Question about Alpine Air XL-15 Air Purifier
I do not smell the ozone. does not clean air - Alpine Air XL-15 Air Purifier
    Sergeant:
    Novelist:
  • 185 Answers
I would clean it, air filter, plate If you need a manual you could try this site.
http://www.allrepairmanuals.com/
Posted on Jan 02, 2011
Eco Quest Living Air XL 15S Classic Air Purifier Cleaner Ozone Ionizer USA
Ozone is not good for you. If you can smell it, it is set too high. Look at it in dark room and check for blue orange glow inside the fan louvers. If you see the glow, it is working
Jan 10, 2017 | Air Air Purifiers
When I turn my brand new air purifier on on it smells like its burning or going to catch on fire is it supposed to?
That unit is a very heavy duty machine that uses ionization to clean air. There is a high voltage power supply that is used to generate ions. The unit can release ozone and that substance has a definite smell to it. If you have ever been near a copy machine or an electric motor that sparks, you would smell ozone. The concern is whether or not it is ozone. Ozone is regulated by the manufacturers to be held at a permissible level because at high concentrations it is an irritant and can cause respiratory issues by itself. The power unit for that air cleaner is on the top near the back and you can run the machine for a while to see if that area gets hot. That would be a bad sign. All the documentation is here: http://electronicaircleaners.com/f50f1032parts.aspx But if you don't trust the unit, take it or send it back.
Feb 20, 2016 | Honeywell (F50F1032) Air Purifier
Does not produce ozone, I have replaced the fuse, it has been cleaned and the amber light is not on.
it's possible that the ozone generator inside has gone bad. The only way to really know is to remove it from the unit and then test it with a power supply w/correct voltage of coarse. You will smell the ozone immediately if it works upon testing. (clean fresh smell) If it does need replaced, it's an easy fix for anyone with electronics knowledge. You will need to match up the numbers to get the correct replacement. Many are available on Ebay. Always disconnect the power to the unit before taking it apart. Hope this helps, Dave
Nov 18, 2013 | Ecoquest Living Air Classic Air Purifier
How do I clean the glass plates in the flair living air f141023
Usually a mild cleanser is all you should need. In some extreme examples you to clean the contact area and the contact itself for ptting, and then lightly rub the mesh with 600 grit finishing paper to break up the silica that may have formed.
Ozone itself is a power oxidizer, it will clean the air in an enclosed room. Excessive Ozone "can" be a problem that usually manifests itself as upper respiratory irritation. Lower levels oxidize with pollutants and you never know it's there.
Ozone will also attack eurethane foams, foam rubber, and elastic rubber. So speaker surrounds usually decompose, and headliners in cars often fall apart about 6 months after exposure-used car dealers use them a great deal to kill residual tar and soot from smokers.
Feb 05, 2012 | Ecoquest Air Purifiers
Hi-I have the Living Air XL. It's out for repair because I cannot smell the distinct clean smell it normally puts out. The repair guy just called and said it's fixed and running, but the green light bulb...
He probably cleaned the unit and restored the plaques. Green light or no green light, it doesn't affect the production of ozone. If still in doubt, when you go to pick it up, have him operate fit or you before you leave the store. I've had one 7years and the green light hasn't worked for three years. I clean it regularly and it still produces ozone when needed. Regular, routine maintenance is the answer.
Mar 28, 2011 | Ecoquest Living Air Classic Air Purifier
My flair unit does not smell of ozone. Why ??
It properly needs the filter and interior cleaned. Especially, if it has run a long time without being cleaned. Or there is nothing in the household air at this time to trip the Ozone producing switch.
Feb 06, 2011 | Ecoquest Flair Air Purifier
No ozone smell
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
May 19, 2010 | Ecoquest Flair Air Purifier
Ozone smell
When the unit is clean it will produce more ozone. If the unit is a bit oversized then it becomes worse. As an installer I have to be carefull to not oversize these units. O3 is harmless and actually will only stay in the air as O3 for about 1/2 hour. Because of this it will not build up in the air. O3 also in a powerful disinfectant and will help kill mold and bacteria in the air. As soon as the filter gets a little bit of dust on it the O3 production will become much less. Run your fan continuously for a day or so and it will go away.
Nov 15, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
XL15
The ozone plates need to be cleaned monthly to work effectively. You can get an owner's manual for free from the manufacturer's website, it's at:
http://www.ecoquestintl.com/support/US50300_Living_Air_Owners_Manual.pdf
The manual has a description of the type and frequency of cleaning of various parts of your air purifier. Hope this helps!
Oct 29, 2007 | Alpine Air XL-15 Air Purifier
Alpine Air XL-15 Air Purifier Logo
108 people viewed this question
Top Alpine Air Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Tom Chichester
Are you an Alpine Air Air Purifier Expert? Answer questions, earn points and help others
