Question about Microwave Ovens
How to access and find fuse in magic chef (installed under cabinet) microwave. No power to microwave (nothing working including light)
    Brigadier General:
  • 8,909 Answers
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Posted on Jan 02, 2011
Testimonial: "The fuse turned out to be the problem. So far so good, mircowave is working"
Where is the fuse for magic chef microwave?
The fuse is internal. Unplug microwave and ope. Casing. Fuse is in the back. Make sure tools used are insulated and touch nothing other than the fuse.
Oct 16, 2016 | Magic Chef Microwave Ovens
SERIAL # 20101639 RELEASED 2002 THIS MAGIC CHEF IS USED IN AN RV FUSE BLEW RESET MAIN FUSE MICROWAVE DID NOT COME ON PULLED OUT CHECKED POWER OUTLET AND POWER IS WORKING TO OUTLET CHECKED ON ANOTHER...
most microwaves do have a fuse to protect the power supply .outer cabinet has to be removed and then you will be able to see it . look where the power cord comes into cabinet
Dec 01, 2017 | Magic Chef MCM660A Microwave Oven
Magic chef mcd1611st microwave oven,why is power gone it self off?
Check the fuse inside the microwave cabinet...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Dec 13, 2010 | Magic Chef MCD1611ST Microwave Oven
Is there a power fuse on a MCD1611?
Yess there is a ceramic 20 amp 250 volt fuse inside the cabinet. Safety first!!! Unplug the microwave from the wall outlet.
If you remove the four T20 Torx screws that hold the case on(back of cabinet around the edges) and carefully slide the case back and up you can access the fuse. It will be on the circuit board near where the power cord enters. If you have a ohmeter you can check the fuse. The ceramic fuses are not clear so you cant tell a blown fuse by looking.
Feb 16, 2010 | Magic Chef MCD1611 Microwave Oven
I purchased a Magic Chef under cabinet microwave from Home Depot on clearance. Got it home and installed when testing all the functions all worked well but the night light function. if you press the light...
Since it's a clearance item, it may not have a warranty.
But you should check with Home Depot on that if you haven't already.
Otherwise, you'd have to have it repaired yourself.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Oct 09, 2009 | Magic Chef Microwave Ovens
We have a Magic Chef microwave oven inour travel trailer and it is not working. The plug is OK but the microwave will do nothing.
Generic comments:
Do you have power to the outlet? Do you have a light or does the control panel light up?
If you have power in the wall - CHECK IT and nothing at the machine, remove the cover - check the fuse on the floor of the cabinet near where the cord enters. DO NOT TOUCH THE SILVER CAN - LETHAL.
If you have a good fuse, you may want to check the door safety interlocks. If it gets this far and you need more help, please let me know. Id be glad to give it a try.
A
Sep 24, 2009 | Microwave Ovens
Magic Chef M/W MCD990ARB - heat quit
Mine did the same thing: Replaced the HV Cap and diode - works fine now.
Jul 05, 2009 | Magic Chef MCD990W Microwave Oven
I was making popcorn and the microwave just died
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
For more help from Magic Chef / Ewave see here or their contact page.
For Magic Chef in Canada call 866.587.2002
Jun 07, 2009 | Magic Chef CMV1000B Microwave Oven
I have an magic chef mvp V microwave and have just put in new cabinets. Do i need to cut an air vent in my cabinets or does it vent through the front?
Consult your installation instructions for that information.
For more help from Magic Chef / Ewave see here or their contact page or order parts here.
You can download owner's manuals for many Magic Chef models here.
Jun 05, 2009 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
