean thanks marie x
Haier Error 2 means 'water not emptied in 4 minutes'.
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Apr 28, 2011 | Haier Washing Machines
Hotpoint WD61 - I have taken back off, emptied blocked filter but having reasssembled the water does not drain and therefore does not spin. If I empty water via a bucket from drain hose the machine does...
hello, is sound like the pump not energizing the pump needs testing with a multimeter. fill it up again then empty it you should hear the pump kick in also check the hoses make sure there not kinked good luck
regards
shaun
Dec 05, 2010 | Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Ariston AML125 won´t spin or empty water.
Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manula once in a while, it does help!
Dec 02, 2008 | Ariston Technologies AW125NA 13 lbs. Load...
Washing Machines Logo
319 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
shaun taylor
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
