Question about NetGear ProSafe FVG318 (606449041668) Firewall
Does a 10 second reset on a Netgear router reset everything. Even the password on the network and so on?
  • NetGear Master
  • 27,725 Answers
It should only set the password on the router
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
Posted on Jan 02, 2011
Testimonial: "Supa Thankys. =D"
I have a netgear readyNAS NV+ that i want to reset the password.
Whether you bought a used Netgear router or just forgot your own password, you can reset it and start over.
This is not an unusual problem, so Netgear has made resetting and restarting their routers a simple task
Connect all of your devices.
If your Netgear router is not already connected, it should be plugged in, with one Ethernet cable connecting it to your computer and a second Ethernet cable connecting it to your computer's modem.
Locate the reset button on the rear of your Netgear router.
The reset button is a small inset button and requires a pointed object to reach it.
Use a fine-tipped pen to hold the button down for at least 10 seconds.
The test light should flash during this process.
Open your Internet browser and enter the Netgear router's IP address into the address bar to access the router's information. Generally, Netgear routers use the IP address 192.168.0.1, but the specific IP address will be listed in the router's manual.
Attempt to log in to the router with the default username and password.
The default username is "admin" and the default password is "password."
If the router's username and password were not cleared away, unplug the router and try holding down the reset button.
While you are holding down the reset button, plug the router back in.
Log in to the router using the default "admin" username and "password" as the password.
You can now reset your information, rename your router and enter your own username and password.
http://kbserver.netgear.com/media/flash/training/Troubleshooting/NG_WGR614V9Router_TS_LostPassword.html
Sep 03, 2013 | NetGear Computers & Internet
Info on how to reset the router
You can factory reset the router using the small button on the back, hold it in for 30 seconds with the power on to the router. This will clear all settings from the router including the password, so you will need to set up the router again after the reset.
Sep 21, 2011 | NetGear WGR614 Wireless Router
I have lost my network security key. My router is a Netgear
If you have lost it for good your best bet is to reset your router to its defaults and then set a new one. You should find a button, usually red, on the back of the router. Press that for about 30 seconds or until you see the lights cycle. The router will now be returned to its defaults and you will be able to log into it using the default credentials and set it back up. Good luck.
May 04, 2011 | Computers & Internet
I need to reset my password
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
Feb 17, 2011 | NetGear WGR614 Wireless Router
Need to find out password or how to reset a new password
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
dont forget to vote hope this helps
Feb 05, 2011 | NetGear WGR614 Wireless Router
Does a 10 second reset on a NetGear router reset everything. Even the password on the network and so on.
It can... Are you talking about holding down the reset button for 10 seconds? That may or may not do the actual reset, on some models you have to power it on while holding the reset in, but in any case... 10 seconds is more than long enough to do the job, as long as the sequence was performed properly.
The login, password, and basic settings should all revert to factory defaults. Remember to log in promptly and setup a new ID and Password so no one else can get in with the defaults and change it on YOU. 8^)
Good Luck..
:o)
Jan 02, 2011 | NetGear ProSafe FVG318 (606449041668)...
How do i reset password for netgear router
There should be the reset button behind the router, click on it for about 5-10 seconds.
Jun 26, 2010 | NetGear WGR614 Wireless Router
How do you reset a password?
Easy, reset the router itself, should have a tiny pin hole in the back that has a button that you must compress, just google reseting your model.
If you have any problems let me know.
Apr 03, 2010 | NetGear DG834G Router
My moms cable company installed a new modem and left the router disconnected--I reinstalled the software and hooked everything back up and my laptop recognizes the network but seems to be stalled out at...
Hi ,
This is Neo . Thanks for contacting us .
Reset your Netgear and Try it again .
The step to be followed are ,
STEP 1
Reset the Router by pressing the RESET button on the rear till the Test Light blinks.This takes about 10 seconds . Use a pen or paper clip to access it .
Release the button and wait for the Router to Reboot.
STEP 2
Login to the Router with the default Password. The Router has the default User Name as 'admin' and the default Password is 'password' .
STEP 3
If the Router was not cleared after rebooting, unplug the Router's power . Then Press and hold the Reset button.
STEP 4
While the button is held down, reconnect the Router's power . Continue to hold the Reset button for 20 seconds after reconnecting the power . Wait for the router to reboot .
Then Login to the Router with the default Password. The Router has the default User Name as 'admin' and the default Password is 'password' .
Do the setup and try to connect to internet .
The Router will work .
Thanks & Regards
Neo
Thanks for using FixYa.com.
Feb 07, 2010 | NetGear WGT624 Wireless Router
NetGear ProSafe FVG318 (606449041668) Firewall Logo
476 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
